uk-mkivs » Forum Main » uk-mkivs online shop » Thanks for purchasing!
Last post 24/07/2005 11:03 AM by Tabs. 0 replies.
Page 1 of 1 (1 items)
  • 24/07/2005 11:03 AM Thanks for purchasing!
    Tabs SystemAdministrator
    • Joined on 08/01/2002
    • Posts 20,153
    Thanks for purchasing from uk-mkivs. You order will be shipped on one of the designated shipping days.
    Please allow up to 21 days for your order to arrive.
    :: PLEASE READ ::
    The following is a small guide on how to apply the new design stickers. Please take note of this guide as we will not be liable for any refunds or exchanges of damaged/used stickers.
    1. Clean surface sticker is to be stuck on to. Normal glass cleaner or methylated spirit works well for this.
    2. If possible heat both the glass and sticker with a hair dryer - this will help the glue to bond. Don't worry if you can't do this however. You can use the rear sreen heater to heat the rear window if need be as well.
    3. Place sticker on flat surface and firmly press down on the sticker. This will help to ensure the lettering sticks to the removable strip part of the sticker, and not the backing.
    4. Peel hard backing from sticker. Do this very slowly starting from the top edge of the sticker (so you peel it from the top edge down), making sure that the vinly lettering is stuck to removable side of the sticker sheet. If any letters appear to stay stuck to the backing, roll the removable side back over and press firmly - repeat it necessary.
    5. With the sticker backing now removed you can place the sticker on the heated surface (glass). Starting at the left or right side, with your finger, slowly stick the sticker to the surface, smoothing the strip firmly as you apply to ensure there are not air bubbles etc.
    6. With the strip applied to the surface use a rag or cloth and rub over the strip to ensure the vinyl has bonded to the glass.
    7. Finally, slowly remove the strip from the surface ensuring the that vinyl lettering is stuck to the surface and not the removable strip.
    Thats it! Stand back and enjoy your new high visibility uk-mkivs / uk-mkvs sticker Yes
    The uk-mkivs team.
