Awesome GTI Store
uk-mkivs » Technical Community » VAG Diagnostic Software Discussion » Vagcom / Pc help please!!!!
Last post Sat, Jul 4 2009 7:32 AM by Stevee. 13 replies.
Page 1 of 1 (14 items)
  • Fri, Jul 3 2009 3:48 AM Vagcom / Pc help please!!!!
    Stevee
    • Joined on Mon, Jul 9 2007
    • Posts 2,210
     I have a genuine vagcom cable bought off a friend of mine and mkivs member. I had to buy a Serial to USB lead.
    Before registering with vagcom i did the test and it recognised my ECU and would connect fine.
    A month later i have bought vagcom, now when i try to connect it to the car, it says interface not found!! I cant see anything that has changed in that time.
    Im thinking that (even though i installed it before) that there is a problem with the driver of the USB to Serial lead. Ive done tons of searches and cant seem to get an answer, and any driver i try to download is on chinese sites!
    I did some checking and ive made sure that vagcom and the USB are on the same COM - Com3, And changing the COM's make any difference.
    Anyone had this before or any ideas what to do? Pulling my hair out here as i have airbag lights i need to get rid off! Not really great with PC's either so any help appreciated.
    Audi A4 Tdi 100 - Remap 135bhp
    Daily = Vw Caddy VCDS registered
    A4 Buying / Common Faults Guide
  • Fri, Jul 3 2009 4:02 AM Re: Vagcom / Pc help please!!!!
    azzle123
    • Joined on Sat, Feb 24 2007
    • Posts 7,653
    When you go to device manager, is there any 'items' with a yellow trianlge beside them?
  • Fri, Jul 3 2009 4:22 AM Re: Vagcom / Pc help please!!!!
    Stevee
    • Posts 2,210
     There is yes....does that mean its the driver?
  • Fri, Jul 3 2009 5:06 AM Re: Vagcom / Pc help please!!!!
    azzle123
    • Posts 7,653
    There's an issue with the driver.
  • Fri, Jul 3 2009 5:15 AM Re: Vagcom / Pc help please!!!!
    josh494949
    • Joined on Wed, Nov 21 2007
    • Posts 3,155
    if you pm me your email, ill send you my driver if you havent got one
    wont be till later today though
    I built it and ill destroy it
     Had enough thread
    Stevee
    • Posts 2,210
     Does anyone know where i can get a driver online for a Serial to USB?
  • Fri, Jul 3 2009 5:41 AM Re: Vagcom / Pc help please!!!!
    azzle123
    • Posts 7,653
    This is where I have always got mines, this one always works...even on xp x64, vista and vista x64 Yes.
    http://www.serialgear.com/USB-Serial-adapter-drivers-windows-mac-linux.cfm
  • Fri, Jul 3 2009 6:21 AM Re: Vagcom / Pc help please!!!!
    Stevee
    • Posts 2,210
    Thanks for that.
    I Uninstalled the previous driver, re-inserted the USB lead and it came up as new hardware found.
    Then downloaded your driver azzle and installed it. It told me to restart the PC.
    After restarting, and looking at the ports, there is still a errror triangle. the new driver appears and also a microsoft driver. Which it has automatically chosen. I cant select the other driver, and when i press to update the driver from files already on the pc it says that I already have the most upto date - the microsoft one!!!!!! aaaaaahhhh
  • Fri, Jul 3 2009 10:46 AM Re: Vagcom / Pc help please!!!!
    Stevee
    • Posts 2,210
     Anyone know why this driver wont load?
  • Sat, Jul 4 2009 5:34 AM Re: Vagcom / Pc help please!!!!
    Stevee
    • Posts 2,210
     bumpy
  • Sat, Jul 4 2009 5:49 AM Re: Vagcom / Pc help please!!!!
    azzle123
    • Posts 7,653
    What os are you using?
  • Sat, Jul 4 2009 6:07 AM Re: Vagcom / Pc help please!!!!
    Stevee
    • Posts 2,210
     Windows XP home
  • Sat, Jul 4 2009 7:27 AM Re: Vagcom / Pc help please!!!!
    azzle123
    • Posts 7,653
    Ok.
    What happens when you click 'roll back driver' for the item with the yellow triangle?
  • Sat, Jul 4 2009 7:32 AM Re: Vagcom / Pc help please!!!!
    Stevee
    • Posts 2,210
     "No driver files have been backed upto your computer for you to roll back"
