uk-mkivs » The Mk4 (MkIV) Community » MkIV Performance and Technical Area » Mk4 - Interiors » removing & replacing steering wheel? little helps please
Last post Thu, Jul 9 2009 4:03 AM by zaine. 16 replies.
Page 1 of 1 (17 items)
  • Fri, Jul 3 2009 3:34 AM removing & replacing steering wheel? little helps please
    zaine
    • Joined on Mon, Feb 23 2009
    • Posts 260
    new to the vag game
    could someone give me a quick run through on the best way to do this please
    doing it on a mates mk4 golf gti if that helps
    many thanks
    Chris
    Bora Sport Clocks for sale - pm me
    Wanted - 18's with good tyres, wheel condition doesnt matter aslong as they're straight
  • Sat, Jul 4 2009 4:35 AM Re: removing & replacing steering wheel? little helps please
    zaine
    • Posts 260
     anyone Sad
  • Sat, Jul 4 2009 7:34 AM Re: removing & replacing steering wheel? little helps please
    • Posts 17,888
    Get the steering wheel so the spokes are at 12 and 6 o'clock,take a small jewellers type of screwdriver and push it into the hole in the back of the spoke right next to the hub,when you feel it catch on something lever it outwards and that side of the airbag should pop out,repeat with the other side.
    The big nut in the middle is either a Torx T50 or XZN M12,do not try to use any other type of tool otherwsie it'll end in tears.Unplug everything,make a note of any punch marks near the splines to get the wheel lined up again,and when the wheel is off don't turn the black plastic housing with the ribbon cable coming out of it.This is the clock spring housing that has to be in the same position when the wheel goes back on again,it may be a good idea to put some tape on it to hold it in that position.
  • Sun, Jul 5 2009 10:48 AM Re: removing & replacing steering wheel? little helps please
    faisal_16
    • Joined on Tue, Feb 28 2006
    • Posts 2,401
     Chris, I'm pretty sure it#s a T55 rather than the T50 that you need?
  • Sun, Jul 5 2009 12:38 PM Re: removing & replacing steering wheel? little helps please
    • Posts 17,888
    faisal_16:
    You're probably right as I did it from memory,it's the largest one in my set which is almost certainly a #55Embarrassed.
  • Tue, Jul 7 2009 6:31 AM Re: removing & replacing steering wheel? little helps please
    zaine
    • Posts 260
     right ok thanks
    what about the battery, how long should i leave it before and after removing / re-fitting?
  • Tue, Jul 7 2009 6:56 AM Re: removing & replacing steering wheel? little helps please
    bouncerMk4
    • Joined on Mon, Apr 30 2007
    • Posts 3,035
     they say 1/2 hour so the capacitor has a chance to discharge
    2003 Mk4 TDi 130ish ps -
    2005 A3 SE 2.0TDi 140 ps (the wife's!!)(but mine from Monday) - (but she didn't say which Monday
    I'm VAGnostic - thank God
  • Tue, Jul 7 2009 6:59 AM Re: removing & replacing steering wheel? little helps please
    faisal_16
    • Posts 2,401
     Yeah half an hour before you remove the steering wheel but you can re-connect it immediately after fitting the new airbag
  • Tue, Jul 7 2009 1:09 PM Re: removing & replacing steering wheel? little helps please
    • Posts 17,888
    bouncerMk4:
    Eh,what capacitor? I always unplug airbags immediately after disconnecting the battery and have never had any problems.
  • Tue, Jul 7 2009 1:14 PM Re: removing & replacing steering wheel? little helps please
    Chris1.8T
    • Joined on Wed, Nov 21 2007
    • Posts 2,415
    zaine:
     right ok thanks
    I don't think there's any specific time. I disconnect the battery, then go and make myself a cup of tea. By the time I've finished the tea - it's time to crack on with the job. Yes
  • Tue, Jul 7 2009 3:13 PM Re: removing & replacing steering wheel? little helps please
    faisal_16
    • Posts 2,401
     I thought you disconnected the battery to prevent an airbag warning light from appearing on the dash?
    Having said that though, I was warned that removing the airbag from it's clips without actually disconnecting the wires, with the battery still connected was dangerous..
  • Tue, Jul 7 2009 3:29 PM Re: removing & replacing steering wheel? little helps please
    • Joined on Mon, Apr 9 2007
    • Posts 13,106
    faisal_16:
    Can we get something straight here? Has anyone ever had an airbag go off when you disconected it? Didn't think soHmm
    Done this job many time with the battery conected and guess what? They haven't gone off.
    R-Tech Powered
    Sad people complain about sigs,get a life.
  • Tue, Jul 7 2009 5:10 PM Re: removing & replacing steering wheel? little helps please
    • Posts 17,888
    Patch:
    faisal_16:
    It's one of those classic urban myths handed down from father to son.You can quite safely disconnect the airbag(s) with the battery still connected and nothing will happen unless you turn the ignition on,when it will record a fault condition of "airbag not detected" or similar that is only a warning light and nothing more,and can be switched off by plugging in a diagnostic tool.
    An airbag can't be set off from the airbag itself unless we put the required voltage down the almost microscopically small female connectors in its plug,but it's always a good idea if using any sort of power probe in a car to avoid yellow or orange taped looms that are normally associated with safety restraint systems.
  • Wed, Jul 8 2009 2:58 AM Re: removing & replacing steering wheel? little helps please
    bouncerMk4
    • Posts 3,035
     still not risk a mouthful of airbag thankyou - myths sometimes have a habit of biting you in the arse!
  • Wed, Jul 8 2009 3:32 AM Re: removing & replacing steering wheel? little helps please
    peace1969
    Golf IV V5 2.3 10v 150PS
    • Joined on Sun, Sep 25 2005
    • Posts 2,252
    Bora Vents & Bora Sport Clock
    US Spec R32 Tail Lights
    W8 Light Blue Leds
    VCDS 908.1 key Usb & Vagtacho 2.5
  • Wed, Jul 8 2009 5:12 AM Re: removing & replacing steering wheel? little helps please
    richwig83
    Golf V Sport 1.9 TDI 105PS
    • Joined on Tue, Oct 16 2007
    • Posts 7,722
    Disconnecting the battery also makes sure you don't cause a fault code by turning the ignition inadvertently... i did it just as a precautionary measure!
    CLICK FOR STOCK-MOBILE
    :: 169bhp rattle wagon ------ mk4 r32, mk5 GTI or B5 S4?? ::
    :: Flickr::
  • Thu, Jul 9 2009 4:03 AM Re: removing & replacing steering wheel? little helps please
    zaine
    • Posts 260
     i've never heard of an airbag going off either, was more thinking of fault codes
    some good info on this site, i like it alot Big Smile
