[Mk4 Golf] Vnt Tdi Turbo: How To Adjust Actuator & Cure Boost Problems - D.I.Y Guides and How to Instructions - uk-mkivs
Mk4 Golf
414 replies to this topic
#1 fenwick458
fenwick458
  • 5335 posts
Posted 21 May 2010 - 12:51 PM
seems like it's getting more and more common this, so i've decided to write a little guide about it as i am particularly bored right now.......[O]
firstly, if you have any sort of problems then step 1 is always the same, diagnostics.
Step 1: using VAG COM log block 11 from 2000rpm to 4000rpm in 3rd gear on a flat straight bit of road
from this info in the log file, I can tell you everything about what the engine/turbo/ECU is doing. It means you can start diagnosing and faultfinding, it's no good posting up on the forum "help, my cars in limp mode when i floor it uphill, WTF do i do?" and then when somebody replies "probably the MAF mate" so then you go out and spend £80 odd quid on a new MAF (or however much thesy cost nowadays) and fit it on the off chance that it might fix the problem........
when you log block 11, you will end up with a whole bunch of numbers that look like this.
Group A: '003 Group B: '011 Group C:
Engine speed MAF (specified) MAF (actual) EGR duty cycle Engine speed Spec. intake press. Actual intake press. D.cycle MAP
TIME 790-870 230-310 210-350 40-75% TIME 2850-3150 2200-2400 2100-2600 35-80% TIME
Marker STAMP RPM  mg/str  mg/str  % STAMP  /min  mbar mbar  % STAMP
0.4 2142 850 1068.2 4.8 0.01 2058 2325.6 2316.6 61.8
1.2 2289 850 1053.5 4.8 0.8 2205 2335.8 2328.3 63.8
2.03 2415 850 1048.6 4.8 1.62 2352 2346 2351.7 64.9
2.86 2562 850 1058.4 4.8 2.45 2478 2346 2351.7 64.9
3.68 2688 850 1058.4 4.8 3.28 2625 2346 2375.1 67.3
4.48 2814 850 1029 4.8 4.08 2751 2346 2375.1 67.3
5.28 2919 850 1014.3 4.8 4.88 2877 2346 2351.7 68.1
6.08 3045 850 1004.5 4.8 5.66 2982 2346 2340 67.3
6.88 3129 850 999.6 4.8 6.48 3087 2346 2340 67.3
7.68 3213 850 975.1 4.8 7.28 3171 2346 2351.7 68.5
8.48 3297 850 980 4.8 8.08 3255 2346 2328.3 67.7
9.28 3381 850 970.2 4.8 8.88 3339 2346 2351.7 68.5
10.06 3444 850 970.2 4.8 9.68 3423 2346 2363.4 69.7
10.88 3507 850 955.5 4.8 10.46 3486 2346 2351.7 70.1
11.68 3591 850 940.8 4.8 11.28 3549 2346 2351.7 70.1
12.48 3654 850 935.9 4.8 12.08 3612 2346 2340 69.7
13.28 3717 850 931 4.8 12.88 3675 2346 2363.4 70.9
14.09 3780 850 945.7 4.8 13.68 3738 2346 2375.1 72.1
14.92 3843 850 940.8 4.8 14.51 3801 2346 2386.8 74.1
which aren't much use like that, it makes it much clearer and easier to read if you convert it into a graph and then post the graph up. (btw....the above is not a really bad example, i have seen much worse attempts. some of which are just rows and rows of numbers with no headings![^o)] ) to make it clear and increse your chance of someone helping you you should make a graph and post that up, to make a graph heres what you need to do:
right heres a quick how to on making them into a graph using excel. i have excel 2007 so if you don't it might be a little bit different......
first open the file with excel, then highlight all of the info you wish to make a graph of, so if you wanted to make a graph of block 11, highlight from the "engine speed" cell at the top left all the way down to the last N75 % figure in the bottom right.
then click on insert, line and 2D line and it should bring up a graph infront of you.
now to get the duty cycle so you can see it, you need to add a secondary y axis. to do this at the top righ area, under chart tools, click on format, then at the top left of the screen you will see a drop down menu that says "chart area" change that to Series "D.cycle MAP 35-80%" and then below it click on format s election, then change the option from primary axis to secondary axis and click close.
thats it, you can now see everything properly, now you should be able to post it up on the forum. to do that i just make the graph as big as possible and then print screen, paste it into paint and save it then upload using photobucket.
a graph of block 11 will look like this
What do all the numbers mean??
RPM is obviously the engine speed,
Requested boost is how much boost the turbo should be making according to the map like in the ECU
Actual boost is how much boost the turbo is making, measured by the MAP (Manifold Absolute Pressure) sensor. this should abviously be similar to the requested value, however it's normal for it to have a little bit of lag, and then spike as the turbo spools up before returning to "about the same as the requested value"
N75 Duty Cycle this is given as a %, the highest it reads to is 94% and the lowest is around 30% but don't quote me on that. A low duty cycle equates to the ECU asking for more boost from the turbo, and a high duty cycle means the ECU has too much boost already and is requesting the boost be lower. so looking at the graph as accellerator is pressed, more fuel is injected and more boost is requested, as the boost is requested you will see the duty cycle go down, the boost will then rise to the required value as the turbo spools up and then the duty cycle will increase as you go up the revs. it does this because the amount of air flowing through the turbo is increasing, and with that increasing the need for the the vanes to close and build more boost is decreasing, hence the duty cycle rising.
*Note, for both of the boost readings they are in mBar and Absolute. Absolute means it's including atmospheric pressure which is normally around 1 Bar give or take a few millibars. so to get into a figure we work with (Bars of boost) you need to divide by 1000 and then subtract 1 Bar (If you happen to live at a great height from sea level then you should take this into account as the atmospheric pressure will be different)
** Another note, the figures you see in VAG COM also may not be all there is too it, because of limiters it will only show upto 2983.5 mBar, this is the limit of what VAG COM can read from a standard ECU. even if you were to fit and calibrate in a 4 bar MAP the actual boost would still never read above this even though the ECU is capable of measuring above it, it still doesn't let VAG COM show the real amount. the requested boost will also only show upto 2601 mBar for the same reason, and the only way to get around it is to edit the conversion factors in the ECU which sadly no tuners that I know of in the UK are able to do. I don't know how to do it, and this is all the other info I have about it if you are curious:
so you have a 16 bit value of measued MAP, this comes from the 2D linearisation you fixed, then that value is muliplied by the 16 to 8 bit factor to convert the measued boost into 8bit 0x00 to 0xFF, then that value is sent to vagcom, the ecu also send the kwp1281 data so vagcom knows what formula it must multiply the 0x00 to 0xFF value to get the correct value and unit on the screen it's as simple as that
How the N75, Vacuum system, Actuator and VNT turbo work.
How a VNT turbo works
by using some adjustable vanes inside the turbine housing, it's possible to increase flow over the turbine wheel and speed it up at lower revs, this means it can spool up quicker than the traditional wastegate turbo. then once the engine speed is fast enough the vanes open up as there is now enough air moving through the turbo to spin the turbine fast enough without the need for the vanes to be closed
this video shows the vanes in action:
http://www.youtube.c...eos=t4j6OAsgZtU
N75
it is basically a simple Y valve inside, the vacuum comes in at the top "vac in" and then depending on the duty cycle from the ECU it will either
  • send all of the vacuum out of the "vac out" line to the actuator (low duty cycle, more boost requested)
  • send all of the vac out to "atmosphere" (high duty cycle, less boost requested)
  • or anywhere inbetween
Actuator
the actuator controls the VNT rod, which controls the VNT mechanism (the vanes) which ultimately determine the boost the turbo produces. it's moved one way by vacuum, and in the absence of any vacuum a spring will return it to it's resting position.
The Vacuum system
on your TDI you might get confused faultfinding with the multitude of vacuum hoses you will see scattered around the bay. this is a simplified version of the vacuum system, it's exactly how it is on my car so if you have deleted your EGR and you are looking for a vacuum leak, it make sense to just rip everything out and pipe it like this, it will make it easier when you are faultfinding.
Common problems
probably the most common is sticking vanes, also you could have incorrect VNT rod length, incorrectly setup stop screw or a vacuum leak/blockage.
if the vanes are stcking then they are just going to jam in any position, normally fully closed, and then once the N75 cannot control the amount of boost (i.e if actual boost is not near enough to requested boost for a given amount of time) then it will go into limp mode
if there is a vacuum leak then there might not be sufficient vacuum in the line to pull the actuator down acainst the spring, move the VNT rod , close the vanes and generate boost, if this happens then after a certain amount of time (~2-3 sec) and still not enough actual boost then it will go into limp mode
if the VNT rod is too short then it will effectively make the turbo far too sensitive and as soon as the ECU requests boost, before you know it you have twice the amount of boost requested as it suddenly spikes. once it does this, it's basically lost control of the boost and for some reason it won't go into limp mode, instead you will just feel a flat spot and if you have a boost gauge you will notice it going off the scale! the reason for the flat spot is the amount of EMP (exhaust manifold pressure) suddenly generated is too much to get though the turbine, so the engine is choked and held back. once the boost falls to a reasonable level you will feel the car start to pull again.
if the VNT rod is too long it will mean the turbo is not responsive enough and it may feel sluggish and laggy.
Vacuum leak, if you have a vacuum leak then it will be the same as above, sluggish and laggy as the N75 will not be able to apply enough vacuum to the actuator
Vacuum Blockage. one example of this is if the atmosphere line from the N75 is blocked then then it will have no way to vent the vacuum away from the actuator, and it will simply send 100% vacuum to the actuator at all times which will most probably end up in limp mode as the vanes will be jammed shut.
Checks and Procedures
How to check the Vacuum system
The most basic way to do this is remove the middle hose from the N75 and suck on it, you should be able to build up enough vacuum to move the VNT lever all the way to the stop screw. once there if you hod it for 1 minute and the lever does not move then all is working as it should be. if the VNT lever starts returning straight away, then theres a leak either in the vac pipe or the actuator diaphragm. if you have a vacuum pump you can use that to do this check, the vacuum will fall slightly on the gauge but as long as it's not rapidly descending it it ok.
http://cgi.ebay.co.u...em=230477698201
How to check the N75
perform an N75 output test using VAG COM and you should be able to see the actuator moving and hear the exhaust tone changing.  alternatively you could swap the N75 for a working one to see if that changes the problem before buying a new one. N75's are very reliable, most of the time its something else causing the problem. also, if you remove the MAP sensor plug temporarily with the engine idling, you should hear a noticeble change in the exhaust note, then once you re-connect the MAP sensor plug it should go back to normal. this proves the N75 is "alive", however it doesn't mean it's 100% working as there could be another fault, sticking in low duty cycle position for example.
How to adjust the VNT rod length
When these turbos are new straight from Garrett, the rod length and stop screws are setup professionally in accordance with their specifications. since they do not publish these specifications alot of re built, re manufactured, re furbished turbos do not have them properly set up. This includes so called "Garrett approved turbo re-builders" most of the time they will just leave them as standard and expect them to work, and they will work most of the time but obviously there is going to be times when they don't.  And because the hybrid turbos are different specifications, the rod length and stop screw specifications from Garrett will no longer apply. this means the turbo must be set up either on a flow bench or on the car.
Adjusting the rod length is necessary if you are getting errattic boost problems, if your duty cycle is above 80% at 4,000rpm then it needs made longer, and if your duty cycle is below 70% at 4,000rpm it needs made shorter. between 70-80% is ok, the closer to 80% the better.
How I do it is remove the TIP and get at it from above, it is possible to do it from below but theres limited space down there too, I prefer the top way.
so once you have removed the tip, you will be able to see this-
I always remove the c-clip that holds the rod onto the vnt lever, it means you can push the rod off the lever as far is it will go right before it hits the compressor housing and you can then get your thumb in where the red square is to move the knurled ring and adjust the length.if it's a brand new turbo you might not need to do this because the rod will still be new and oiled, but on a 5 year old turbo they tend to be seized a bit, so this is why you need more room to get your whole thumb in there and get more purchase on the ring.
to loosen the 10mm locknut, best way is to cut a 10mm spanner as shown:
if you try and use an open end, the jaws are too big to get onto the nut, so you need to cut a slot in the ring end, and also chop it in half because theres limited space between the bulkhead and the engine.
heres a pic of the spanner in use and what you will see from above:
adjustment should be done one turn at a time, and re check with VAG COM after adjustments.
How to cure sticking vanes
If the vanes are sticking, firstly you can try removing the actuator/VNT rod and giving the VNT lever a bloody good wiggle, it's not garanteed to fix the problem but it worked for me years ago! To do this you need to gain access to the turbo either from above or below, remove the 2 X 10mm nuts holding the actuator to the mount, then remove the C-Clip holding the VNT rod onto the VNT lever, and then you can slide the rod off and remove the actuator alltogether. once it's out of the way, give the VNT lever a good wiggle and then re-fit and see it it has cured the problem. if it doesn't work then you could either do a DIY refurb, you could send it away to a company to get it re-furbed, you could try using a boost valve, or you could attempt the Innotec VNT clean. more info on all of them below
Refurbish the Turbo
probably the most expensive way, most companies will charge about £250 to do this, maybe more. also be aware that it might come back with a new (incorrectly set up) actuator/VNT rod. you could also do the clean yourself if you are competent, heres a guide: http://pics.tdiclub....edure_small.pdf
Using a Boost Valve
here I have found a quote from myself about a year ago, this can work and help stop sticking vanes, however I would not use it for any other reason, i.e to stop spiking or mapping issues. I used one to stop spiking a year ago, it cured it a little bit but the problem was still there, allbeit masked a little.
the reason it works is when the duty cycle is raised, the actuator sees less vacuum and the springin the actuator is expeced to return the VNT lever back to open the vanes up. so it's not a force acting upon the actuator, but instead the abscence of a force and it's all relying upon the spring. if the vanes are a little bit coked up, then it might stick or not respond as quicky as it should, so what this method does is put boost into the vacuum line, which has the opposte effect to the vacuum and will open the vanes up instantly, resulting in lower boost. It basically gives it a bit of a kick.
right here is something else you can do to to try and stop sticking VNT vanes, a manual boost controller. set it to open at just above your max requested boost pressure (~1.6 bar for a mapped PD150)
so for example if we have a mapped 150, as soon as the charge pressure reaches 1.6 bar the MBC sends 1.6 bar of boost pressure down into the N75-actuator vacuum line and firmly seats the actuator in the "vanes open" position. the key thing here is boost into vacuum line! as long as the turbo is not rediculously coked up the extra force on the actuaor should be enough to keep them moving freely
the type of MBC you get is important too, do not get a bleed valve, you need a ball and spring type one. they are on ebay for £20-30 or if you want you can buy a shiny one from demon tweeks etc.., that has a click adjust setting with lockout, these are very easy to set up but are more expensive and effectively the same thing. do not buy a turbosmart boost tee, it will not work properly.
the one I bought had a small hole which needed blocking up, I used chemical metal but i'm sure any sort of glue would work.  if you don't block it up it will act as a vacuum leak in the N75-actuator line.
Innotec Turbo clean
I don't have personal experience of this, but I am told it works. more info on this thread https://uk-mkivs.net/...s/t/230403.aspx
  • RobertV, dervdave and SpkPD130 like this
#2 Pieman
Pieman
  • 383 posts
Posted 21 May 2010 - 01:57 PM
Very good. This should be made a Sticky!![Y]
#3 Bobby_Singh
Bobby_Singh
    B S R
  • 1265 posts
  • West London and Windsor
  • A4 3.0 TDI Bus of Moderate Win
Posted 22 May 2010 - 03:33 PM
Stu everything is good mate but Im not a fan off these MBC.
Also as a side note from what I've seen so far all these TD hybrids surge at around 2k to 2.5k and i've seen maps from all over the place that also have this issue.
#4 afro gti
afro gti
    Hang on like this MKIV thing
  • 4566 posts
Posted 23 May 2010 - 03:34 AM
Good write up again stu.
Quick question what software/license do we need to get to be able to do the logging?
#5 fenwick458
fenwick458
  • 5335 posts
Posted 23 May 2010 - 10:45 AM
I
know I know, not ideal but they have been known to cure sticking vanes.
it would not use one for any other reason though as they are not a
substitiute for proper mapping
You will need a VAG COM, i'm not sure about the versions, although i'd guess it needs to be a proper licenced cable as i think the shareware ones don't allow you to do logging.
#6 mike_r
mike_r
  • 339 posts
Posted 26 May 2010 - 11:40 AM
the un-registered Vag-com will only allow you to log 1 mesuring block. ( or atleast 409.1  not shure about VCDS light)
#7 devonutopia
devonutopia
  • 396 posts
Posted 29 May 2010 - 01:53 PM
 certain versions of 311.2 will allow you to log 3 groups at the same time. [:D]
However, for tuning purposes, 2 groups is best as logging 3 can distort the results somewhat as vagcom has trouble accurately doing that.  I am going to be running some logs myself soon now my turbo's actuator/VNT arm setup has been correctly fitted now.
#8 MAH
MAH
  • 485 posts
Posted 29 May 2010 - 02:10 PM
Good write up mate [Y]
#9 motionlee
motionlee
  • 3172 posts
Posted 29 May 2010 - 03:19 PM
Fenwick i could not of wrote that better myself so well done bud.
One thing i would like to add id that for me i find it easier to think of the vnt as a turbo inside a turbo due to function of the vanes, the vanes allow quick spool up by being closed on idle (less lag) and opening up on throttle to allow more flow of the turbo.
#10 Engimaneer
Engimaneer
  • 3437 posts
Posted 29 May 2010 - 03:25 PM
Nice!
Bump for my reference
#11 motionlee
motionlee
  • 3172 posts
Posted 29 May 2010 - 03:46 PM
One more thing to add is the vanes are in the open position in its resting postion, this is a fail safe system that the turbo was built, due to the fact that if for any reason the rod, actuator, and more commonly vac line failed the turbo would not over -boost causing possible destruction, so instead it would cause just lag.
Hope i not affend you fenwick by adding to your excellant thread, just a little input.
#12 roypaci
roypaci
  • 20 posts
Posted 18 June 2010 - 10:29 AM
I have done this test,and got an interesting result:
Engine speed Spec. intake press. Actual intake press. D.cycle MAP RPM Torque Inj. Quantity Inj. Quantity Engine speed MAF (specified) MAF (actual) EGR duty cycle
TIME 2850-3150 2000-2150 2000-2200 40-95% TIME TIME 820-900 230-420 230-420 10-95%
STAMP  /min  mbar  mbar  % STAMP  /min  Nm  mg/str  mg/str STAMP  /min  mg/str  mg/str  %
0.4 2100 1672.8 1846.2 58.6 0.8 2163 170 70 0 0 2037 640 597.8 50.6
1.6 2247 1621.8 1662.6 55.8 2 2310 170 70 0 1.2 2205 585 602.7 63
2.8 2373 1581 1611.6 61 3.2 2415 162 70 0 2.4 2331 600 588 52.2
4 2478 1570.8 1550.4 61 4.4 2520 158 70 0 3.6 2457 580 573.3 56.6
5.2 2604 1744.2 1611.6 57.4 5.6 2646 190 70 0 4.8 2562 660 578.2 50.6
6.41 2751 1642.2 1774.8 67.7 6.8 2793 172 70 0 6.01 2709 665 681.1 59
7.61 2877 1611.6 1591.2 64.9 8 2898 170 70 0 7.21 2835 635 656.6 66.9
8.8 2982 1560.6 1499.4 62.2 9.2 3024 166 70 0 8.4 2940 640 592.9 51.4
10 3066 1744.2 1560.6 53.4 10.4 3108 202 70 0 9.6 3045 650 632.1 47.8
11.2 3213 1713.6 1887 70.1 11.6 3234 184 70 0 10.8 3150 710 774.2 4.8
12.4 3339 1846.2 1805.4 67.3 12.8 3402 216 70 0 12 3276 785 681.1 4.8
13.6 3486 1785 1785 68.1 14 3549 214 70 0 13.2 3444 775 744.8 4.8
14.8 3654 1897.2 1856.4 61.4 15.2 3717 224 70 0 14.4 3591 845 735 4.8
16 3822 1927.8 1887 66.9 16.4 3885 226 70 0 15.6 3759 850 735 4.8
17.2 3465 1234.2 1540.2 39.8 17.61 2730 0 70 0 16.8 3906 850 725.2 4.8
#13 roypaci
roypaci
  • 20 posts
Posted 18 June 2010 - 10:31 AM
Engine speedSpec. intake press.Actual intake press.D.cycle MAPRPMTorqueInj. QuantityInj. QuantityEngine speedMAF (specified)MAF (actual)EGR duty cycle
TIME2850-31502000-21502000-220040-95%TIMETIME820-900230-420230-42010-95%
STAMP /min mbar mbar %STAMP /min Nm mg/str mg/strSTAMP /min mg/str mg/str %
0.421001672.81846.258.60.8216317070002037640597.850.6
1.622471621.81662.655.8223101707001.22205585602.763
2.8237315811611.6613.224151627002.4233160058852.2
424781570.81550.4614.425201587003.62457580573.356.6
5.226041744.21611.657.45.626461907004.82562660578.250.6
6.4127511642.21774.867.76.827931727006.012709665681.159
7.6128771611.61591.264.9828981707007.212835635656.666.9
8.829821560.61499.462.29.230241667008.42940640592.951.4
1030661744.21560.653.410.431082027009.63045650632.147.8
11.232131713.6188770.111.6323418470010.83150710774.24.8
12.433391846.21805.467.312.83402216700123276785681.14.8
13.634861785178568.114354921470013.23444775744.84.8
14.836541897.21856.461.415.2371722470014.435918457354.8
1638221927.8188766.916.4388522670015.637598507354.8
17.234651234.21540.239.817.612730070016.83906850725.24.8
2037640597.850.6
2205585602.763
233160058852.2
2457580573.356.6
2562660578.250.6
2709665681.159
2835635656.666.9
2940640592.951.4
3045650632.147.8
3150710774.24.8
3276785681.14.8
3444775744.84.8
35918457354.8
37598507354.8
3906850725.24.8
#14 roypaci
roypaci
  • 20 posts
Posted 18 June 2010 - 10:44 AM
As you can see guys the Spec. intake pressure and the Actual intake pressure do not reach the lowest limit,and the other is the  EGR duty cycle which is fine till I reached 3150 RPM,and the it has dropped to 4.8 form 47.8!!
Do you know are those values are fine,or what do those values mean??
Thank you
#15 fenwick458
fenwick458
  • 5335 posts
Posted 21 June 2010 - 12:32 PM
......it makes it much clearer and
headings!Hmm ) to make it clear and increse your chance of someone helping you you should make a graph and post that up, to make a graph heres what you need to do:
(see first post)
if you make it into a graph and post it up it will be much easer to understand
#16 roypaci
roypaci
  • 20 posts
Posted 21 June 2010 - 01:22 PM
Thank you fenwick!
I have successfully uploaded two pictures,first in group 011,and the second one in group 003(which shows the maf and the egr valve duty cycle)which are under the PHOTOS here.
Could you have a look on those please?
D cycle map dropping back to 40% about 3800rpm....Does it mean something?
As I read in your first post,that shold be between 70-80% about 4000rpm.
And the spec,and also the actual pressure do no reach the expected levels.
On the second picture I can see MAF shows higher values then the expected,but the weird thing I have changed the MAF 5 month ago.
Do you think are those values fine at MAF and EGR duty cycle?
Both have been taken in 3rd gear,between 2000 and 4000rpm.
#17 alanpemma
alanpemma
  • 5 posts
Posted 30 July 2010 - 04:28 AM
N75 Duty Cycle Issue
As you can see from the above chart my duty cycle for the N75 only ever reaches just above 60% I belive this should be close to 80%
My actual boost seems low untill engine speed reaches almost 3000
So is this because the N75 is faulty,I have a vacuum leak or the vnt actuator needs adjusting.
The story so far my turbo blew on my 2000 Passat 1.9 TDI engine AJM so I cleaned the intercooler and pipes and replaced with a reconditioned unit since then I have had the above problem the turbo does'nt spool fast enough (turbo lag). i have ordered a mityvac so I will test vacuum pipes when it arrives any ideas or thoughts on this greatly apprecated Thanks Alan
Would more logs help
#18 alanpemma
alanpemma
  • 5 posts
Posted 30 July 2010 - 10:22 AM
 Here is another log graph with a different result does this help Thanks
N75 log
#19 merlykx
merlykx
  • 7 posts
Posted 25 November 2010 - 06:19 AM
Hello, I own a 1.9TDi Seat Leon AHF (110bhp) and found this post quite interesting, thank you :) but I have one question...the n75 duty cycle, in my case it appears to be reversed.
I've recently upgraded my turbo (1749VB), injector nozzles (Firelli Bosio Race520) and camshaft (custom made by AM Motorsport, in Portugal) and am battling with safe modes. In order to fine tune the car I uploaded my original ECU file and made a trial run in 4th gear, 2000rpm to redline and back. Here's the graph:
My n75 duty cycle is always elevated, until I stop accelerating. I've also noticed that when in safe mode with "charge pressure control: negative deviation" my n75 duty cycle freezes at 92,4.
Currently the car is going into safe mode with "charge pressure control: positive deviation", however in the run that I logged it accelerated to about 160km/h without going into safe mode. After I stopped logging I shifted into 5th gear and got a safe mode at around 140km/h, about 30 seconds after stopping the log.
Any ideias on what might help solve the problem? My tuner is already working on a ECU file to try and avoid the safe modes but I'm worried with that graph, electronically it only requests a maximum of 0,95bar but it comes to a point where the actual pressure rises to 1,27bar (4158rpm) and then suddenly drops. It looks like I have an boost spike of 1,1bar that starts to drop to 1bar but then I get a boost creep and pressure begins rising again to 1,3bar. And this is using a factory default ECU file, I don't even want to think about what will happen when I start requesting 1,5bar :(
Thanks for your time :)
#20 alanpemma
alanpemma
  • 5 posts
Posted 25 November 2010 - 06:35 AM
It seems your VNT rod length is too short causing overboost then limp mode which will been seen by a high duty cycle ideal is 70-80% peak hope this helps
#21 merlykx
merlykx
  • 7 posts
Posted 25 November 2010 - 06:48 AM
Thanks,that's what I thought too but my mechanic said he didn't touch it... I'll try to have it lengthened (rotate towards the front of the car?) ASAP :)
#22 merlykx
merlykx
  • 7 posts
Posted 29 November 2010 - 04:26 AM
Hello, I had the car fixed this weekend and the problem wasn't the actuator, it was a leak on the vaccum system, a small tube just outside the vacuum pump. Had it fixed and now the car runs great, up to 228km/h and no safe mode =)
#23 old_n07
old_n07
    Diesel isn't a dirty word
  • Technical Contributor
  • PipPipPipPipPipPip
  • 11030 posts
  • North Staffs
Posted 29 November 2010 - 04:52 AM
 Just stickied this Stew, it might be usefull to me some [whistle]
#24 motionlee
motionlee
  • 3172 posts
Posted 01 December 2010 - 02:58 PM
The most informetive thread on here [Y]
might be good for you neil to try a maybe adjust your rod
#25 old_n07
old_n07
  • 11030 posts
  • North Staffs
Posted 01 December 2010 - 03:18 PM
 I have read it through a few times now Lee, I'm going to see what Nick has in store fore me at R-Tech as he's developing a theory to test on my car but if that doesn't work I will try adjusting the rod [y]
Neil
#26 motionlee
motionlee
  • 3172 posts
Posted 01 December 2010 - 03:23 PM
I can still see a pic of the turbo on that shiney floor of yours lol
#27 g4jsg
g4jsg
  • 15 posts
Posted 13 March 2011 - 09:41 AM
I'm having problems with very poor mpg on my 1.9 TDI 100 bhp auto golf.
Here's my block 11 a graph to see if this can bring any help to how \i might cure the problem on my car.
http://g4jsg.net/block11.jpg (sorry but I can't upload pics it seems)
My current thread about the problem is here.....https://uk-mkivs.net/forums/t/408729.aspx
Thanks, John
#28 Bosserdet
Bosserdet
  • 1 posts
Posted 03 June 2011 - 09:19 AM
This is a great write up!  Thanks.  This is a big help for my knowledge base.[:)]
#29 poxxxy
poxxxy
  • 282 posts
Posted 19 September 2011 - 01:04 PM
Can anyone offer any advice to get to the vnt actuator/lever/turbo on an ARL PD 150? Want to make the rod length ever so slightly longer!
Is the TIP easy enough to remove? I have an EGR delete if this will help (have a feeling it will as more room at the back!)
#30 danny_sims
danny_sims
  • 2987 posts
Posted 13 October 2011 - 02:46 PM
need to add to my posts. i need t sort out my very annoying pd130
