[Mk4 Golf] how do i fit a gearknob!? - Clutch and Gearbox - uk-mkivs
Mk4 Golf
5 replies to this topic
#1
  • Validating
  • 6 posts
Posted 19 April 2003 - 06:58 PM
hey, ive just bought a gearknob from halfords, a £49 chrome one, looks the dogs, but im having a bit of diffecaulty putting in on.!
i mean how does the other gear knob come out ive no idea !
elp!
#2 Reflex TDI
Reflex TDI
    Hang on like this MKIV thing
  • 2786 posts
Posted 20 April 2003 - 12:05 AM
Can't help on fitting the Halfords jobbie.
To remove the VW one, prise off the gaiter surround, which is held in place by small clips at the front and rear. Pull the leather up over the knob[:I].
You will see a brass clip, which secures the knob within a recess on the shaft. Stick a screwdriver in this, and prise it open. The gearknob will then lift off.
#3
  • Validating
  • 2029 posts
Posted 20 April 2003 - 01:55 AM
I wasnt aware the Halfords etc knobs would fit, as they are screw on heads arent they??
#4
  • Validating
  • 35 posts
Posted 20 April 2003 - 10:37 AM
Chris is right. You will see a plastic "sleeve" which slides over the actual metal gear stick and which the brass clip holds the knob to the gear stick. There is also a plastic sleeve near the base of the knob which clips over a disc on the main plastic sleeve which holds the gaitor tight to the bottom of the knob. So basically if it isn't designed to fit a MK iV golf then you will probably have to resort to grub screws and you may have a problem making the gaitor fit neatly.
Sorry if this sounds confusing, but vw seem to have used an ingenious way to fix the gearknob, but it does a neat job.
I may be wrong there might be a satisfactory way to fit it, but i had a quick look not so long ago and decided the vw way was best.
Hope this helps.
#5
  • Validating
  • 6 posts
Posted 20 April 2003 - 03:09 PM
hey, well a quick word to my mate over at vw and he tells me thats u can fit it but it will take some work, have to use the clips and screws provided. but he did say however the tt gearknob will fit, so ill get that one off him :()
#6
  • Validating
  • 1 posts
Posted 08 July 2003 - 12:37 PM
Hi all
I have just got a MOMO gearknob from also from halfords, Doesn't screw on So it does fit and looks the dogs! But how do I get the gaiter of the old Knob? Or do I have to buy a new gaiter?
Many Thanks
