uk-mkivs » Technical Community » D.I.Y Guides and How to Instructions. » Installing "No Holes" Parking Dynamics - PD1 Vision Reversing Sensor
Last post Fri, Feb 19 2010 11:39 AM by Brian566. 10 replies.
Page 1 of 1 (11 items)
  • Mon, Jun 15 2009 1:11 PM Installing "No Holes" Parking Dynamics - PD1 Vision Reversing Sensor
    CaptMadDog
    Golf V GTI 2.0 200PS
    • Joined on Tue, Mar 10 2009
    • Posts 404
     Well fellas as promised I managed to install the above on Sunday afternoon with the help of another forum member Mk4Richie.  The kit I installed was the VISION model which comes with the unit that displays the distance from objects aswell as the audible tone, for the speaker only version the install is exactly the same.
    Tools required are
    VW Star Type ScrewDrivers or Screw Heads - 3 different sizes
    13mm + 10mm Socket
    Inline Splices
    Multimeter
    Underbody Sealant Paint + Paintbrush
    Initial reports from the wife are very very favourable - she is chuffed to bits tbh.
    Here goes -
    1. We first jacked up the rear of the car and placed it on axle stands - to allow both rear wheels to be removed.
    2.  Once the rear wheels were off we could access the rear bumper retaining screws.  There are four per side.
    3. Now remove all the boot ancills - such as the carpet, parcel shelf, spare tyre and so on.
    4. Now remove the  long plastic panel which covers the boot catch - it just pulls off, use even pressure and all will be good.  Doesnt Richie make a great model!!
    5.  Now pull back the carpet behind the light clusters which will expose two plastic bolts - these hold the light clusters on.  Also on the drives side the rubber wiring grommet is visible with the carpet pulled back.  More about this later.
    6. Remove the two plastic bolts and slide the rear lights off exposing two more bumper retaining screws per side.
    7. Under the car now on the rear valence there are 4 more retaining screws to remove.  Take these off and remove the two screws per side as indicated above.  The bumper can now be slid off.
    ** Carefull though as the numberplate lighting loom needs to be disconnected - two man job **
    8.  Scarily enough the rear of your pride and joy should look something like this.
    9.  I then took some water and a scotchbright and scrubbed the inside of the bumper where the sensor strip was going to be installed so I could get a good key for the adhesive.
    10. While this was drying we stripped back some more trim removing the upper rear headlining strip, and the parcel shelf support (passenger side), we loosened the wiring grommet and exposed the reversing light bulb housing and popped open the trim around it.
    11. With the parcel shelf support removed the Earth Point was exposed and we used a ring connector to earth the Parking Dynamics wiring.(yellow connector)
    12. We then carefully fed the red wire (PD Loom) up through the hatch gromet and into the boot lid where the reversing bulb was housed.  Made easier by tying the wire to a section of wire coat hanger to get through the gromet!!
    13. Using a multimeter we selected the 12v wire (white) to the bulb and took a feed off that for the red wire. We then carefully tie wrapped the red wire to the OE wiring and clipped the trim back into place.
    14. The supplied ECU now had the power it needed to operate.  The second section of the install concerns the sensor and small display unit.  The ECU found a neat location between two looms but can go anywhere you like.
    15 The wire which connects to the sensor needs to run from the passenger side to drivers side and down through the wiring gromet where the number plate lights are plugged in. See pic.
     16.  With the sensor wire ready for connection the actual sensor needs to be applied to the bumper itself.  We did this once and then attached the bumper testing its sensitivity.  After a few tries we decided to install two sensors as one wasnt enough imho.
    17.  After checking the sensitivity we removed the bumper and applied a generious coat of underbody sealant to the sensor strip to prevent it from corroding.
    18.  With the sealant drying we tried to think of somewhere to install the Visual Display unit - I didnt want to install it on the dash so we decided to feed the wiring into the headlining and attach it to the rear courtesy light.  Looks great to me as I naturally look rearwards when reversing.
    19.  With the sealant over the sensor dry we carefully attached it and pushed it into place for a final test.
    After much joy in the system working - very well I may add, we in true Haynes fashion put the car back together.
    After using the PD1 Vision system for a whole day my wife is very happy with it - no problems when wet or raining and the quality of the kit was very high.  All in all I would recommend this kit to others and think its a very neat and stealthy way of having reversing sensors fitted.
    We increased the sensitivity by installing a second sensor strip above the first which did noticably extend the detection range.  The display unit is very easy to interpret and the audible tone beeps faster as you approach the object.
    Top Marks for Parking Dynamics
    Where Napoleons armies marched with horse and musket and Hitlers Reich crumbled in blood and rubble, the warriors of Armageddon do battle against the landscape of hell now indeed thrive the ARMOURERS
  • Mon, Jun 15 2009 4:16 PM Re: Installing "No Holes" Parking Dynamics - PD1 Vision Reversing Sensor
    apkent
    Golf V SE 1.9 TDI 105PS
    • Joined on Sun, Nov 30 2008
    • Posts 178
    Brilliant write-up, just what I was hoping for. Thanks very much for taking the time to take photos etc.
    Looks like our group buy should be a goer then Big Smile
    Cheers Yes
  • Mon, Jun 15 2009 6:37 PM Re: Installing "No Holes" Parking Dynamics - PD1 Vision Reversing Sensor
    p1tse
    • Joined on Tue, Nov 2 2004
    • Posts 295
    thanks
    awesome write up
    an extra antenna means extra cost ;-(
    for an amateur it looks quite a task
    how long did it take to do in total?
    MKV Golf DSG
  • Tue, Jun 16 2009 1:13 AM Re: Installing "No Holes" Parking Dynamics - PD1 Vision Reversing Sensor
    CaptMadDog
    • Posts 404
     Hi p1tse,
    There is an xtra antenna in the box so no extra cost!! To be honest there was enough spare to probably do another car so dont worry about that.
    Myself and Richie are definately amateurs so dont get too worried - the trim just pops off and on with clips so even pressure to remove, no problems.
    Now we have identified the best place to take to take the 12v source from IE the reverse bulb itself installing the kit shouldnt take much longer than 3 hours or so.
    We just took our time as we were both pretty hungover and suffering with hayfever!!
  • Tue, Jun 16 2009 3:07 PM Re: Installing "No Holes" Parking Dynamics - PD1 Vision Reversing Sensor
    mk4richie
    • Joined on Mon, Jul 9 2007
    • Posts 446
     Oih, amateurs! Ha ha. Yeh a fun day spent mostly with toilet roll stuffed up my nose, to prevent  regular sneezing fits.
    To be honest I never thought the kit would be half as good as it actually is. Top marks. Bloody good for £60 IMO.
    Just need me a mk5 GTI
    Richie K
    Chipped UK ST3, EGR Delete, Uprated clutch, 18" RS6 rep's (due to some knob ruining my DTM's), Eibach Springs, Full custom stainless exhaust with decat, Ambient footwell lighting, Smoothed airbox with DSG intake parts, Green Panel filter, Sharan rear badge. More to come soon.
  • Tue, Jun 16 2009 6:52 PM Re: Installing "No Holes" Parking Dynamics - PD1 Vision Reversing Sensor
    p1tse
    • Posts 295
     nice one
    out of interest i hear there are hole marks for oem sensors, did you see them and use it to line up the antenna?
    MKV Golf DSG
  • Wed, Jun 17 2009 1:15 AM Re: Installing "No Holes" Parking Dynamics - PD1 Vision Reversing Sensor
    CaptMadDog
    • Posts 404
     I didnt see any marks for the standard sensors to be honest - although I wasnt really looking.  I lined up the antenna using the instructions as it recommends the strip is applied between 40cm and 60cm from the ground.
  • Tue, Jun 23 2009 3:03 AM Re: Installing "No Holes" Parking Dynamics - PD1 Vision Reversing Sensor
    T70MM-B
    Golf IV 1.6 8v AKL 100PS
    • Joined on Tue, Apr 14 2009
    • Posts 165
    great guide sounds like a bargain !
    everyone loves a nice vag ;) . . .
  • Mon, Aug 10 2009 8:05 AM Re: Installing "No Holes" Parking Dynamics - PD1 Vision Reversing Sensor
    AdamRawlins
    • Joined on Mon, Aug 10 2009
    We are distributors of Parking Dynamics parking sensors and have a trade stand at VW Festival this Sunday Leeds, anyone with a PD1 no Holes sensor fitted on their golf that wants to display their car on our trade stand please let me know.
  • Sun, Aug 16 2009 1:13 AM Re: Installing "No Holes" Parking Dynamics - PD1 Vision Reversing Sensor
    therealvw
    • Joined on Fri, Jun 19 2009
    • Posts 3
    Excellent thread! Funny thing is thought.. I have a bike JUST like that one!!
    Never ride faster than your guardian Angel can fly!
  • Fri, Feb 19 2010 11:39 AM Re: Installing "No Holes" Parking Dynamics - PD1 Vision Reversing Sensor
    Brian566
    • Joined on Fri, Feb 19 2010
     CaptMadDog
    I have just used your excellent guide and fitted these to my  2006 Audi A3 Everything went as planed Except Connections to reverse light are bad due to them been in the Tailgate and the connection is in the pillar
    I have also done as you have and put the vision unit at the rear interior light
     Just One Urgent Question
     The unit does a Quick bleep when Reverse is engaged as it should
    But it Also Does a Quick Bleep when you turn the ignition on I suspect this is the self diagnostics check
     and the unit is picking this pulse up Did yours do this ?? I have asked Parking Dynamics but they seem unsure
    Can you send reply please if you pick his up
    Briant566@talktalk.net
