[Other] cant get any heat - TDI & Diesel Forum - uk-mkivs
Other
cant get any heat
No replies to this topic
#1 cypher007
cypher007
  • 67 posts
Posted 15 January 2016 - 09:56 AM
got a 110bhp tdi Leon.
it has got problems with the electrics, eg. when the cars filling up with water during the winter months I get the disco lights dash with beeping until I turn the ignition on, and sometimes it gets into a position where the both cooling fans runs continuous.
anyway I have disconnected both cooling fans and still have the same problem.
I start off to work and the coolant slowly gets upto warm and I get some heat out of the heater. if I then slow down to town speeds the coolant temp drops and eventually I end up with cold air blowing on my legs.
this morning the only way to keep it at 90 was to turn the heater off, it has climate control so had to turn the fan to minimum. I got out and felt the rad hoses top one was warm bottom one was cold near the rad but warmer close to the stat.
Also tagged with one or more of these keywords: Other
