Madmans' OEM+ Diesel Build 17 Years on! - Page 4 - Members Rides - uk-mkivs
1483 replies to this topic
#91 markyb
markyb
  • 952 posts
Posted 04 November 2010 - 04:12 PM
No Neil. Its more my fault for the OT'ness of it.
Its informative never the less tho, which i think is still relative if people want to follow suit to Madmans work or even just giving ideas to a slightly cheaper option to the other hard pipe kits available [Y]
thank you for the links and info [Y]
#92 madman
madman
    TEAM 88 MOTORSPORT
  • 8901 posts
  • Area 51
  • Golf IV GTI 1.9 ARL 150PS
Posted 04 November 2010 - 04:33 PM
Its all good Gents...I cant believe the SFS red turbo replacement pipe can yield 20bhp. Anyone fancy been a guinea pig?[:o]
#93 old_n07
old_n07
    Diesel isn't a dirty word
  • Technical Contributor
  • PipPipPipPipPipPip
  • 11030 posts
  • North Staffs
Posted 04 November 2010 - 04:45 PM
 I was having this discussion with Ray (aRd) yesterday and he was very sceptical about it too, the diameter of the SFS pipe might be larger than the stock red pipe but he pointed out that the bore of the turbo connection matches the bore of the connection of the standard red pipe (he measured it)
So how does increasing in bore help if it makes it bigger than the port in the turbo connection? [8-)]
#94 madman
madman
    TEAM 88 MOTORSPORT
  • 8901 posts
  • Area 51
Posted 04 November 2010 - 04:56 PM
would be nice to see proof...although its not an expensive pipe @ £60 I believe. It just doesn't make sense. It would make for a nice connection to the 1.8T pancake though.[:|]
#95 amachleb
amachleb
  • 149 posts
Posted 06 November 2010 - 12:28 PM
 id be willing to be guinea pig, ive got a terrible whistling noise and when revving highly stoodstill so im guessing must be loose pipes to turbo??
i want to do the upgrades of intercooler (godspeed), egr delete kit (allard), sfs pipework from allard to turbo and 1.8t pancake pipe with silicone couplings, to basically eradicate usually gremlins.
can someone tell me if this is good mods and where to locate parts/ items and prices phone numbers etc
but im up for being the trialler if they can send one out to me to test for them???
let me know
A
#96 madman
madman
    TEAM 88 MOTORSPORT
  • 8901 posts
  • Area 51
Posted 06 November 2010 - 12:49 PM
Well I cant see SFS sending you one for nothing,They have already tested it,SFS have a section in the Advertisers bit near bottom of front page. Post a question in there mate[Y] I think the godspeed cooler works well along with the uprated pipework. Mine is boosting really well and I now know I'm leak free[:O] godspeed intercooler is available from Turborevs on Ebay...currently not in stock though[:^)]
#97 madman
madman
    TEAM 88 MOTORSPORT
  • 8901 posts
  • Area 51
Posted 07 November 2010 - 12:17 PM
Got this ordered Im going to use it to monitor the pre intercooler and post intercooler temperature...should be able to see exactly what the cooler is doing[8-|]
#98 yamaha88
yamaha88
  • 1313 posts
Posted 08 November 2010 - 03:36 PM
 Looks good let us know what the temps are, also are you going to swap back to the original intercooler for a test run?
craig
#99 madman
madman
    TEAM 88 MOTORSPORT
  • 8901 posts
  • Area 51
Posted 08 November 2010 - 04:51 PM
sorry craig I wont be putting the old cooler back on as its too much hastle...will post up what temps I get though[C]
#100 yamaha88
yamaha88
  • 1313 posts
Posted 08 November 2010 - 04:57 PM
 let me know your results and i will log my diesel and see if we can get an overall result
craig
#101 madman
madman
    TEAM 88 MOTORSPORT
  • 8901 posts
  • Area 51
Posted 08 November 2010 - 05:13 PM
sounds like a plan mate [Y]
#102 yamaha88
yamaha88
  • 1313 posts
Posted 12 November 2010 - 11:57 AM
 Have you got the temps yet? [:D]
craig
#103 madman
madman
    TEAM 88 MOTORSPORT
  • 8901 posts
  • Area 51
Posted 12 November 2010 - 12:08 PM
nah...turns out the fecking things from Hong Kong![:@] sorry mate[C]
#104 pedropete27
pedropete27
  • 8098 posts
Posted 12 November 2010 - 12:09 PM
Very nice car indeed fella![Y]
#105 madman
madman
    TEAM 88 MOTORSPORT
  • 8901 posts
  • Area 51
Posted 12 November 2010 - 12:16 PM
Very nice car indeed fella!Yes
Thanks pete [B]
Edit new page new pic
an old pic though[whistle]
#106 old_n07
old_n07
  • 11030 posts
  • North Staffs
Posted 21 November 2010 - 02:46 PM
 Just a couple of questions regarding the IC install, did you fit a bracket to the lower mount from the chassis?
Also did you have any difficulty with refitting the bumper, as the corner of the IC catches the seam where the valance joins on mine at the moment, I know I could trim the seam but I'll re adjust the IC first to move it accross and up a bit.
I tried fitting the pipework with the EGR but it comes too far accross so I will have to fit the EGR delete now to give me more room [:(]
Neil
#107 madman
madman
    TEAM 88 MOTORSPORT
  • 8901 posts
  • Area 51
Posted 21 November 2010 - 02:54 PM
mine had a lower mounting bracket already...I just mounted it all to the existing mounts. I used the metal spacers from the origional mounts to make it all line up. The bumper went straight on. Has your car been in a minor bump? just wondered why the origional cooler had leaked. I never tried with the EGR valve but I can undestand it running too wide over the power steering reservoir.
HTH mate [snack]
#108 old_n07
old_n07
  • 11030 posts
  • North Staffs
Posted 21 November 2010 - 02:59 PM
 Nope never had a bump, well not on the front any how
 I will try spacing it up and see if that helps, I have the original bracket from the factory SMIC but it seems way off but there again I haven't spaced the IC up at all, I just put rubber washers underneath the brackets [*-)]
Cheers for the tip [Y]
#109 lowdaily
lowdaily
  • 155 posts
Posted 21 November 2010 - 06:05 PM
Looking well, should be some great improvements you've done pd130 is VW's best diesel engine in my opinion.
#110 Golfin
Golfin
  • 6280 posts
Posted 21 November 2010 - 06:10 PM
Lovely motor mate.. nice clean and simple..
#111 madman
madman
    TEAM 88 MOTORSPORT
  • 8901 posts
  • Area 51
Posted 22 November 2010 - 01:10 PM
Cheers...I think the PD130 has a fair bit of potential[:)]
Thanks nice or you to say so[:D]
#112 amachleb
amachleb
  • 149 posts
Posted 25 November 2010 - 02:12 PM
 this may sound like a dumb request but ive been looking on fleabay, and have located the parts you mentioned 90o bends and 45o stainless etc
would you do me a favour and locate all the parts i require including ebay item numbers, as when i add up what ive found its a lot more than u listed
cheers fella, appreciate ya troubles
Al
#113 madman
madman
    TEAM 88 MOTORSPORT
  • 8901 posts
  • Area 51
Posted 25 November 2010 - 02:28 PM
its all listed somewhere with ebay links its in another post/ topic[C]
#114 amachleb
amachleb
  • 149 posts
Posted 25 November 2010 - 02:52 PM
 cant find anywhere if u could and send me a linky please
cheers madman
A
#115 madman
madman
    TEAM 88 MOTORSPORT
  • 8901 posts
  • Area 51
Posted 25 November 2010 - 03:09 PM
this alloy pipe and 2 of these bends
HTH mate
#116 old_n07
old_n07
  • 11030 posts
  • North Staffs
Posted 25 November 2010 - 03:11 PM
 This post in his build thread
https://uk-mkivs.net/...55.aspx#2666455
Neil
#117 madman
madman
    TEAM 88 MOTORSPORT
  • 8901 posts
  • Area 51
Posted 25 November 2010 - 03:26 PM
lol Neil[lol-lol]
#118 old_n07
old_n07
  • 11030 posts
  • North Staffs
Posted 25 November 2010 - 03:39 PM
 Yep, I see what I've done [doh]
#119 bigtallbloke
bigtallbloke
  • 435 posts
  • Poole, Dorset
  • Mk4 Models
Posted 26 November 2010 - 11:53 AM
Good inspiration there mate, like the way you've got things breathing more easily :)
#120 madman
madman
    TEAM 88 MOTORSPORT
  • 8901 posts
  • Area 51
Posted 26 November 2010 - 12:03 PM
[B]
