[Mk4 Golf] Clutch peddle problems - Clutch and Gearbox - uk-mkivs
Mk4 Golf
7 replies to this topic
#1
  • Validating
  • 6 posts
Posted 17 January 2003 - 07:21 AM
Hi,
I jumped into the golf this morning, pressed the clutch to engage a gear, to find that the peddle has no resistance, and just flops to the floor.
I haven`t noticed any fluid leaks recently, no patches on the drive, can the fluid accumulate inside the engine bay. the cars barely 18 months old, and its been one problem after the other so far with it. (I thought my fiat coupe should be the unreliable one!!)
Any ideas on what it could be ? is this a common fault ?
Gurmon,
By the way nice forum, been following posts for the past few months
#2
  • Validating
  • 194 posts
Posted 17 January 2003 - 07:27 AM
Were you still able to s elect a gear ?
#3
  • Validating
  • 6 posts
Posted 17 January 2003 - 08:22 AM
Yeah, I can get it into gear, but not when engine is running. I intend to bleed the system, i just hope it isn`t a faulty slave cylinder.
It has the 6-speed box, not sure if this matters though. [:(]
#4
  • Validating
  • 6 posts
Posted 17 January 2003 - 11:03 AM
Had this problem on a VR6 gear box.
Clutch pedal went to the floor, so had to pump it to get it back to normal. Wasn't very helpful when you couldn't change gears when moving off or slowing down.
Bled it a couple times, in the end, changed the slave cylinder, and it was fine again.
#5
  • Validating
  • 6 posts
Posted 18 January 2003 - 02:37 AM
Cheers, tried bleeding it all morning, right looks like a new slave cylinder then [V][V] not very happy.
oh well, [:(!]
#6
  • Validating
  • 24 posts
Posted 02 February 2003 - 03:55 AM
Seen this on a few TTs, and the pedal has just stayed on the floor when pressed, and seems to only do it in very cold weather.
Some times it was okay again after we had lifted the pedal back up, but on most have had to replace either the master or slave cyliders.
#7
  • Validating
  • 8 posts
Posted 05 February 2003 - 12:00 PM
i have same problem on my anni in cold weather, only first thing though once warm its fine,
#8
  • Validating
  • 3 posts
Posted 12 April 2003 - 06:41 PM
if its only 18 months old, try to blag a free repair on the warranty[8D]
