Performance tuning specialist - Offering custom remaps, turbo upgrades and performance exhausts
uk-mkivs » The Mk4 (MkIV) Community » MkIV Performance and Technical Area » Mk4 - Engine, Turbo and Exhaust » 1.8T Turbo lifespan
1.8T Turbo lifespan
Last post Sun, Dec 21 2008 11:59 AM by Caged. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Dec 19 2008 11:49 AM 1.8T Turbo lifespan
    Caged
    • Joined on Tue, Jan 8 2002
    • Posts 886
    Anyone know what the typical lifespan is of a K03 turbo?
    If worn, what are the symptoms likely to be?
    1.8T, Upsolute and LPG
  • Sun, Dec 21 2008 9:56 AM Re: 1.8T Turbo lifespan
    Caged
    • Posts 886
    No one suggest symptons to look for?
    Would smokey on startup and oil in the pancake pipe suggest the turbo is past it's best?
  • Sun, Dec 21 2008 10:09 AM Re: 1.8T Turbo lifespan
    scoles
    • Joined on Fri, Nov 2 2007
    • Posts 668
     Smoke? what colour? does it smoke only on startup or all the time?
    how much oil is in the pancake pipe?
    you have to allow for a little oil as the turbo seals are not 100% efficent but at the same time if your getting a cup full of oil out the pankcake pipe then that would suggest turbo seals....
    Mine only produced blue smoke after sitting ticking over for a while and when initially pulling away it gave a puff of blue smoke.... the seals were starting to weep so had it rebuilt and its been 100% ever since....
    Stuart
    Miltek Turbo Back, N75J, Forge Recirc Valve, K03s , Forge TIP, custom FMIC G60 flywheel & VR6 clutch Whiteline front/rear ARB's, coilovers set LOW 312mm brake upgrade BBS LM reps........235BHP - 237FT/LBS
  • Sun, Dec 21 2008 10:11 AM Re: 1.8T Turbo lifespan
    NooNoo
    • Joined on Sun, Jul 1 2007
    • Posts 1,816
    Having seen pancake pipes on many mk4 turbos (k03 or k03s) it is normal to have oil contaminating the hot side of the intercooler. So oil in the pancake pipe is no indication of turbo wear or imminent destruction!
    Talking to other drivers and reading this forum turbos tend to fail catastrophically with little warning. Shaft movement is probably the only way of measuring "wear" but that involves some dismantling.
    Smile
    1.8T Golf MKIV AGU 231 BHP | Satin Silver | 5 door | xenons | sunroof | cruise | Black chrome BBS RCs | K03s | RTech stage 2 map | Blue flame turbo back | Vmaxx coilovers |SFS TIP | S3 strut braces | Delocked | Aero-wipers | Rear polo wiper | W8 sunroof interior light | Boost gauge | Retro heated Recaros | Eibach ARBs 25mm F&R | Forge FMIC soon | R32 front soon | Girlfriend drives it
    ED30 | Steel grey metallic | 5 door | Xenons | Sunroof | Cruise | Highline | Armrest | Privacy glass | Luxury pack 2 | Hybrid RCD300 | Hertz front components | 2 x Kenwood 5204 amps |
  • Sun, Dec 21 2008 10:37 AM Re: 1.8T Turbo lifespan
    Caged
    • Posts 886
    Smokes on startup if I've had to crank it a few seconds (Blue) and apparently smells of oil when someone is following.
    It's done 156k miles now.
    Bext places to buy Ko3 or Ko3s? Can't really have the car off the road to get it rebuilt.
  • Sun, Dec 21 2008 11:50 AM Re: 1.8T Turbo lifespan
    scoles
    • Posts 668
     turbo technics offered me a replacement for £500 plus VAT i think it was and its £195+VAT for a rebuild.... a rebuild took 2 days
    the turbo is the easiest thing to assume when blue smoke arrives? may be worth checking a few other things? as if the turbo was worn or passing oil i would imagine it would do it at more than just startup....
    Stuart
  • Sun, Dec 21 2008 11:59 AM Re: 1.8T Turbo lifespan
    Caged
    • Posts 886
    Cheers for that. May be smoking more, I only notice on startup.
    Cheers for the rebuild info.
