replacing thermostat
9 replies to this topic
#1 moggie93
moggie93
  • 352 posts
Posted 12 January 2016 - 11:59 PM
I'm going to change the thermostat this weekend as the heater seems cold but when pushing on it gets warmer. Temp gauge always reads normal..
What's the best way to change it on a bkd engine?
#2 moggie93
moggie93
  • 352 posts
Posted 13 January 2016 - 10:33 PM
Just noticed that there is a sensor on the thermostat housing.
Should I replace it while changing the thermostat?
#3 gerrywac
gerrywac
    Hang on like this MKIV thing
  • 3310 posts
  • West Yorks
  • Golf Match 1.9 TDI 105PS
Posted 13 January 2016 - 11:40 PM
Thermostat shouldn't affect the heater as that's full flow, stat just affects flow to the rad
The temp sensor doesn't need changing unless faulty
Sent from my GT-S7500 using Tapatalk 2
#4 moggie93
moggie93
  • 352 posts
Posted 14 January 2016 - 12:25 AM
My reason for changing the thermostat is I think it's opening too early or possibly stuck open.. My communte from work is about 2 miles A road then onto the motorway. The heater is warm but nowhere near as warm as my tdi a4 was.Once I start pushing on with the revs up the heater seems so much warmer.The reason for changing the sensor,was I was in next to it..
Have you changed the thermostat on a bkd engine?
#5 NooNoo
NooNoo
    NooNoo
  • 8331 posts
  • Leicester
Posted 14 January 2016 - 05:28 AM
Stat absolutely affects coolant temp/heater.
It's the same coolant!
Normally you would only change the stat if the gauge was indicating low, but the gauge has a wide range indication for 90°C. Coolant can be anywhere between about 72°C and 95°C and still indicate 90 on the gauge. So it is possible the car is running below temp.
Buy a genuine stat.
BKD is the 1.9PD like my mums car IIRC. Those diesels are very thermally efficient and are prone to off temp running. Just looked, this is the 2.0...
#6 gerrywac
gerrywac
  • 3310 posts
  • West Yorks
Posted 14 January 2016 - 03:00 PM
I've read this and NooNoo's post and think I could have explained better. The heater heat exchanger doesn't have any control on the water flow so it will reach the same temperature as the rest of the water in the cooling circuit.
If the thermostat is stuck open it will take a long time for the water to heat up and if you're not driving with much load on the engine it may be running cool. As Noo Noo mentioned the dash temp gauge is strongly biased toward the central 90C indication (speculation is it is not to worry the driver if its slightly above or below) even if the actual  is a few degrees either way
If changing the stat doesn't resolve the heater problem
Heres extracts from the VW repair manual for a BKD Touran
[attachment=15386:N19-10001 Touran BKD cooling system.png]
[attachment=15394:N19-10003 Touran BKD thermostat.png]
Removing
  Note
Always renew seals and gaskets. –  Drain coolant → Chapter. –  Remove alternator →Rep. gr.27 –  Pull connector off radiator outlet coolant temperature sender -G83-. –  Pull coolant hose off connection.     –  Loosen securing bolts -4- of union -3- using T-bar and socket, 10 mm -3185- and remove using hexagon key extension, 5 mm -3249- and remove union -3- with thermostat -1-. –  Turn thermostat -1-1/4 turn (90 °) to left and remove from connection -3-. Installing Installation is carried out in the reverse order. When installing, note the following: –  Moisten new O-ring -2- with coolant. –  Insert thermostat -1- in union -3- and turn 1/4 turn (90 °) to right.
  Note
The brace on the thermostat must be almost vertical. –  Fit union -3- with thermostat -1- into cylinder block.   –  Tighten securing bolts -4- using T-bar and socket, 10 mm -3185-. Specified torque: 15 Nm. –  Replenish coolant → Chapter.
Hope this helps
#7 moggie93
moggie93
  • 352 posts
Posted 14 January 2016 - 03:32 PM
Massive thanks gerrywac. Thanks NooNoo.Hopefully it's an easy job and shouldn't take too long.
#8 Kyle_TDI
Kyle_TDI
  • 875 posts
  • Manchester
  • Golf IV GTI 25th Anni 1.9 ARL 150PS
Posted 26 January 2017 - 08:05 PM
Just out of curiosity, did this cure the problem?
My heater is also noticeably warmer when under load?
When i'm at the lights on tickover its almost cold, as soon as i set off it gets warm again??
Kyle
#9 doddy666
doddy666
  • 1743 posts
  • telford
Posted 28 January 2017 - 12:05 AM
Kyle
Does the temp gauge sit at 90 all the time once it's warmed up? If it drops in traffic you need a new GENUINE thermostat
Sent from my SM-G935F using Tapatalk
#10 robrs2
robrs2
  • 13 posts
Posted 15 April 2017 - 01:19 AM
Changed the stat on mine and made no difference. But i did find out that not having the A/C switched on stopes the aux heater working on the cooling system.
