Gearbox LSD inspection
7 replies to this topic
#1 sabk21
sabk21
  • 939 posts
  • Sunderland
Posted 21 April 2017 - 06:10 AM
Hi Guys
I'm going to have a look at a gearbox with a Quaife LSD installed. Is there a way of telling if the LSD is installed in the box without taking it apart?
#2 adam-
adam-
    K04-064'd 1.8t
  • 5328 posts
  • Glasgow
Posted 21 April 2017 - 06:42 AM
I wouldn't have thought so.
facebook.com/adamforbes92
ig: adamforbes92
Anthracite Grey 1.8t Build Thread.
#3 adam-
adam-
    K04-064'd 1.8t
  • 5328 posts
  • Glasgow
Posted 21 April 2017 - 06:43 AM
Unless you can fit it in minutes; do some sick two-tire fires and then buy it if it does.
ig: adamforbes92
#4 northpole
northpole
  • 5697 posts
  • Suffolk
  • Golf IV TDI 1.9 AHF 110PS
Posted 21 April 2017 - 06:44 AM
Nope you can't see it as it is in the box... you can only tell the difference at the amount of grip the car has compared to a non LSD car....
just saw you said you are looking at a box.... in that case the seller should have the receipt for the part and of course have the box open so you can see the LSD... if he doesn't want to open it but has the receipt  not to much to worry about, if he doesn't have the receipt.... well than it's box open
#5 Gti Fly
Gti Fly
  • 9524 posts
  • Golf IV R32 3.2 240PS
Posted 21 April 2017 - 08:20 AM
What about if u turn one the sides, then the other side would turn in same direction ?
<a href="http://uk-mkivs.net/...d-0-60-569secs/">Click for pics of my car</a>
#6 sabk21
sabk21
  • 939 posts
  • Sunderland
Posted 21 April 2017 - 09:55 AM
That's what i thought, that both flanges would rotate in the same direction if one is turned.
#7 adam-
adam-
    K04-064'd 1.8t
  • 5328 posts
  • Glasgow
Posted 21 April 2017 - 10:14 AM
According to the internet, if there is no backlash then that won't happen. But it "should".
ig: adamforbes92
#8 sabk21
sabk21
  • 939 posts
  • Sunderland
Posted 24 April 2017 - 03:35 PM
Right, I've spoke to quiafe and they told me how to check if the box has an ATB diff in it. Need to remove the drive flanges and have a look though the diff, if there is a 5mm hole through it to the other flange it's an ATB diff. If you see cross pins then it's an open diff
