uk-mkivs » Technical Community » VAG Diagnostic Software Discussion » Bora Glow plug circuit fault code?
Last post Wed, Jul 1 2009 6:38 PM by BeartheBruce. 3 replies.
Page 1 of 1 (4 items)
  • Tue, Jun 30 2009 11:44 AM Bora Glow plug circuit fault code?
    turborat
    • Joined on Sat, Jan 5 2008
    • Posts 9
    I just scanned my friends Bora TDI150 and it came up with the following...
    Control Module Part Number: 038 906 019 KG
      Component and/or Version: 1,9l R4 EDC 0000SG  5342
               Software Coding: 00002
                Work Shop Code: WSC 01266
               Additional Info: WVWZZZ1JZ4W151516     VWZ7Z0D9149894
    1 Fault Found:
    17056 - Cylinder 2 Glow Plug Circuit (Q11) Electrical Fault
            P0672 - 35-10 - - - Intermittent
    This is the second time it has shown this fault. Has anyone else come accross this or any idea on what the actual problem is.
    Any help appreciated.
    Thanks!
  • Wed, Jul 1 2009 7:22 AM Re: Bora Glow plug circuit fault code?
    BeartheBruce
    • Joined on Wed, Feb 15 2006
    • Posts 262
  • Wed, Jul 1 2009 2:20 PM Re: Bora Glow plug circuit fault code?
    turborat
    • Posts 9
    Thanks Bruce,
    Sorry for my lack of knowledge but does this mean the glowplug needs replacing or is there something else that could cause this electrical fault issue?
    Sorry for the seemingly simple question but I need to get to the bottom of this.
  • Wed, Jul 1 2009 6:38 PM Re: Bora Glow plug circuit fault code?
    BeartheBruce
    • Posts 262
    The answer is in my previous post - you need to check the wiring and /or the glow plug.  Continuity and resistance tests are required to determine which is causing the fault.  Use a multimeter to check these.  Compare the bad readings to a known good glow plug circuit.
    -Bruce-
    Ross-Tech,LLC
    Bruce@Ross-Tech.com
