MK4 Golf and Bora Speedo \ Instrument Cluster - Page 37 - FAQ Forum - uk-mkivs
1102 replies to this topic
#1081 old_n07
old_n07
    Diesel isn't a dirty word
  • Technical Contributor
  • PipPipPipPipPipPip
  • 11030 posts
  • North Staffs
Posted 19 September 2018 - 06:04 PM
Are you following the correct coding instructions as yours will be an immo2 to immo3 swap?
https://uk-mkivs.net...immo3-upgrade/
#1082 Sandus
Sandus
  • 10 posts
  • Denmark
Posted 21 September 2018 - 03:29 PM
Currently trying with that guide, just not sure we have the right Soft code numbers from the old speedo as it's half dead and we can't get much data from it.
would the CAN Gateway soft code unchanged from the new speedo result in us being unable to "speak" with the canbus?
#1083 Wazzzer
Wazzzer
    Hang on like this MKIV thing
  • 2718 posts
  • Isle of Wight
Posted 21 September 2018 - 07:21 PM
If you can send me both eeproms from the new and old clusters I can try to merge them so the eeprom for the new cluster should be plug and play when you load it back on...
#1084 iwcham1979
iwcham1979
  • 19 posts
Posted 28 October 2018 - 12:58 PM
Hi guys, if i can ask a question for a sister car?! Can I retrofit the Maxidot cluster to my VRS, which doesnt have it? Will I require the satnav MFD unit as well (I currently have Skoda simphony)? Olso, the one I found is from a BLB engine Vrs (which is only an ASZ with minor modifications to make it Euro 4 compliant). Mine is ASZ ? Does it matter? Apart from the coding job, will I require any other modules and so for it to work fully? My Fabia is decembar 2004 prod. date... Thanks guys! Cheerrz!
https://www.ebay.co....353.m1438.l2649
#1085 extra-ordinary_
extra-ordinary_
  • 43 posts
  • Bora Sport 1.9 ASZ 130PS
Posted 11 July 2019 - 07:04 PM
If there's anyone still reading this thread...and apologies if it's been asked before as I haven't read all 37 pages but...I'm replacing my 1J5920926C (MFA) instrument cluster with a 1J5920946C (FIS) off €bay. I've gotten the PIN off my own cluster, will I be able to get the PIN from the new cluster by just plugging it in?
#1086 gazman70
gazman70
  • 192 posts
  • Newton Stewart,South West Scotland
Posted 11 July 2019 - 07:14 PM
Aye
#1087 mur3633
mur3633
  • 202 posts
  • Podgorica, Montenegro
  • Golf IV GTTDI 1.9 AJM 115PS
Posted 12 July 2019 - 08:40 AM
Yeah, but you'll need VAGTacho or VAG Commander.
#1088 adam-
adam-
    VR6 GT35 4mo
  • 10779 posts
  • Glasgow
Posted 12 July 2019 - 08:54 AM
Well if he managed to read the old cluster...
  • mur3633 likes this
#1089 extra-ordinary_
extra-ordinary_
  • 43 posts
Posted 13 July 2019 - 12:17 PM
Aye
Grand...thanks.
#1090 extra-ordinary_
extra-ordinary_
  • 43 posts
Posted 15 July 2019 - 11:02 PM
Got the cluster swapped today and I'd hoped for better - I can hardly read the display and this photo was taken in the dark! Also the new cluster was taken from an auto so I think it has the bottom line reserved for gear indicator? Do I need to write a standard manual FIS eep to it and does anyone know what the contrast issue with the display is? I thought the whole display went dim not the actual characters.
#1091 Earl_C
Earl_C
  • 271 posts
  • Shropshire
  • Other Models
Posted 16 July 2019 - 12:26 AM
Looks like a goosed display, the lines seem to hold better.
I guess you have VCDS, run an output test on the cluster and it will do segment tests as part of the outputs, will show you how bad it is.
As for the auto, yup, fairly sure its just an EEPROM swap needed
Amateur build thread : https://uk-mkivs.net...-green-machine/ Now deceased, see here for parts  https://uk-mkivs.net...howtopic=649256
Crisis Car: https://uk-mkivs.net...er-life-crisis/
 As Dan FR once said "If you don't like the answers you get, don't let the door hit you on the way out"
#1092 extra-ordinary_
extra-ordinary_
  • 43 posts
Posted 16 July 2019 - 09:53 PM
Thanks. I'm getting an error with VCDS for instruments but I'm presuming this is the auto looking for it's connection to the autobox -
1 Fault Found:
01315 - Transmission Control Module
            49-00 - No Communications
I ran a segment test and didn't see any response from the display.
#1093 gazman70
gazman70
  • 192 posts
Posted 17 July 2019 - 08:59 AM
It would be easier if you could get hold of a appropriate bin file for the cluster and flash it on using eeprom programmer i have a good bin file for half fis but that's no good to you.
#1094 dasmans
dasmans
  • 1 posts
  • Latvia,Riga
  • Golf IV 1.6 16v BCB 105PS
Posted 08 October 2019 - 03:58 PM
Hi guys!
1st off all- sorry for bad english  :blush:
So i have a golf mk4 1.6 fsi with VDO immo 3 cluster, and i want to swap in cluster from my donor car, which also is VDO immo 3, but it has disel rpm gauge.
Reason i want to swap them- the one from the disel has Full FIS display  B)
I have VCDS 12.12 genuine cable, and vagtacho cable is on its way.
Is it posible to make the disel cluster work on my car?
Vcds and vagtacho is enough to make it work?
I know that i will need to programm the immobiliser, swap the gauge faces, but i do not understand Nothing about the ""eeprom" thing...
Basically- Can it be done?
                And someone pls explain smth about eeprom  :D
Thanks in advance- Tom
#1095 locarno
locarno
  • 630 posts
  • Poland
  • Golf IV 1.6 16v SE AUS
Posted 12 April 2020 - 09:15 AM
1j5 920 842a is immo2 or 3 ?
#1096 Neutron
Neutron
  • 883 posts
  • West Sussex
Posted 23 April 2020 - 02:48 PM
I know this is a thread mainly about swapping clusters, I've read most of the 1095 posts too :) but I have a faded MFA LCD in my 4motion
Motometer/Bosch 1J0 920 926 A, RB8 V52
I'm wondering if there's a source for a quality replacement Half FIS/MFA LCD display to DIY ( I'm OK with solder re-working) on these - I've looked pretty hard but can only find LCDs for the RB8 fitted to later Audi A4s (I don't think they are the same or are they?) and most "dash cluster fix" business seem to only cater for the VDO versions of Mk4 dashes. tbh I'm being a bit tight on this - being a nearly 20 year-old car I'd rather not spend 10% of the cars value sending the dash to the pros :)
I would swap to a Bora Sport VDO cluster if I had the SKC but these RB8s are a pain to retrieve it from - currently investigating ArgDub's ME7 EEPROM tool to see if I can pull it from the ECU binary dump instead, but if anyone knows of the best way to get a SCK out of one of these clusters without bricking the electronics I'm all ears!
#1097 adam-
adam-
    VR6 GT35 4mo
  • 10779 posts
  • Glasgow
Posted 23 April 2020 - 04:38 PM
K-commander will pull the SKC and the EEPROM can be pulled from the ECU with ease.  I've got an RB8 cluster that I pulled from my 4mo that is taking up space - no-one will use it because it's an RB8 so it's good enough for the bin.  If you want it to butcher, give me a holler.
  • Neutron likes this
#1098 Neutron
Neutron
  • 883 posts
  • West Sussex
Posted 23 April 2020 - 08:09 PM
cheers @adam- I have a knock-off K+CAN commander 1.4 cable from years ago but lost the software in a clear out, I think a newer version might be needed to work though. Didn't have much luck today with the EEPROM tool but have changed the adapter baud rate to 10400 and will give it a go tomorrow. I may tap you up for the old cluster but I'm on a mission to make this work now ;)
#1099 adam-
adam-
    VR6 GT35 4mo
  • 10779 posts
  • Glasgow
Posted 24 April 2020 - 07:37 AM
10400 is usually fine.
Should be CD'ing to the correct folder and then: me7eeprom --OBD 95040 -rp1 95040_022906032BG_0004_immoon.bin
It'll save in the folder where me7eeprom is stored. I tend to collect them by their part numbers because I do so many.  If it doesn't work, let me know.  I've also got k-commander 2.5 (which works well) on my Google Drive if you need a copy.
#1100 northpole
northpole
  • 9925 posts
  • Suffolk
Posted 24 April 2020 - 07:49 AM
you can download that software for free from several sources... just do a quick google search and download it ;) and it works with the old K-line vagcom cables also i found this out by mistake but it was a bit slower ;)
#1101 Neutron
Neutron
  • 883 posts
  • West Sussex
Posted 24 May 2020 - 01:11 PM
Just a quick report back - managed to get the skc from the cluster EEPROM with K+CAN commander 1.4 using the VCDS dumb k-line cable. It couldn't talk to the ECU EEPROM though as I was going to grab that binary for a backup - also managed to trigger the air bag fault code but VCDS sorted that without bricking the module.
Thanks for your help and offers of assistance all!
#1102 gazmc
gazmc
  • 2 posts
  • durham uk
  • Mk4 Models
Posted 19 November 2020 - 08:31 PM
hi all know its an old thread but hoping someone still reading. I need new clocks {and ecu ect} mine are 1j920926B VDO two questions what does the B mean if Ameans petrol and C means diesel ??? I have a 02 tdgti and will any clocks with a 6 on end work {diesel ones} and which ones would be best to fit
#1103 fv1200
fv1200
  • 952 posts
  • Bristol BS16 7AE
  • Golf IV GTTDI 1.9 ASZ 130PS
Posted 19 November 2020 - 11:04 PM
1Jxxxx926C is what you need for a diesel
