2.0tdi (110) engine management light and flashing glow plug light
4 replies to this topic
#1 Hayden777
Hayden777
  • 3 posts
  • Northern Ireland
  • Golf VI SE TDI 2.0 110PS
Posted 15 May 2017 - 12:11 AM
Hi, I recently bought a 2009 2.0tdi (110) golf and today the engine management light came on and the glow plug light has been coming on when I've been on the motorway hitting over 2000 revs. The glow plug light goes off when I stop and restart the car but the engine management light stays on. I suspect it has something to do with the EGR and/or DPF and I will get the codes read as soon as possible and post them. However the car has been sitting for the past 5 months before I bought it and I've only had it 2 days and I was wondering if this may be the cause of the problem. Could the engine be running slightly inefficiently and there's been a build up of soot in the DPF due to the lack of miles the engine has done recently. I've read that a good long drive on the motorway can help clean out the DPF but I'm concerned about doing this because of the additional glow plug warning light that appears when I am driving on the motorway over 2k revs.
Any advice would be greatly appreciated and I will post the codes once I get them.
Thanks.
#2 grit
grit
  • 135 posts
  • herts
  • Golf VI SE TSI 1.4 122PS
Posted 17 May 2017 - 02:27 PM
hi Hayden 777
I cant be much use as I have tsi petrol golf but did you say you just purchased this car if so was there any warranty ?
grit
Grit 122 tsi
#3 adam-
adam-
    K04-064'd 1.8t
  • 5299 posts
  • Glasgow
Posted 17 May 2017 - 02:31 PM
Either get it scanned right away or get it on the motorway for an hour over 2k.  If you don't, the DPF will clog and you'll been to fork out a lot.
facebook.com/adamforbes92
ig: adamforbes92
Anthracite Grey 1.8t Build Thread.
#4 Hayden777
Hayden777
  • 3 posts
  • Northern Ireland
Posted 17 May 2017 - 02:32 PM
No there was no warranty because it was bought from a private seller. I've since had the codes read and it was: 16785/P0401/001025 - Exhaust Gas Recirculation (EGR) System: Insufficient Flow Detected. Which basically means the EGR valve is blocked or faulty
#5 Hayden777
Hayden777
  • 3 posts
  • Northern Ireland
Posted 17 May 2017 - 02:52 PM
Anybody know how likely it is that it's just blocked rather than faulty. I can get it professionally cleaned for about £100 but a new EGR is £140 alone plus labour. It's easily accessible on the 2.0tdi unlike the 1.6 but still probably £250+ all in.
