Outside door handle fault or module?
15 replies to this topic
#1 jamesm86
jamesm86
  • 1579 posts
  • South Hampshire
Posted 18 June 2017 - 09:19 PM
Hi, my N/S/F and O/S/R Doors are not opening from the outside correctly,
When i unlock them i have to pull the handle twice to get them to open.
The front one seems to sometimes take 3 pulls and will sometimes release a bit and get stuck then pull again to open all the way.
Is this a faulty handle or is this the control module playing up?
#2 Thai-wronghorse
Thai-wronghorse
  • 1466 posts
  • Kent
  • Other Models
Posted 18 June 2017 - 09:23 PM
The cables that attach to the outer door handle probably need adjusting.
They've more than likely got to much slack in them, it's easy to sort though.
Sent from my SM-G930F using Tapatalk
#3 adam-
adam-
    K04-064'd 1.8t
  • 5299 posts
  • Glasgow
Posted 19 June 2017 - 06:52 AM
Do the door pins lift?
facebook.com/adamforbes92
ig: adamforbes92
Anthracite Grey 1.8t Build Thread.
#4 jamesm86
jamesm86
  • 1579 posts
  • South Hampshire
Posted 19 June 2017 - 09:18 AM
Yeah pins are up fine.
#5 adam-
adam-
    K04-064'd 1.8t
  • 5299 posts
  • Glasgow
Posted 19 June 2017 - 09:40 AM
Sounds like the cable has stretched then. It's on a little ridge and can be adjusted. Remove the lock barrel with one T20? torx and tighten the cable. You'll see how to when it's out.
ig: adamforbes92
#6 jamesm86
jamesm86
  • 1579 posts
  • South Hampshire
Posted 19 June 2017 - 09:43 AM
Ok ill give that a go when i get 5
#7 Mmalkie
Mmalkie
    Dinny gees any o yir pash !
  • 1082 posts
  • Sunny Scotland
  • Golf VI BlueMotion TDI 1.6 105PS
Posted 19 June 2017 - 09:05 PM
Piece of urine !
Follow pic 17 thru to 23...
http://forums.vwvort...ead.php?1015107
#8 jamesm86
jamesm86
  • 1579 posts
  • South Hampshire
Posted 19 June 2017 - 09:12 PM
Piece of urine !
Thanks for that, now i can see how easy it is
#9 Adam_Jonezy
Adam_Jonezy
  • 697 posts
  • Preston, Lancs
  • Golf IV TDI 1.9 ATD 100PS
Posted 20 June 2017 - 05:56 AM
Thanks for this 👌
Mines literally started doing this the last couple of days
#10 northpole
northpole
  • 5688 posts
  • Suffolk
  • Golf IV TDI 1.9 AHF 110PS
Posted 20 June 2017 - 11:00 AM
i slackend mine on purpose it keeps thieves away thinking they haven't managed to unlock the doors i also de-locked both the front doors. well the inside of them spins around but i've taken the metal bit away so they will literally have to take the complete barrel out just to be faced by a glued block plate.
#11 NooNoo
NooNoo
    NooNoo
  • 8411 posts
  • Leicester
Posted 20 June 2017 - 01:30 PM
The glued block plate is a pain when relearning the remote function on fobs.
:Y:
#12 jamesm86
jamesm86
  • 1579 posts
  • South Hampshire
Posted 20 June 2017 - 03:08 PM
So i have adjusted the cable. Very easy to do buy something went clunk and my handle is loose and doesnt sit flush with the blanking cap. Any ideas?
#13 jamesm86
jamesm86
  • 1579 posts
  • South Hampshire
Posted 20 June 2017 - 03:30 PM
Ignore the last post. Sorted i out.
#14 Thai-wronghorse
Thai-wronghorse
  • 1466 posts
  • Kent
  • Other Models
Posted 20 June 2017 - 09:33 PM
Did you have the torx bolt tightened up on the blanking / lock cylinder as I discovered that if it's not tightened up when testing the handle it can catch inside in the rotating plate that retains the cylinder.
#15 jamesm86
jamesm86
  • 1579 posts
  • South Hampshire
Posted 21 June 2017 - 06:15 AM
No while the blank was out i somehow managed to knock the handle out from it retainer tabs. Was a bit fiddly to get it back in but its working a treat now
#16 northpole
northpole
  • 5688 posts
  • Suffolk
Posted 21 June 2017 - 06:30 AM
:Y:
i got software for that ;) takes me 2 min. to add a key including adding the fob ;)
