Mk 4 V6 4Motion Daily Driver - Volkswagen Driver Magazine - uk-mkivs
14 replies to this topic
#1 Neil Birkitt
Neil Birkitt
  • 382 posts
  • Bedfordshire
Posted 09 December 2013 - 11:31 AM
Now running a Mk 4 V6 4Motion as daily driver ...
4-door in black, de-badged, with original 6.5 x 16 Brands Hatch alloys running 205/55 Goodyear Ultragrip8 Winter tyres, or 7.5x17 RS4 reps running 225/45 Dunlop SportMaxx for summer
Suspension: Eibach Pro springs, Bilstein (R32) dampers, Polybush top mounts, Eibach anti-roll bars front and rear
Engine: Stock but running a Prinz Autogas LPG conversion, getting 220-240 miles per 41-litre refill costing £31  :-)
Westfalia detachable towbar
See various articles featured in Volkswagen Driver magazine  ( www.volkswagendrivermag.co.uk )
Neil Birkitt
Editor, Volkswagen Driver magazine
[email protected]
#2 Franko180
Franko180
    99 Ronnie
  • Car of the Year
  • 2792 posts
  • Haldex City
  • Golf IV R32 3.2 240PS
Posted 09 December 2013 - 11:50 AM
I was at a VW dealer last week and was reading either a March or April VW driver magazine with the first installment of your V6 article :)
From:                                                      To:
MK4 Golf R32 - Rescue Build Thread  ++ Full licensed VCDS (VAG COM), key coding, cluster coding, diagnostics etc.++
#3 welder1
welder1
    welder1
  • 1057 posts
  • South East Kent
  • Jetta Sport 2.0 TDI CR 140PS DSG
Posted 11 December 2013 - 09:18 AM
My one was in Golf Driver article done couple of years ago on these cars along with a few other owners great cars to drive ,Peter
#4 Neil Birkitt
Neil Birkitt
  • 382 posts
  • Bedfordshire
Posted 11 December 2013 - 10:28 PM
Unfortunately the 4Motion is currently only a 2Motion! – trying to resolve problem with rear drive system – anyone got a good Haldex unit?  Before it snows....
#5 Neil Birkitt
Neil Birkitt
  • 382 posts
  • Bedfordshire
Posted 23 December 2013 - 02:02 PM
Recent work to bring it up to scratch and fresh MoT etc: New set of Eibach Pro springs –30 mm, with Polybush –10 mm front top mounts ( dampers are R32 Bilsteins, front and rear ) Eibach anti-roll bars fitted front and rear, also needed new sump as original had started seeping oil from a small crack where it has been bashed. Curently running Dunlop Sport Maxx 225/45 on 7.5 x 17-inch RS4 reps, but  soon to have Goodyear Ultragrip8 Winter tyres swapped onto standard Mk 4 6.5 x 16-inch steel rims for Winter use as still only running 2wd, hence new Haldex unit needed... ( new controller and oil change didn't fix it... )
#6 poppinfresh
poppinfresh
  • 19 posts
  • Herts
Posted 23 December 2013 - 02:19 PM
Any fault codes? Mine's been disabled thanks to an ABS sensor, lots of things can upset it unfortunatly.
#7 Franko180
Franko180
    99 Ronnie
  • Car of the Year
  • 2792 posts
  • Haldex City
Posted 23 December 2013 - 02:35 PM
Neil, I saved a bunch of useful threads about this ages ago, for when I was a bit suspicious about my Bora's 4motion. Common culprit with these problems is the Haldex pre-charge pump, have a look at this thead over a coffee -
https://uk-mkivs.net/...2wdplease-help/
From:                                                      To:
#8 Dod 1396
Dod 1396
    Hang on like this MKIV thing
  • 2778 posts
Posted 24 December 2013 - 12:07 AM
Is this what your looking for Neil?
http://www.r32oc.com...e-charge-pumps/
How you getting on with the Prins LPG?
#9 Neil Birkitt
Neil Birkitt
  • 382 posts
  • Bedfordshire
Posted 24 December 2013 - 01:28 PM
Thanks for all the useful feedback...  You'd never think that so many other systems could impinge on the operation of the 4wd system
The car has spent a lot of time in the workshop at APS of Brackley and they've done a pretty thorough diagnosis before declaring that the Haldex unit itself needs to be replaced, and I've since got a pretty good offer of a low-mileage (22K) unit from a guy off this forum, so just hoping the snow holds off for a week or so...  although the set of Goodyear Ultragrip8 Winter tyres should cope even with only 2wd
LPG conversion still doing the business – gets 200 to 240 miles out of £30 worth of LPG  :-)
#10 Franko180
Franko180
    99 Ronnie
  • Car of the Year
  • 2792 posts
  • Haldex City
Posted 19 August 2014 - 10:25 AM
Still have this car Neil? How are you getting on with it?
From:                                                      To:
#11 Neil Birkitt
Neil Birkitt
  • 382 posts
  • Bedfordshire
Posted 26 August 2014 - 10:01 PM
Sorry, not been on to check this thread for a while.. Yes, still running the V6 2Mo as a daily driver.. Only major problem was when the alternator packed up while at out track day at Castle Combe in May.. many thanks to Grantley Woodhatch of Grant Motorsport for fitting  a new one in the paddock after everyone else had gone home..  no real progress since on sorting out the rear drive issue, but not my highest priority, until it starts snowing again.. ( ?! ) Dunlops nearly worn out, so recently had the original Brands Hatch 6.5 x 16 alloys refurbed and fitted with new 205/55 Toyo T1-R Sports... Will soon need new discs and pads, will probably go for EBC Yellow or similar...
#12 Neil Birkitt
Neil Birkitt
  • 382 posts
  • Bedfordshire
Posted 02 January 2015 - 05:05 PM
Full update article on the V6 4Mo coming up in the next issue ( Feb 2015 ) of VW Driver mag ...
Project GTI 1.8T still awaiting fitting of its newly rebuilt AGU engine... where on earth did the last year go to..?!
#13 Neil Birkitt
Neil Birkitt
  • 382 posts
  • Bedfordshire
Posted 21 January 2015 - 09:01 PM
5-page update / running report about the V6 4Motion over the last 40,000 miles in 2 years, in the latest issue ( Feb 2015 ) of Volkswagen Driver, just published...
#14 Neil Birkitt
Neil Birkitt
  • 382 posts
  • Bedfordshire
Posted 29 July 2015 - 08:58 PM
Now fast approaching 200,000 ( 197,540 on the clock last time I looked.. ) and has recently had a pair of TT front wishbones with SuperPro bushes, 4-wheel alignment, new front 312 mm discs and pads + fresh fluid, and  then a recon steering rack after the original seized up just outside VW HQ in Milton Keynes! ... all work done at VAGTech...
#15 Neil Birkitt
Neil Birkitt
  • 382 posts
  • Bedfordshire
Posted 19 September 2015 - 07:06 PM
Just clocked over 200,000 today!   See pics etc on the Volkswagen Driver mag facebook page ( www.volkswagendrivermag.co.uk  )
Will soon be getting a new set of Winter tyres fitted... Going for Goodyear Vector 4Seasons Gen 2 this time, 205/55 R16 on the original 6.5 x 16 Brands Hatch alloys
  • Gti Fly likes this
