mk5 sill dent
6 replies to this topic
#1 Bongo mk5
Bongo mk5
  • 12 posts
  • MACCLESFIELD
  • MKI Models
Posted 09 January 2017 - 10:47 PM
Hi somehow the o/s front sill on my mk5 has a dent , looks to be caused by a misplaced jack pad etc as it is inline with the arrow impression as to where the jack point is and a puck sized impression but have not pushed the jack under enough and jacked up on the sill  , Its not noticeable if stood looking but kneel down and its there , not super deep so the penny must of dropped before a total cave in , but big enough to super bug me now i know . I have tried the glue on dent pullers but its to solid and i had no joy but i will try again weather permitting .
I don't really want to grind off the stone chip and tack a bolt or anchor on to pull it out if can be helped . Does anyone know if i can gain access from inside the car before i rip the carpet and trim out to look myself , Is there ie a grommet so that i can knock it out from inside , thanks
#2 TomasLT
TomasLT
  • 1346 posts
  • northern europe
Posted 10 January 2017 - 08:26 AM
No, but you can cut the whole sill out, buy a replacement and weld it in.
#3 adam-
adam-
    K04-064'd 1.8t
  • 4877 posts
  • Glasgow
Posted 10 January 2017 - 08:59 AM
That is a lot of work!
facebook.com/adamforbes92
ig: adamforbes92
#4 TomasLT
TomasLT
  • 1346 posts
  • northern europe
Posted 10 January 2017 - 09:24 AM
It'll come to you eventually when your mk4 rusts away.
#5 adam-
adam-
    K04-064'd 1.8t
  • 4877 posts
  • Glasgow
Posted 10 January 2017 - 10:16 AM
It's begun. :(
ig: adamforbes92
#6 TomasLT
TomasLT
  • 1346 posts
  • northern europe
Posted 10 January 2017 - 01:29 PM
Hah, doesn't seem so different from a mk3 after all huh?
#7 Bongo mk5
Bongo mk5
  • 12 posts
  • MACCLESFIELD
  • MKI Models
Posted 11 January 2017 - 10:18 PM
All a bit extreme as its solid hence why i dont want to strip and weld a pull onto it , i was hoping there were access grommets internally .
