How To: Install Kufatec Heated Seat Loom - Page 2 - D.I.Y Guides and How to Instructions - uk-mkivs
89 replies to this topic
#31 Jamie8954
Jamie8954
    Hang on like this MKIV thing
  • 2016 posts
Posted 21 January 2010 - 04:03 AM
anybody bought from Kufatec ?
i just registed an account and put my paypal password in etc but on my account on kufateci get Order number:3****3
(processing)
but no money has come up on paypal as coming out of the bank
does this mean they have to manually process it through later or something ?
#32 S11NY_P
S11NY_P
  • 811 posts
Posted 21 January 2010 - 07:21 AM
i just registed an account and put my paypal password in etc but on my account on kufateci get Order number:3****3 (processing)
Hi there,
I bought this last week and I made a payment via paypal no problems.
I dont no if there is a manually process as I followed though the steps on the website.
My loom I ordered came with in 2 days recorded delivery too with out anyproblems now fitted and well happy.
Suny
#33 Jamie8954
Jamie8954
  • 2016 posts
Posted 21 January 2010 - 07:22 AM
cheers mate
#34 bansal6
bansal6
  • 11 posts
Posted 06 February 2010 - 12:14 PM
i've treid to install it using this diagram with my own wiring, the seats are not heating up, power is going to the switches and they work in my mates car, but been thru it so many times but cant understand why they are not heating up, hel[p pls anyone
#35 josh494949
josh494949
  • 3981 posts
Posted 06 February 2010 - 12:20 PM
do a continuity test on your seats to make sure the elements havent gone
#36 bansal6
bansal6
  • 11 posts
Posted 06 February 2010 - 12:26 PM
 done it, everything seems to get power, except the wire 2 from the switches, and wire 3 from the switches  only had like 4 v going to it? ( both to the seats)
#37 bansal6
bansal6
  • 11 posts
Posted 06 February 2010 - 12:27 PM
 I mean to say, wire 2 from the switch to green connectore 4 has no power???!!! and wire 3 from the switch to green connectoer 2 has only 4.16v???? pls help, thank you
#38 Diesel Power
Diesel Power
  • 12 posts
Posted 22 February 2010 - 02:42 PM
Hi mate.
Thank you firstly for this SUPERB instructions. Flawless mate.
I bought the wires and seats 3 years ago and have been trying to find someone to fit it all these years. With no knowledge of electronics I managed to fit them on Saturday thanks to you in half an hour.
Thanks again. You are a legend
Regards
Antony
#39 loosebmx05
loosebmx05
  • 337 posts
Posted 12 September 2010 - 02:12 PM
 glad ive found this too ive been looking to fit the loom to my seats for ages now so the one from  Kufatec is about £60
did some one mention a retro fit loom from vw how much is this?
cheers
#40 mtbe
mtbe
  • 657 posts
  • Finland
  • Golf IV R32 3.2 240PS
Posted 19 January 2011 - 03:26 PM
I just bought kufatec`s loom as well (but with memory) You can see on heating switch which is left or right. I looked on manual and there is red and blue. Look those wires (they are gray but there is marking röt, etc)
Ig: _4lexi_
#41 cheshiresport
cheshiresport
  • 1085 posts
  • Cheshire
Posted 24 January 2011 - 05:40 PM
 Subscribed
Diesel gone - Replaced by 1.8T AUM, also got V6 4Mo project
242da524-2100-45c8-87e2-7e8b43082eb9_zps
#42 mrjonsavage
mrjonsavage
  • 225 posts
Posted 30 May 2011 - 05:41 PM
Ok peeps, time to put the VW Hive mind on this topic for a struggling novice...
Right, installed loom fine (double checked wires to which bits), switches light up (nice!) BUT no heat in either seat!
So, my question is basically how to do a good test of relevant bits with multi-meter etc...
(1) Testing seat heating elements: I imagine I need to do a continuity test so on the plug of the connector on the bottom of the seat there are 4 metal blades that fit into the female bit from the loom - any particular combo to test (1+2/1+3 etc etc [yes I know the wiring diagram is above but am a little lost on it!]).
(2) Testing the voltage/current coming from the loom at the female end where connectors to bottom of seat: again, which terminals to put me probes on for voltage (& what should it be about 12V or less?). Can I test the current, again which bit to do (& remember this is a ptential 15-20Amp line so gotsta be a bit careful as this could kick like a mule if I cock it here?!)
(3) Slightly off topic but may be related: I fitted cloth Recaros & had to do the classic cutting off the connectors as they were different types. Now I was very careful to try & connect up the corresponding leads to positions but looking at them again I have for passenger side: Brown to brown/blue to blue/white to black & for driver: brown to brown/white to blue/green to black - SO, have I ballsed up here on the latter & should have had it brown to brown/GREEN to blue/WHITE to black??? AND so could this be affecting my heating of the seats?
(& yes I have got a 'Airbag error' message & the seatbelt symbol is illuminated all the time but I think that was due to me reconnecting the negative lead to battery in error too early).
I iz scratchin' ma noggin in confusion on al the above so put yer oars in people so I may get some warmth to ma ass before Winter comes...
#43 furiokid
furiokid
  • 7 posts
Posted 16 June 2011 - 02:57 PM
Just currently installing my loom and on the last bit of wiring up to the light switch and i don't have a grey/black to wire too? can anyone tell me which pin number it should be??
#44 white_gorilla
white_gorilla
  • 12 posts
Posted 18 June 2011 - 11:39 AM
Golf 115 tdi
Have installed a Kufatec heated seat loom tuther day along with new elements in the front seats of my tdi. I have illumination of the switches and upon checking the plug on both sides I am getting no higher than 4volts when turning the seat switches. Is this correct? shouldn't I be getting 12v?
Why is fuse 5 mentioned in previous threads? I fitted a fuse into 44 only.
Furthermore as it is a retrofit I don not have the small looms that connect the different plugs on the seat elements....I am just using the main block connectors.
Not feeling the heat yet....
any tips gratefully received....
#45 NooNoo
NooNoo
    NooNoo
  • 9388 posts
  • Leicester
Posted 21 June 2011 - 05:05 PM
This is the base / backrest interconnect I needed for Recaros...
https://uk-mkivs.net/...36.aspx#1722736
Is that what you are missing?
#46 white_gorilla
white_gorilla
  • 12 posts
Posted 22 June 2011 - 01:00 PM
Yeah that be the one. To be honest I wish I had ordered the complete kit off VW_Teeside instead of messing about with the kufatec loom and second hand switches. It would have been a lot easier and no more expensive. Have put an order in for a pair. Cheers.
#47 blade4real2004
blade4real2004
  • 1358 posts
Posted 22 June 2011 - 02:38 PM
 i got this mission to start tomorrow if my loom comes...anyone know what the time scale is on fitting this loom?
#48 blade4real2004
blade4real2004
  • 1358 posts
Posted 22 June 2011 - 02:39 PM
 also im thinking of routing it the right was past the bonnet realise anyone know how it comes off and the trims around that side?
#49 white_gorilla
white_gorilla
  • 12 posts
Posted 22 June 2011 - 03:02 PM
I routed mine via the centre console. Took a couple of hours. pretty straightforward
#50 blade4real2004
blade4real2004
  • 1358 posts
Posted 22 June 2011 - 03:08 PM
 how much extra wire you left with if you go the centre console way?
#51 NooNoo
NooNoo
    NooNoo
  • 9388 posts
  • Leicester
Posted 22 June 2011 - 03:14 PM
Proper route with the Kufatec loom is via the bonnet release area and lead lengths are perfect for this. No problem with centre console distribution but you will end up with a cable coil.
Be very cautious with the bonnet release removal, it's not obvious. There are many pics on here and other forums that will detail exactly how to remove it.
I think the VW Teeside kit is great if you have VW Sports seats, if you have genuine Recaros you really need the Recaro elements (they are different).
#52 blade4real2004
blade4real2004
  • 1358 posts
Posted 22 June 2011 - 03:20 PM
yer i would really want to go the proper route with it as i dont really want any cable bunched up
ill have to try and find how to remove the handle and trim part
#53 NooNoo
NooNoo
    NooNoo
  • 9388 posts
  • Leicester
Posted 22 June 2011 - 03:27 PM
Quite a long way down this post are some pics of the bonnet release and the fragile clip that needs to be removed...
https://uk-mkivs.net/...74.aspx#1561474
#54 blade4real2004
blade4real2004
  • 1358 posts
Posted 22 June 2011 - 03:41 PM
 cheers noo ill take a look now
#55 blade4real2004
blade4real2004
  • 1358 posts
Posted 23 June 2011 - 11:08 AM
 well it looks like im going to be awaiting 2 weeks for my loom after waiting two days and spenting 9 quid on overnight delivery i get told that its a special order item that got to be made up in germany and then shipped over here even through on there web site it states 3-5 working days
sooo peee'd off is an understatement! DAM KUFATEC!
anyone know the part number for vw's heated seats loom? ill give them a try see what they say
#56 white_gorilla
white_gorilla
  • 12 posts
Posted 06 July 2011 - 11:19 AM
Drivers seat working fine after retrofit with kufatec loom. However, passenger side does not properly. the side elements work but but bottom element and back do not. I have a black plug on the side elements along with the green and and white plugs. This black plug has not been used as I have nothing to plug it into.
any ideas?
#57 NooNoo
NooNoo
    NooNoo
  • 9388 posts
  • Leicester
Posted 06 July 2011 - 01:05 PM
 any ideas?
Not following this. On cloth Recaros there is a base heater and a backrest heater and a single interconnecting cable. You say there are side elements? What seats are these?
#58 white_gorilla
white_gorilla
  • 12 posts
Posted 06 July 2011 - 01:51 PM
Howdo NooNoo
I have sports seats.
On drivers side I have a base heater and backrest heater. this works fine. On passenger side I brought the small side bits that house the green plug separate from the base seat, this has a female white connector AND a four pin black plug which does not fit anything.
In addition on the passenger side I have a backrest heater and base heater both with white plugs which via the interconnecting cable I have joined together and connected to the white female connector. I feel that maybe I have brought an element for Recaro seats or leather seats?  The black plug consists of four wires; brown, brown & black, yellow & black and white and black. I get 4v from the last two wires.
Broken circuit?
#59 NooNoo
NooNoo
    NooNoo
  • 9388 posts
  • Leicester
Posted 06 July 2011 - 03:55 PM
Pic from my element install...
Green plug went to the Kufatec loom and white to the backrest heater...
#60 white_gorilla
white_gorilla
  • 12 posts
Posted 07 July 2011 - 01:41 PM
That is the same as my driver side. My passenger side consists of three separate parts. this is what VW showed me on their screen today. the wing parts are separate from the seat base while there is an additional black connector plug. VW parts dude reckoned central locking connector?! Anyway I think this is wired different because it heated seat not working. I will try and upload a pic
