just purchased my golf recently. it has a gamma tape player with a seperate cd player underneath. it also has a nokia phone kit installed. everytime i turn on the ignition, about 10-20 seconds later i get a beep which cuts my music off temporarily. i put this down to my nokia kit which i dont use, but im not realy sure if it is. i took my stereo and cdplayer out to see if i could disconnect the nokia kit, which im not sure if i can and i found there was lots of tin foil stuffed in there and the gamma unit was also wrapped in tin foil. when i took out the connectors from the back of the gamma unit i found that a yello wire had been bodged into the iso connector. the wire has its own free slot so it isnt bridged or anything, but this yellow wire then goes up to the back of my dash behind the steering wheel/clusters.
so i have a few quastions to ask which i will be very greatful if anyone could answer as im a little clueless
1. is there any reason why there should be tinfoil behing my dash and around the gamma unit?
2. what could this beep be?
3. what could this yello wire be?
4. can i get rid of the nokia kit?
5. i dont have a code for the radio, and i read on here that it will re code its self if it is the origional unit, which i think it is. is this true?
sorry for all the questions but i realy am clueless here.
thanks Dan
