[Mk4 Golf] 1.8t - PCV simplification and catch can installation - Engine, Tuning and Performance - uk-mkivs
Mk4 Golf
181 replies to this topic
#1 Pat
Pat
  • 7467 posts
Posted 04 May 2009 - 04:44 PM
Sorry this has been a little longer in coming than I planned. It's not quite complete and I will edit more into this post as I go [y]
I wanted to simplify the PCV (positive crankcase ventilation) system on my car. The stock setup works well, but over time the materials used to produce these specially formed pipes breaks down gradually due to oily vapour, heat, manhandling when replacing adjacent parts.. etc etc
So I'm doing this for a variety of reasons:
No oily vapour should re-enter the intake. It'll be caught in the catch can. This should:
Keep boost pipes free from recirculated oil vapour
Octane of the fuel shouldn't be reduced (oil vapour reduces octane apparently)
No need to clean throttle body again
No boost leaks from the stock VW pipework under the manifold. Remember, anything in the inlet is either boost or vacuum. If a vac pipe connected to the manifold has a split, it'll leak both under vacuum and boost conditions and the ECU will need to compensate. If enough compensation has to occur that the ECU thinks it's out of tolerance, you'll see a CEL on the dash
The first thing I did was to remove both engine covers. Under the lower cover I loosened the metal plate which houses the N112, the N249, a checkvalve and a small maze of vac pipes
2 x 10mm bolts holding the SAI (secondary air injection) pump inlet pipe
then 2 x hex bolts holding the plate to the manifold
Carefully lift the plate from out of the clip on the side of the dipstick holder. If your dipstick holder's never been replaced it'll be very fragile and it'd be a good idea to replace it now for what it costs (about £5-6)
Now I started removing all the stock pipework from the top
See right behind the dipstick, there's the first small L section of pipe that leads to the suction jet pump Y piece. This is the pipe in which I've previously inserted a checkvalve, to stop boost before it hits the suction pump
I removed that, leaving the suction pump end exposed
Next was the infamous for splitting upper breather, on the passenger side of the rocker cover
It attaches to the TIP via the 'hockey puck' accumulator valve
Removed
Then I disconnected the brake booster line, leading from the suction pump
and finally I took out the lower breather pipe which is located right on the oil filter housing
You can see it on this picture from above, but unfortunately it's not in focus
I used a long shafted flathead screwdriver to prise off the C clip that holds it in position
http://i4.photobucke...CV/IMG_0245.jpg
There's an O ring in there too, careful not to lose it!
Removed
Now I managed to shimmy all the pipework clear and took this photo. The Upper breather Y pipe and the L piece leading to under the manifold are not attached, as mentioned above, I disconnected before removal
Yeggers! Look at that sludge that's accumulated [:O] Stuff like this clogs the PCV valve, the suction pump and will make it into your TIP..
Keep these 2 parts for the new installation
Now I want to cap the vacuum source under the manifold. It's not going to be used, all the pressure is positive coming from the crankcase and upper breather anyway and it'll be caught in the can. The fumes will also pull via the TIP connection when under acceleration. I used a small length of 3/8" ID pipe with a bolt screwed tightly into it
I'm also wanting to cap the brake booster line and just use the 1 vac source for brakes. It works on the AGU and ARZ so no reason it shouldn't work on an AUM right? I used a 1/2" piece of nylon rod and a jubilee clip but have since replaced this section of the brake booster line. Picture of revised piece to be edited in later
New picture to show the new brake booster line. I retained the original check valve as you can see, and it now looks a lot neater
All that's left to do now is cut new 3/4" or 19mm ID pipes, and connect the catch can between both breathers and the TIP
upper breather---catch can---TIP
lower breather /
The can Saikoimichi Type 951
The hose I got from Hosequip - I spoke to Josh who really is the most helpful fella in the universe. He sorted out some oil pipe so it shouldn't break down over time with all the vapours. As mentioned it's 3/4" or 19mm inner diameter stuff and I used around 1.5 metres
I connected the upper and lower connections to a T piece, and led this into the inlet of the can (top port)
I then connected the outlet (bottom port) of the can back to the hockey puck valve on the TIP
What I've done here is replace a system that I'm beginning to realise is slightly different depending on the model year of your car
AGU's and ARZ's seem to have only the one hose from under the manifold, straight down to the PCV valve
AUM's like mine (late 2000, X reg) have the hose, split into a Y 'suction jet pump' VW call it, top half coming up through the inlet manifold and joining onto the brake booster line off the passenger side of the manifold. The bottom split goes to the PCV valve
AUM's are different on the later models, my friend Lee has a Y reg that is different. Ste2 has a 53 reg that's also like this and so does Calimori.
They, like the AGU have the single pipe from inlet manifold to PCV, but an additional vac nipple right next to the PCV vac source, that also splits in the form of a suction pump, one half going to the TIP (presumably for pull under boost) and the other coming up through the manifold runners and into the brake booster line off the passenger side of the manifold
I'm not sure what an AUQ setup's like. I haven't seen one to pay any real attention to so if someone knows please post it here [y]
So far I have emptied out a couple of table spoons worth of oily water, so it does appear to be working. I'm going to pull the inlet pipe off soon though just to check everything's flowing okay, with no sludgy buildup
  • nickiejay1991 and Ells like this
#2 jmgr33n
jmgr33n
  • 1983 posts
Posted 05 May 2009 - 10:51 AM
Thats a great write-up Pat [Y] Really useful pictures too.
Think I'll be giving this a go on my ARZ in the near future.
Do you know if the catch can that forge do is any good?
James
#3 spawn
spawn
  • 1469 posts
Posted 07 May 2009 - 05:17 PM
 mate great write up, just what ive been looking for!
how much did u pay for ur catch tank?, looks sweet!
#4 spawn
spawn
  • 1469 posts
Posted 09 May 2009 - 06:38 PM
 i removed my pcv system 2day.. {agu}
what is the reason on having this on the 1.8t's..
most other cars dont?
i take it, it wont do any harm..?
#5 Shleng
Shleng
  • 353 posts
Posted 10 May 2009 - 08:42 AM
Thats a great write-up Pat Yes Really useful pictures too.
James
I have been looking at installing a catch can on my AUM. From what i have seen, the forge one, although good quality, only has 14mm inlet and outlet connections. The hose used on the standard PCV system is much larger in diameter. Would VW make them so large if this size was not essential? I would try and keep them a similar size, and the catch can used here has the largest connections that i have seen.
#6 spawn
spawn
  • 1469 posts
Posted 10 May 2009 - 09:28 AM
 the hose size is 19mm! alot bigger than most!
#7 Shleng
Shleng
  • 353 posts
Posted 10 May 2009 - 09:42 AM
 Is it possible to install one of these whilst still leaving the PCV system in use? I was intending to install the can between the 'y' shaped breather and the TIP. Would this work, and be effective? I dont want to remove too many components in case i decide to turn it back to standard when selling.
Also, can anybody tell me what the 'Hockey Puck' PCV valve does? Is it a check valve? How can you check if it is still functional?
#8 spawn
spawn
  • 1469 posts
Posted 10 May 2009 - 09:56 AM
 u can check pcv valve by blowing down pipe its a one way valve..
u can leave it on when installing catch tank..
ive removed it all cause i wanted to eliminate any crank case gases getting back into the inlet manifold..
#9 Shleng
Shleng
  • 353 posts
Posted 10 May 2009 - 10:16 AM
Ahh!!! So it is a check valve! Mines kafooked! I could go snorkeling with mine [:D] What stupid money do VW want for one of these then?
#10 Shleng
Shleng
  • 353 posts
Posted 11 May 2009 - 12:59 PM
 Just been checking the net after i made a note of the part number:
06A 129 101 A
It seems like this valve is also refered to as a Pressure Regulator Valve. It has a diagphram that restricts flow when the pressure is low in the tip (i.e. under acceleration). Because of this, im wondering if mine is faulty at all?
#11 spawn
spawn
  • 1469 posts
Posted 11 May 2009 - 01:05 PM
 when i took mine of it was like small plastic cylinder with a spring goes in and out?
only lets air through on way.
#12 Shleng
Shleng
  • 353 posts
Posted 11 May 2009 - 01:20 PM
I am getting confused?!?!? Do you mean the same component as me? The 'L' shaped connector, shaped like a hockey puck?
#13 spawn
spawn
  • 1469 posts
Posted 11 May 2009 - 01:43 PM
 opps.. i have agu so maybe different to urs..?
#14 BaV
BaV
  • 301 posts
Posted 11 May 2009 - 01:47 PM
This looks great and is a real help as i will be doing mine very soon.
Where did you get the Can from? Looks nice and oem.
a6e0e1f5-7bb9-4b2f-8b24-af5a424df199_zps
#15 Shleng
Shleng
  • 353 posts
Posted 11 May 2009 - 01:52 PM
 BaV, have you ever removed your 'PCV' valve that connects between the tip and the pipe that connects to the 'y' shaped breather? You have an AUM like me. I need to know the characteristics of the valve to know if mine is still functioning?
#16 BaV
BaV
  • 301 posts
Posted 11 May 2009 - 04:35 PM
Alright mate that isnt the PCV valve you are talking about. I think you are talking about the big hockey puck looking thing that sits next to your DV on your Tip?
The PCV valve is a small check valve that sits in the maze of vacuum tubes that sit above your oil filter housing.
The Hockey puck looking thing as far as i know is some sort of regulating one way valve. It is designed to slow air down passing through the system.
Hope that helps! Feel free to correct me if i have got anything wrong as i'm not 100% i havent started altering this yet i have just done the N249 for now.
#17 spawn
spawn
  • 1469 posts
Posted 11 May 2009 - 05:06 PM
pcv valve is marked on here.
#18 Shleng
Shleng
  • 353 posts
Posted 13 May 2009 - 01:51 AM
 Nice one lads. Ive just recieved my Samco Tip from Pritchi83 on here [:D] Not bad for £60! Cheers for that mate! Now I wanna wait to get my catch can before installing though. Im not sure if i wanna remove the existing PCV system. Pat, have you got any CEL codes appearing since you removed or is this not an issue? I was thinking that i could just install it in series between the 'Hockey Puck' and the 'y' shaped breather? It might not be as effective but it should catch some oil no? Or should i remove the full system?
I'm gettin a CEL now saying N249 Mechanical Malfunction, and SAI Incorrect Flow. I want to find the problem for these codes. I was going to remove the N249 valve and possibly the SAI but does this throw CEL codes anyway? These codes were appearing before my 'y' shaped breather split.
#19 AnniGTI
AnniGTI
  • 800 posts
Posted 13 May 2009 - 02:25 AM
I'm not sure what an AUQ setup's like. I haven't seen one to pay any real attention to so if someone knows please post it here Yes
Pat nice write up [Y]
Now it seems you lost me when it came to reinstalling the above two items back on the car. Do you have any pictures or what was done to refit them?
Also to answer your question on the AUQ engine, from looking at yours and comparing it to mine I would say yes they are very similar.
#20 haf1zur
haf1zur
  • 8220 posts
Posted 13 May 2009 - 02:29 AM
Nice, i need to do this sometime
#21 BaV
BaV
  • 301 posts
Pat nice write up Yes
I assume they go back exactly where they were originally.  You put the L shape piece on the top of the oil filter housing and then connect the pipe that goes to the T piece on the top inlet of the catch tank.  And then leave the hockey puck thing on the TIP
Has anyone found were to buy this tank from in Enlgand? Or anything very similar?
#22 Shleng
Shleng
  • 353 posts
Posted 13 May 2009 - 03:27 AM
 No, ive checked the usual, google and eBay and cannot find one as yet. 15mm is the largest i have found, which is the same as the forge one. I'm gunna keep looking but it looks like im going for the Saikou Michi too.
#23 BaV
BaV
  • 301 posts
Posted 13 May 2009 - 10:44 AM
So have you found somewhere you can get the saikou michi one from in this country?
#24 Shleng
Shleng
  • 353 posts
Posted 13 May 2009 - 05:38 PM
 Nah just from the website that Pat supplied. I think that they only sell on their websites and they don't have any other retail outlets. I think these are made to order thats why!
#25 James_1-8T
James_1-8T
  • 151 posts
Posted 17 May 2009 - 10:00 AM
Hi Guys did anyone end up finding a 19mm catch can similair to the 'Saikou Michi' ??
Also i've looked at the hockey puck thing on mine and it doesnt look to do much except house a spring? There seems to be an upgraded part for this now so I'm betting its probably broken like most of the plastic bits in the bay!
[^o)]
#26 Shleng
Shleng
  • 353 posts
Posted 18 May 2009 - 01:25 AM
Found a Greddy one for £51.68
http://www.nengun.co...catch-tank-1000
Might just opt for the Saikoi Michi as its more oem looking.
#27 James_1-8T
James_1-8T
  • 151 posts
Posted 18 May 2009 - 06:56 AM
 Yeah as you say the Saiko Michi is more oem looking which i prefer... or i guess i could just get some hose reducers to get a bit more choice. My TIP is covered in oil so i definatly want to get this done, not sure still if the amount of oil in the TIP is anything to do with the hockey puck thing though. Wondering if i should buy the revised part just in case its faulty?
Thanks for your help.
#28 Shleng
Shleng
  • 353 posts
Posted 18 May 2009 - 09:04 AM
After what has been said in this thread, i think that the 'Hockey Puck' only engages (diaphram seals or reduces flow) when a large negative pressure is present (i.e. when the turbo is spooling). Oil will be sucked through this part in the form of vapour as there is no way of filtering. This is where the Catch Can comes into play. I have a Samco TIP that i plan to install at the same time, as i dont want to get it covered in oil. How much is the new component?
#29 James_1-8T
James_1-8T
  • 151 posts
Posted 18 May 2009 - 11:58 AM
I think the revision (06A 129 101 D) is about £19, I installed a blue samco TIP about 2 months ago and the inside is now totally black. If the 'Hocky puck' is anything like the standard dv then its had it. I did have a look and try to figure out how it works but i could only see a spring inside it and even after i compressed the spring with a screw driver i couldnt see anything else in there.
#30 Shleng
Shleng
  • 353 posts
Posted 18 May 2009 - 04:31 PM
 I think on top of that spring is a diaphragm that gets 'sucked' down under acceleration, compressing the spring, and sealing the valve. This then reduces the flow from the crankcase and the TIP but does not completely block it (as i believe most pressure is present under acceleration).
