It is about time I wrote this I think
Let's get this bit out of the way, you perform this mod at your own risk - if you screw your cluster up don't blame me! Only do this if you are confident you know what you are doing
Miles to empty on a VDO immobiliser 3 cluster - if you don't know which cluster you have then take a look at the cluster FAQ here and ask your questions on versions in that thread please :Y:
To use this guide you will need:
1. Connect up your cable to the laptop and car then with the ignition on run the Vagtacho software (VT)
2. If you know which cluster you have then you can skip this part and go to 3
Press Connect Any Tacho
VT will return the cluster info and from the part number and type you can tell if your cluster is VDO and immo 2 or 3 :Y:
Then click the disconnect button
3. Select VDO new from the ECU drop down list
And click on connect s elected ECU
VT will connect and return the following info
4. Reading the SKC code (PIN number)
Press the read PIN button
The SKC is returned by VT, to use in VCDS (Vagcom) put a 0 in front ie 03957
5. Reading the cluster eprom
Press the Read button in VT
When done File > Save
Save two copies of the file, one labelled original and one modified!!!
6. Editing the eprom
Close VT and open up the HEX editor XVI32 and File > open
Open the file you saved with the modified label [y]
To enable miles to empty the hex address $416 needs to be modified, in a standard cluster the value will be C1, to turn on MTE change the value to E1
Click on Address > Goto
Enter $416 in the box and make sure hexadecimal is s elected > OK
This will highlight the address value in the eprom file
Click on the address value and type in E1, the blue s election will then move to the right and s elect the next value but don't change this value.
If you make a mistake re load your file into the editor and start again :Y:
To enable lit pointers the value at address $1ED need to be modified, in your standard cluster it will be 30, the value is changed to 3X where x represents the value in the list below:
x value
3 - displays only
5 - gauges only
7 - displays and gauges only
9 - needles only
B - displays and needles only
D - Needles and Gauges only
F - all lit up
39 is the most common choice but feel free to experiment :Y:
Enter $1ED in the box and make sure hexadecimal is s elected > OK
Click on the address value and type in 3x, the blue s election will then move to the right and s elect the next value but don't change this value.
Once you have finished editing File > Save
Close the editor
7. Uploading the modified eprom to the cluster
Open up VT again and connect to the cluster as in steps 1 and 3 above
Click on File > Read file >
select your saved modified eprom dump and this will be loaded into the VT memory buffer
Click on write eprom
Click on continue and VT will write the eprom back to the cluster
Wait until Done
Click on options > Reset Tacho
And that is it, disconnect your cables :Y:
If you have any issues with the eprom write then you can try to put the original file you saved back onto the cluster, this is not always possible however and the cluster could end up dead
Hope that makes sense
Neil
Please, no discussions on where to obtain pirate \ illegal copies of software in this thread - I will delete any references I find, you have been warned :mellow:
- An immobiliser 3 VDO cluster
- Vagtacho software and cable (VT)
- A Hex editor, I am using XVI32 available here
x value
3 - displays only
5 - gauges only
9 - needles only
F - all lit up
Close the editor
Wait until Done
Neil
