The rear bumper will, however you may need certain brackets. I did not use them though!
And yes the bumpers are a straight fit, also with the front and rear bumpers, your standard arch liners will not line up to the bumpers as the R32 bumpers are wider, you will need to buy the extensions!
I dont have the part numbers, you can find them if you do a search on here.
