Mk4 Golf
Parts needed for 120k PD150 timing belt change?
18 replies to this topic
#1 Stonedofmoo
Stonedofmoo
  • 727 posts
  • Portsmouth, UK.
  • Golf IV GTI 1.9 ARL 150PS
Posted 16 April 2017 - 07:11 PM
Hi guys
Can someone remind me what I should be changing at the second timing belt interval.
Full timing belt kit including timing belt and tensioners
Water pump
Anything else?
My car's actually done 101k, but I'm going to be rebuilding the head anyhow so may as well start with a new timing kit.
PD230: Turbo Dynamics Stage 2 turbo, Bobby Singh remap. 230bhp/340lbs torque
#2 Thai-wronghorse
Thai-wronghorse
  • 1466 posts
  • Kent
  • Other Models
Posted 16 April 2017 - 07:13 PM
How about an auxiliary belt as well whilst it's off?
Sent from my SM-G930F using Tapatalk
#3 Thai-wronghorse
Thai-wronghorse
  • 1466 posts
  • Kent
  • Other Models
Posted 16 April 2017 - 07:14 PM
Don't forget the correct coolant seeing as the water pump is coming out.
#4 Stonedofmoo
Stonedofmoo
  • 727 posts
  • Portsmouth, UK.
Posted 16 April 2017 - 07:17 PM
Yep the latter I took for granted, but you're right about the aux belt, they are cheap as chips anyhow.
#5 northpole
northpole
  • 5687 posts
  • Suffolk
  • Golf IV TDI 1.9 AHF 110PS
Posted 17 April 2017 - 08:50 AM
Use a timing belt toolkit so you can lock the engine on tdc without it it can be done but the timing might jump a tooth or two.... meaning you'll be fiddling to get the timing back to what it should be.
Sent from my SM-G935F using Tapatalk
#6 brianpologti
brianpologti
  • 203 posts
Posted 17 April 2017 - 12:45 PM
Alternator belt tensioner , did the misses diesel when did the belts, not that much engine mount bolts ,
#7 Edvardo
Edvardo
  • 1233 posts
  • Aylesbury
  • Golf IV GTTDI 1.9 ASZ 130PS
Posted 17 April 2017 - 02:13 PM
I personally wouldn't renew the coolant unless it's really old. I just drained and caught most of what came out. Fairly rusty looking but topped it up with distilled water. Under a year since it was renewed when I did the heater matrix.
As np said lock the crankshaft and camshaft if possible too. I just made sure I didn't turn the camshaft. Takes a lot too shift it but mark it up just in case maybe.
You also might be looking at a new engine mount...
Edited by Edvardo, 17 April 2017 - 02:17 PM.
'Never test the depth of the water with both feet'
#8 Stonedofmoo
Stonedofmoo
  • 727 posts
  • Portsmouth, UK.
Posted 17 April 2017 - 03:14 PM
Excellent, cheers for the tips. yeah I'm looking at engine mounts now. Building my shopping list
Whole head will be coming out for this, performance cam going in after a skim & port/polish so I guess I'll have to ensure it's all aligned correctly when that goes in.
#9 Thai-wronghorse
Thai-wronghorse
  • 1466 posts
  • Kent
  • Other Models
Posted 21 April 2017 - 09:12 AM
I'm literally just pricing the bits up for mine.
Where did you get them in the end?
#10 Stonedofmoo
Stonedofmoo
  • 727 posts
  • Portsmouth, UK.
Posted 21 April 2017 - 09:14 AM
I've not bought them yet, but GSF said about £60 for the full set from a recommended brand, and £30 for the 'premium' water pump
Through this forum of course, they give excellent discounts.
#11 Edvardo
Edvardo
  • 1233 posts
  • Aylesbury
Posted 21 April 2017 - 09:44 AM
Discounts are big compared to what the mark up price is on their site but there's just as good to be had elsewhere. I like blue!
http://www.ebay.co.u...=STRK:MEBIDX:IT
SKF all the way!
#12 Thai-wronghorse
Thai-wronghorse
  • 1466 posts
  • Kent
  • Other Models
Posted 21 April 2017 - 10:04 AM
Are you replacing the vibration damper as well?
Edited by Thai-wronghorse, 21 April 2017 - 10:04 AM.
#13 Thai-wronghorse
Thai-wronghorse
  • 1466 posts
  • Kent
  • Other Models
Posted 21 April 2017 - 10:07 AM
Look at this on eBay http://www.ebay.co.uk/itm/262940828669
#14 Stonedofmoo
Stonedofmoo
  • 727 posts
  • Portsmouth, UK.
Posted 21 April 2017 - 10:08 AM
I would be looking to change everything that needs changing. Does that kit above include it?
Edit: Oh I see, typically mine is a crossover year so I'll need to get the engine number. Is that on the cam cover?
Edited by Stonedofmoo, 21 April 2017 - 10:09 AM.
#15 Edvardo
Edvardo
  • 1233 posts
  • Aylesbury
Posted 21 April 2017 - 11:36 AM
Oooooh they're a right pain apparently. Give 'em your reg hopefully it's not the hydraulic tensioner as above
#16 Thai-wronghorse
Thai-wronghorse
  • 1466 posts
  • Kent
  • Other Models
Posted 21 April 2017 - 11:47 AM
Is it a case of one type of tensioner or the other or do some engines have both of these fitted?
#17 Edvardo
Edvardo
  • 1233 posts
  • Aylesbury
Posted 21 April 2017 - 12:05 PM
One or the other. GSF or TPS will know which. Phone 'em up or use the chat box on the site
#18 Thai-wronghorse
Thai-wronghorse
  • 1466 posts
  • Kent
  • Other Models
Posted 21 April 2017 - 12:21 PM
I've just got a quote from Sere Seat parts and I asked about the tensioners and he said the hydraulic type were fitted on the 1.8t engines.
My link above says otherwise...
#19 Edvardo
Edvardo
  • 1233 posts
  • Aylesbury
Posted 21 April 2017 - 01:14 PM
Yeah that's wrong. You're right.
