uk-mkivs » Technical Community » D.I.Y Guides and How to Instructions. » Crimping and soldering how to.
Last post Sat, Feb 21 2009 2:24 AM by aRd. 10 replies.
Page 1 of 1 (11 items)
  • Tue, Feb 3 2009 6:51 AM Crimping and soldering how to.
    geezer_3000
    Golf IV Final Edition 1.6 16v AUS 105PS
    • Joined on Fri, Oct 31 2008
    • Posts 140
     Afternoon all.
    I came across this page and thought it might help some of you outYes
    http://www.mmxpress.com/technical/connections.htm
    WANTED: BORA SPORT INSTRUMENT CLUSTERS 1J5 920 926 A.
  • Tue, Feb 3 2009 6:57 AM Re: Crimping and soldering how to.
    tre271
    • Joined on Sat, Jan 5 2008
    • Posts 1,042
    Hi mate,
    That's a good guide if your not sure how to go about it. Good find. I'm afraid I still giggle at "crimp" though!
    I could be wrong but this post is in the wrong section, you should have posted it in the D.I.Y / How to section. Mods will have to move it for you. Make sure you read the forum sections before you post... no worries, it's an easy mistake to make.
  • Tue, Feb 3 2009 7:00 AM Re: Crimping and soldering how to.
    PJ Moderator
    • Joined on Tue, Jun 10 2003
    • Posts 3,130
    tre271:
    Yep, and moved.
    This section is for help on using the forum.
    1.8T | Leather Recaros | Eibach Pro -30mm Springs & Shocks | Xenons | Upsoluted
  • Tue, Feb 3 2009 7:03 AM Re: Crimping and soldering how to.
    geezer_3000
    • Posts 140
     Cheers guys.
  • Tue, Feb 3 2009 1:49 PM Re: Crimping and soldering how to.
    • Posts 17,761
    All I will say about soldering is that although it is said to give the lowest resistance and most reliable joint,it isn't always the best way of joining two wires together.Crimping done properly under VERY high pressure will form a cold weld that will melt all the parts together and give a much better joint than soldering ever will.
    Manufacturers will never solder inside a wiring loom,partly due to manufacturing costs,but also because a multi-strand wire that has beeen soldered turns into a much more brittle single strand wire,that is more prone to failure.
    It is however the best way for the small scale amateur messing about with low current lights etc on his/her own car,the mistake most people make is either not enough heat (you get a dry joint and improperly melted flux can make a worse joint than twisting the wires together),or too much solder travelling too far up and down the wire,also caused by too much heat.
  • Tue, Feb 3 2009 8:51 PM Re: Crimping and soldering how to.
    charles_mckendrick
    Golf IV GTI 2.0 8v APK 115PS
    • Joined on Tue, Dec 23 2008
    • Posts 387
    nice little guide u got there, cheers mate
  • Wed, Feb 4 2009 7:24 AM Re: Crimping and soldering how to.
    geezer_3000
    • Posts 140
     cheers mate.
  • Fri, Feb 20 2009 1:08 AM Re: Crimping and soldering how to.
    Golf V5 Moderator
    • Joined on Tue, Apr 30 2002
    • Posts 1,979
     As im one of only a hand full of people that has probably stripped a Mk4 Golf right to the bone im 100% sure VW solder in there harness if im right the Heated Seat Wire Lume is soldered to main harness at some stage and the Boot cd Changer harness is too
    Life is only what u make it, Make it VW
    There are No Stranger,s here just Friends that have Never Met
  • Fri, Feb 20 2009 2:21 AM Re: Crimping and soldering how to.
    • Posts 17,761
    Golf V5:
    I've looked at every pary of a mk.4 wiring loom at some time and I've never seen any soldering.I've fitted a few heated seat looms and they're all 100% plug and play except for the ignition and illumination wires which I've soldered but if fitted as OEM woyldn't have been.
    What I meant was that unless some very last minute changes are made they wouldn't normally solder inside a wiring loom,they would use crimps instead,but not the DIY red,nlue or yellow ones we use.
  • Fri, Feb 20 2009 1:33 PM Re: Crimping and soldering how to.
    mortygttdi
    • Joined on Fri, Sep 28 2007
    • Posts 393
    Ive just fitted a new rear left abs loom into my mk5 cos some idiot had tried to repair it near the wheel end instead of replacing it,  I can confirm that the original wiring to the main loom was soldered.
    Darren
  • Sat, Feb 21 2009 2:24 AM Re: Crimping and soldering how to.
    aRd
    Golf IV SDI 1.9 AQM 68PS
    • Joined on Sat, Aug 17 2002
    • Posts 2,869
    Golf V5:
    VW do use solder in certain situations in the harness.  Jimmy didn't we cut out the harness for the heated seat loom for me.  I'm sure there was soldered junctions in that loom.  Thats going back a few years.
    Need some help with Vagcom check, Keys/Immobilser adaption, cluster swapping, Miles till Empty/Illuminated Needles, Autowindows, ECU swapping//coding etc... PM me :) Pics of the aRd automobile http://uk-mkivs.net/forums/p/239924/1548484.aspx#1548484
