Thanks for that Bruce, I'll investigate this further tonight
A current update on the situation is that I re-scanned last night. Cleared the faults then ran for 20 odd miles and ran another scan. All faults vanished except for the MAF signal being too low. However this morning I left home and the ASR light came on straight away. Then, when I switched on the A/C, the engine management light came on!
Full scan results from yesterday:
Address 01: Engine Labels: 06A-906-032-AUM.lbl
Part No: 06A 906 032 DR
Component: 1.8L R4/5VT 0003
Coding: 11500
Shop #: WSC 14386
1 Fault Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 00028 000 00000
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B2 907 044 C
Component: CLIMATRONIC C 1.0.0
Coding: 11000
Shop #: WSC 00028
3 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
37-10 - Faulty - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
01274 - Air Flow Flap Positioning Motor (V71)
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 27 AIRBAG VW5 01 0006
Coding: 12855
Shop #: WSC 00028
No fault code found.
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 926 AX
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 05414
Shop #: WSC 00050
XXXXXXXXXXXXXXXXX VWZ7Z0B5565542
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01271
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 4V Zentral-SG Komf. 0001
Coding: 00256
Shop #: WSC 00028
Part No: 1J2959802C
Component: 4V Tırsteuerger. FS0002r
Part No: 1J2959801D
Component: 4V Tırsteuerger. BF0002r
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
Address 76: Park Assist Labels: None
Part No: 1J0 919 283 A
Component: Einparkhilfe 0001
Coding: 00103
Shop #: WSC 00000
End ---------------------------------------------------------------------
Phil
