[Mk4 Golf] Diesel Geek quick shift fitted - Clutch and Gearbox - uk-mkivs
Mk4 Golf
1 reply to this topic
#1
  • Validating
  • 67 posts
Posted 04 August 2003 - 05:34 AM
I've now had a diesel geek quick shift fitted to mt TDI 150 for over a month now, say 2K miles. Fitting was relatively easy apart for finding the gear s elector locking pin for the final adjustment. In terms of driving the gear s elector is definatly shorter in both directions. The feel is more notchy and has lost refinement over the standard shifter. Whilst driving quickly over A roads the shifter is much improved, with less chance of missed gears, but round the town the 1st and 2nd gear changes are harder to work and add to driver fatigue. Overall I'm pleased, but you must be aware that the changer has pros and cons. I will keep you informed regarding durability over the next months.
#2 Reflex TDI
Reflex TDI
    Hang on like this MKIV thing
  • 2786 posts
Posted 04 August 2003 - 06:18 AM
Wakaday
As you know this follows on from the topic we ran a while back;
http://www.uk-mkivs....p?TOPIC_ID=9014
I agree with your opinion - it is not perfect but is much better on a blast and I forgive it's failings at slow speed in town, where it is noticeably poorer for me too. I slightly over-tightened one of the bolts and caused a tear in the rubber bushing of the left-hand gear s elector. When I get around to it I will replace this bit which will hopefully show an improvement.
James
