Mot check online
Started by
vwgtiking
, Jan 31 2016 01:15 PM
13 replies to this topic
#1
Posted 31 January 2016 - 01:15 PM
Have been checking on a car I am looking to buy on this link;
https://www.check-mot.service.gov.uk
Over the past 5 years according to the gov website it recorded the below:
2011 - Odometer reading114,967 miles
2012 - Odometer reading122,839 miles
2013 - Odometer reading134,959 miles
2014 - Odometer reading146,508 miles
2015 - Odometer reading103,685 miles
However on the last mot certificate
2011 - 614967
2012 - 722839
2013 - 834959
2014 - 946508
What's going on here? Nearly a million miles? And would vcds give me true mileage.
2011 - 614967
2012 - 722839
2013 - 834959
2014 - 946508
#2
Posted 31 January 2016 - 01:29 PM
Mot's can be faked, there only a print out.
Are you 100% sure the reg was entered correctly?
The fact that it drops 43k from 2014-2015 shows something has happened, either clocked or cluster swap and milage not corrected.
#3
Posted 31 January 2016 - 01:39 PM
Why fake mileages at nearly a million miles? Can vcds confirm correct mileage stored on ecu?
Yes I double checked reg a few times.
#4
Posted 31 January 2016 - 01:44 PM
If it's a MK4 you can't verify the mileage from the car itself as it only stores mileage on the cluster, not the ECU. My previous 1.8T was sold with over 200k miles on it with full history and I've checked on that website and weeks after it was sold it went through MOT with about 100k less miles on it. Can only assume that someone had "clocked" it back and binned about 3-4 years of history (or all the history) and sold it as a 100k car. Bad boys.
MK4 Golf R32 - Rescue Build Thread ++ Full licensed VCDS (VAG COM), key coding, cluster coding, diagnostics etc.++
#5
Posted 31 January 2016 - 01:45 PM
VCDS doesn't store it on the ECU. Stored in the cluster though, but that's obviously the same as what's displayed on the odometer.
#6
Posted 31 January 2016 - 01:58 PM
Vcds can read the mileage off the ecu? Not its no a mk4.
#7
Posted 31 January 2016 - 02:03 PM
think you can safely forget the million odd mile MOT details although it would be interesting to see a new printout from a MOT centre. As mentioned it would be easy enough to doctored one.
I'd be more concerned as Doddy666 mentioned with the large drop in mileage in the last year which is fishy. There are legitimate reasons such as a cluster swap but most legitimate garages would install a new one and have it corrected to the same mileage as the old one or at least record the swap and give the mileages for each at the swap.
Doing neither is whiffy
Sadly you cannot rely on VCDS either. I don't know about the Mk4 cars but on th Mk5 a mileage is recorded in the ECU ad displayed/printed when a scan of the engine module is done and this should correlate closely with the cluster odometer reading. My own car was a one owner car with main dealer FSH when I bought it and the discrepancy over near 80k miles is just 4 miles
We do know however that these can be altered quite easily
My advice to anyone is that if you have the least doubts is to either walk away or ask demanding questions ad closely scrutinise the answers. At the end of the day we are still talking a common car here
#8
Posted 31 January 2016 - 02:12 PM
Depends on the model you are looking at. Look up EDC15 for an example of mileage stored on an ECU.
#9
Posted 31 January 2016 - 02:14 PM
Audi A3 8P.
#10
Posted 02 February 2016 - 01:08 PM
Can this be done? Also worth a view or stay clear? He claims service history all adds up.
#11
Posted 02 February 2016 - 07:35 PM
114967 = 614967 for 2011.
Remove the 6 and 1 leaving 4967.
Add 5 to the 6 = 11.
Place 11 in front of 4967.
= 114967
This translation matches all those numbers..
= 114967
#12
Posted 02 February 2016 - 07:36 PM
I wouldn't go near it with that 2015 number...
#13
Posted 16 February 2016 - 06:39 PM
I left it alone in the end. Not keen on the a3 b
#14
Posted 16 February 2016 - 06:43 PM
= 114967
If you look they have changed the 1 to 6, 7, 8, then 9 over the previous 4?years of mot
