Engine management light
6 replies to this topic
#1 leeabr101
leeabr101
  • 492 posts
  • Manchester
  • Golf VI GT TDI 2.0 140PS
Posted 22 April 2017 - 12:28 AM
Took car in for its mot this morning and just needed a new tyre which was great. I then drove away and after a mile or so, the coil light started flashing and went into limp mode. Pulled over and restarted and it disappeared however about ten mins later it returned along with the engine management light.
Then after itd stood for a few hours, the EM light then came on but no limp mode and no coil light.
Im confused but no idea why all of a sudden my dash is lit up like Blackpool illuminations!
Im also concerned its because ive had the emissions update and then its happened just after its been through MOT testing conditions. Just seems a bit suss 🤔🤔🤔
#2 leeabr101
leeabr101
  • 492 posts
  • Manchester
Posted 22 April 2017 - 03:32 AM
Its the catalytic converter light thats on. Just drove home and no limp or coil warning, just the CC lamp
#3 leeabr101
leeabr101
  • 492 posts
  • Manchester
Posted 22 April 2017 - 06:35 PM
And after standing overnight its now gone off!
#4 Mmalkie
Mmalkie
    Dinny gees any o yir pash !
  • 1082 posts
  • Sunny Scotland
  • Golf VI BlueMotion TDI 1.6 105PS
Posted 05 May 2017 - 05:11 PM
THIS might be 'helpful'...
http://uk-mkivs.net/...t/#entry3270313
Have a look at post #12....
#5 gerrywac
gerrywac
    Hang on like this MKIV thing
  • 3428 posts
  • West Yorks
  • Golf Match 1.9 TDI 105PS
Posted 05 May 2017 - 07:18 PM
The ECU is constantly monitoring sensors to detect possible faults and depending on the severity that can raise engine management and emmiissons lights etc and in more severe cases trigger "limp mode".
Not all the lights will require to be re-set, less severe ones will go out once the fault clears so itis quite possible this is what has happened to yours.
If you have access to someone with VCDS or a code reader you could ask them to scan for faullts as they give a better idea of the fault. Codes are stored in memory, even when intermittent or non-current until such time as the memory is cleared.
#6 leeabr101
leeabr101
  • 492 posts
  • Manchester
Posted 07 May 2017 - 07:14 PM
It came backnon for a day the other day, no limp. Then disappeared again. Seeing how it goes but due cambelt change soon anyway so see what gets said during that
#7 Mmalkie
Mmalkie
  • 1082 posts
  • Sunny Scotland
Posted 09 May 2017 - 09:55 PM
Is your wallet ready for that pain ???
OUCH !!!!!
