2012 mk 6 tdi
6 replies to this topic
#1 alexmastin
alexmastin
  • 899 posts
  • Sunny Kent
  • Golf IV GTI 1.9 ARL 150PS
Posted 30 November 2016 - 06:09 PM
Hi a friend of my son has a 2013 tdi, think its the smaller 1600 engine.
She has taken and had it coded, they said its the e g r, bit of research by me and it looks like an awful job to do...Fitted on the back  of the engine now.
People are quoting 7 hours labour plus the part...
Not sure if its throwing any lights up or going to limp mode.
I suspect the occasional light maybe eml one.
Any thoughts people please.
 2002 Anniversary tdi, Bora vents, sun glasses holders, coil overs, built in sat nav.. 2001 Audi TT 225 BAM engine, Anni wheels, rear seat delete.  2010  Black Audi A 3 quattro Sport back,winter pack, park assist front and rear.
#2 FLAPPERJACK76
FLAPPERJACK76
  • 114 posts
Posted 30 November 2016 - 09:16 PM
Yep. Quite common. Book time is around 5.5 hours. Best way to replace it is remove battery and subframe and steering rack and dpf and osf driveshaft. Replace the egr valve /cooler assembly. Refit everything. No need for coding. Price has really come down on the part average price from the dealer's is £274 plus 20 % vat. Plus 5 or 6 or 7 hours labour depending on who you take your car to.
Sent from my SM-G900F using Tapatalk
#3 FLAPPERJACK76
FLAPPERJACK76
  • 114 posts
Posted 30 November 2016 - 09:19 PM
If you have full dealer service history you will probably be able to get some factory goodwill and may end up paying nothing.
#4 Chuck16
Chuck16
  • 81 posts
  • Cardiff
  • Golf V GT Sport TDI 2.0 140PS
Posted 01 December 2016 - 12:11 AM
Things like this makes me glad I got rid of my 1.6tdi cr and went back to the 2.0pd engine.
Mk5 1.9tdi R32 replica-Reflex silver..Mk6 Candy white Golf R-line replica 1.6tdi .. Mk5 GT 2.0tdi Ford Frozen white, Currently getting R32'ed 😆
#5 alexmastin
alexmastin
  • 899 posts
  • Sunny Kent
Posted 01 December 2016 - 01:57 PM
That's really disappointing, having had so many PD Golf's my next step was a newer on. I'll have to keep the anniversary one then. :dash2:
Thanks for the info everyone.
#6 gerrywac
gerrywac
    Hang on like this MKIV thing
  • 3194 posts
  • West Yorks
  • Golf Match 1.9 TDI 105PS
Posted 01 December 2016 - 05:18 PM
If you want a newer diesel there's no option as the late 4andsubsequent ones all have complicated EGR systems that do fail now and then.
A failure will likely raise an EML but shouldn't  cause limp mode or serious running issues.
Modern cars have a great deal of ancillary equipment and are tightly packaged which means that for some jobs a great deal of dismantling and reinstatement is needed to carry out the work and with labour costs as they are this means expense. This is one such job, another is the cambelt/tensioner/water-pump.
If is however not a particularly difficult job and any reasonably competent mechanic would have no difficulty undertaking it. As a DIY job you might also consider using second hand parts as the units are quit reliable, reasonably common and relatively inexpensive.
As flapperjack 76 indicated it might be worth approaching a main dealer about a "goodwill" contribution or even a free repair. Vw are often not as bad as is sometimes said, particularly with newer models. From personal experience however (with myMk5 ABS unit failure) there is a bit of a sting in a "Catch 22" scenario as VW insist on the dealer carrying out a full dealer diagnostic before they will consider goodwill and at dealer prices this is often £100 or so.
They will not accept third party diagnostics and often will not cover any or all of the costnand once this is factored in it might be worth  considering a good independent VW Specialist with lower diagnostic and labour charges
#7 alexmastin
alexmastin
  • 899 posts
  • Sunny Kent
Posted 02 December 2016 - 03:22 PM
Thanks for the input Gerrywac.
