Old - Guides Index - Pre Forum Move. Has Some Dead Links - D.I.Y Guides and How to Instructions - uk-mkivs
  • This topic is locked This topic is locked
62 replies to this topic
#1 old_n07
old_n07
    Diesel isn't a dirty word
  • Technical Contributor
  • PipPipPipPipPipPip
  • 11030 posts
  • North Staffs
Posted 27 February 2009 - 09:20 AM
I've been back as far as page 10 in this section and indexed the guides below, after that loads of the links and pictures are dead.
MK IV
Electrical
General
Crimping and Soldering - DIY Terminal tool - Testing
Understanding the charging system
Bora Vents
Wiring loom
Cruise Control
Foxy's Guide - Guide 2 - 1.8T loom
W8 Light
Wiring loom and W8 Install 1 - Install 2
Aircon Fan fix
Fix the Aircon fans on a climate equiped MK4
USB Socket
Installation in Ashtray
Aftermarket central locking
Retro-fit
Wiper stalk with MFD control
Retro-fit
Emergency unlock switch
Installation
Changing alternator
4Motion
Keys
Sync Remote - Coding with VCDS
Parking Sensors
Installation
Parrot 9100 install
guide
Manual aircon to climate upgrade
guide
Central locking - after market
Retrofit
Newsouth oil temp and volt guage install
Guide
Passat heated mirror switch install
Guide
A pillar pod + boost guage install (petrol)
Guide
MK5 tailgate wiring into MK4
Guide
CCM upgrade from 1J0 to 1C0 959 799B
Guide
Lighting
Headlight mounting tab repair
Angel Eye EL wire install
Rear interior courtesy light bulb change
Door Handle LED
Remove rear lights
HID Kit install
Joey Mod
Guide 1 - Guide 2
Headlight bulb Change
Boot light upgrade
Manual aircon bulb replacement
LED puddle lights
OEM Xenons
Rheostat Mod Guide 1 - Adapter + rheostat Guide 2 - Early to Late model Xenon upgrade
OEM Bora Xenons
Bora xenons with auto leveling retro fit
Hella Celis voltage reg
Replacement
Audio
Remove unwanted noise
Stereo upgrade
Choose and design a sub enclosure
Building a Sub Box
How to choose and install car stereo amplifiers
Changing MK4 speakers
Ipod in armrest (links to vortex)
MFD install + CD Changer move
Fibreglass pods
wheel arch sub enclosure
Interior
Window regulator
Repair guide 1 - guide 2
Aircon recirc flap motor
Removal and replacement guide (pics towards bottom of thread)
Clutch Pedal
Repair broken pedal - Clutch master cylinder replacement
Heated Seats
Element repair - Retro Fit - Installing Kufatec loom
Trim
R32 trim instal l (contains external links to Vortex)
Glovebox
Latch repair
Bora vent installation
Fitting guide 1 (external links) Guide 2 on Vortex Removing Bora Vents
Speedo
Cluster removal - Removal Video's - Chrome rings - cluster swap immo3 - Cluster upgrade
Gear knob
Beetle Turbo gear knob - Gear gaitor 1.6
LED alarm cap swap
Seats
Clunking recaro fix - Removal and dismantle - Rear Seat back
Black headlining
DIY Guide : DIY Guide 2
W8 Light
Colour coding
A pillar pod
DIY two guage pod
Bora boot lid trim removal and light fix
Removal
Arm rest
Retrofit
Dashboard
Remove the dash + dash trim
Fitting aftermarket guages
Guide
Steering Wheel Removal
Guide Guide 2
Door lock modules (from Vortex)
Removing the module : Repair
Boot lock micro switch
repair
Rear door locks
removal
Boot Popper Solenoid
Installation: Guide
Dash trim respraying
Guide
Changing indicator \ wiper stalk
Guide
Fitting seats fron a hatchback into estate
Guide
Audi TT shifter into Golf console mod
Guide
Exterior
Trim
Sharan Badge
De-badging
Spraying
Colour coding (Guide 1 - Guide 2 - Guide 3) - Bonnet - Front Grille - Paint info
Side skirt fitting
4Motion rear valance installation
Front bumper and grille removal Guide1 - Guide 2
De-locking : when it goes wrong [help]
Bora rear badge
Fitting Polo\Lupo 6N2 Stubby Mirrors
Mirror Housing
Bora GLi valance fitted to a Golf
Auto Dimming side mirrors
Installation
Front windscreen wiper mechanism
Replacement
Rear wash wipe
Repair - DIY washer repair
Boot lock
Removal (Golf)
Misc
DIY Stubby aerial
Chassis and Suspension
TT\R32 Quickrack + Subframe
Front ARB
Fitting 2WD
Fitting 4WD
Rear ARB
Fitting 4WD 1 - 4WD 2
Suspension Bushes
Front wishbone bush replacement - Powerflex Bush install
Coilover install
Bora 4motion - 2WD Paltform
Front wishbone 2WD removal
Lower ball joint removal
Dog Bone mount
Changing and poly bush upgrade
Engine + Gearbox
Vacuum Pipework
Turbo Pipework
Finding Boost leaks - Fitting a Samco kit
Throttle Body
Cleaning 1 - Cleaning 2
MAF
Clean1 - Clean 2 - Install
Forge DV
Installation Guide
TIP
Fitting Guide
Air filter swap
Video (Youtube)
Oil change (Pella oil extractor)
Video (Youtube)
Boost guage
Install - Install 2 - adjustment
Secondary air pump
Repair
Turbo upgrade KO3 to KO3S
Upgrade
Changing alternator
4Motion
Timing belt
Change (PD Engine)
Auxillary Belt
Change (Petrol)
Gearbox removal and clutch change
Elsawin guide
Gearbox linkage adjustment
5 Speed
Clutch slave cylinder bleeding
Syringe bleeding
NOS
Fitting Guide
Sticking turbo vanes
How to cure
DSG Air intake
Installation
Temperature sender
Change 1 (1.6) Change 2 (AGU 1.8T) Change 3 (1.9PD) Video (1.9PD)
EGR
Allard Delete Pipe
Driveshaft
Removal and service - CV Boot Renewal
Lambda probe
Swap 1.6
Injector Swap (Diesel)
Injector Change
Clutch Change
DIY Style Clutch swap
Oil catch tank install
Petrol version
Camshaft change
PD engine | PD Guide 2
Vac line simplification on a PD diesel
Guide
Radiator change Tdi
Guide
Short shifter install
6 speed
Forge 007P DV service
Service
Audi R8 oil cap modification
To fit MK4
Exhaust
4Motion style tail pipes
Downpipe installation
Fitting a turbo back SS system
Brakes
Brake fluid change \ Pressure bleed
Guide 1
Painting
Guide1 - Guide 2
Discs
Rear disc swap R32
Pads
Changing front and rear pads - Rear Pads
Brake pedal switch adjustment
Rear caliper and sheild swap
Guide
Wheels
RC center caps
DIY Repair - guide 2
Servicing your wheels
Polished lip
External Links
Foxy's Web site
VW Vortex How to guides
Scottish Vag how to's
MK 5
Electrical
Multi Function Steering Wheel
Installation
MFD2 retrofit
Installation
Dension Ice link Installation
Installation
Exterior
Side Skirts
Fitting
Front end GTi, Gt or Jetta conversion
Swap
Carbon look grille badge
Mod
High level brake light replacement
Guide
Brakes
Brake Disc swap
Rear
Rear anti roll bar
Change
Interior
Gear knob
Change - Guide 2
Rear seat
removal
Neil
  • GTMonster likes this
#2 haf1zur
haf1zur
  • 8220 posts
Posted 27 February 2009 - 09:30 AM
nice one
would be handy to reference one for all
#3 Dent Reform
Dent Reform
    I live here
  • 13211 posts
  • MKI Models
Posted 27 February 2009 - 02:09 PM
Mods can we make this a STICKY please?????
Top work Neil and i know you have spent all day sifting through this instead of working [whistle]
Andy
#4 hotboy836
hotboy836
  • 9152 posts
Posted 27 February 2009 - 02:13 PM
love it
#5 ruebix
ruebix
  • 185 posts
Posted 27 February 2009 - 02:16 PM
Top work, that'll be really useful!
#6 s.g
s.g
  • 165 posts
Posted 27 February 2009 - 02:21 PM
excellent, top work
thanks very much.
#7 Chris.
Chris.
    Like A Bawwsss
  • PipPipPipPipPipPipPip
  • 25247 posts
  • Durham
Posted 27 February 2009 - 02:22 PM
Central Armrest Install Guide
Might want to add that to the awesome list.
Great work!
R-Tech Power 248bhp 275lbft - Gone But Not Forgotten
1.9T Forged Track Build Thread - TTE 420. Running 390bhp | 360lbft
#8 Antvw
Antvw
  • 1989 posts
Posted 27 February 2009 - 02:38 PM
Thanks, great idea! [y]
Ant
#9 old_n07
old_n07
  • 11030 posts
  • North Staffs
Posted 02 March 2009 - 01:35 AM
Great work!
Updated the first post [y]
Neil
#10 tre271
tre271
  • 985 posts
Posted 02 March 2009 - 01:53 AM
Fantastic! Thank you very much for doing that Neil.
#11 Ballesteros
Ballesteros
  • 613 posts
Posted 02 March 2009 - 02:23 AM
 Cheers for taking the time to do that.
#12 sb1967
sb1967
  • 167 posts
Posted 02 March 2009 - 02:41 AM
 very helpfull cheers[;)]
#13 old_n07
old_n07
  • 11030 posts
  • North Staffs
Posted 03 March 2009 - 01:35 AM
 Updated with the heated seat loom install [y]
Neil
#14 old_n07
old_n07
  • 11030 posts
  • North Staffs
Posted 09 March 2009 - 02:54 AM
 Updated
#15 Aidy310
Aidy310
  • 132 posts
Posted 06 April 2009 - 11:42 AM
Somebody Was Bored lol I was Looking For a how to clean Manifold guide but there must not be one lol
#16 GOOF72
GOOF72
  • 1310 posts
Posted 06 April 2009 - 12:10 PM
 Great post Neil[Y]
GOOF
#17 Foxy
Foxy
    Hang on like this MKIV thing
  • 3199 posts
  • Northants
Posted 16 July 2009 - 03:23 PM
Guys I have managed to find a free hosting service - you can see my website again, HERE
#18 Johnyd
Johnyd
  • 21 posts
Posted 20 July 2009 - 03:02 PM
Excellent web site Foxy great guides Thankyou !! :-D
#19 Johnyd
Johnyd
  • 21 posts
Posted 20 July 2009 - 03:05 PM
Sorry old No7 your how to's are the dogs danglies also
#20 brad1707
brad1707
  • 247 posts
Posted 16 September 2009 - 07:50 PM
can someone add this too it, its a guide on how to paint interior parts, just so i can find it when i need it... CHEERS
https://uk-mkivs.net/forums/t/72401.aspx
#21 Foxy
Foxy
  • 3199 posts
  • Northants
Posted 17 September 2009 - 05:36 PM
 Neil - my site link is out of date dude on your awesome list.
#22 old_n07
old_n07
  • 11030 posts
  • North Staffs
Posted 18 September 2009 - 02:57 AM
Updated [y]
#23 Gavin N.I.
Gavin N.I.
  • 504 posts
Posted 18 September 2009 - 04:20 AM
 Great Idea but some of the pics form the guides are missing and are vital tools for the guides??
#24 old_n07
old_n07
  • 11030 posts
  • North Staffs
Posted 18 September 2009 - 05:06 AM
That is due to the OP having moved or deleted the pics so nothing can be done really, you can try contacting them to see if they have them.
#25 old_n07
old_n07
  • 11030 posts
  • North Staffs
Posted 11 March 2010 - 07:14 AM
 Index updated
#26 haf1zur
haf1zur
  • 8220 posts
Posted 12 March 2010 - 05:42 AM
Please add this:
Syringe bleeding of the slave cylinder
http://forums.vwvort...read?id=4376420
#27 old_n07
old_n07
  • 11030 posts
  • North Staffs
Posted 12 March 2010 - 06:01 AM
Please add this:
Added it to the MK4 engine section Haf next to the gearbox bits [y]
Neil
#28 JoeMK4
JoeMK4
  • 4248 posts
Posted 19 March 2010 - 02:12 PM
 This page is great [Y] good work
#29 skimad4x4
skimad4x4
  • 268 posts
Posted 02 April 2010 - 01:16 PM
Hi Neil
Heres another one to add to this great resource -
Door lock micro switches (faulty soldering)
http://gruvenparts.com/website/diys/Door%20Locks%20Explained%20-%20MKIV.htm
SkiMad4x4
#30 old_n07
old_n07
  • 11030 posts
  • North Staffs
Posted 02 April 2010 - 02:34 PM
Hi Neil
SkiMad4x4
Cheers, it is already linked via Vortex [;)]
http://forums.vwvort...read?id=1542461
Neil
