Touran DSG problem 2007 - Touran - uk-mkivs
5 replies to this topic
#1 vwtdi130
vwtdi130
  • 327 posts
Posted 25 May 2016 - 09:13 AM
Have a touran at work that occasionally revs between gears like it cant find the next one to select.
We have a speed warning on dashboard and engine temp sensor fault which is being changed tomorrow.
Would any of these be causing this problem ?
Any help is appreciated.
#2 Booster
Booster
    Diesel Geek
  • 4089 posts
  • Berkshire
  • Golf IV GTI 25th Anni 1.9 ARL 150PS
Posted 25 May 2016 - 11:00 AM
Temp sensor might cause higher idle speed. How much variation in rpm do you get on gear change?
Also has the dsg box had services at the correct intervals?
Just a stock diesel Anni................well almost  :new-chuckle:
Build Thread
#3 vwtdi130
vwtdi130
  • 327 posts
Posted 25 May 2016 - 11:13 AM
It revs upto 3k to 3.5k then if you depress accelerator it seems to find a gear and is ok again some days it doesnt do it at all. The oil has just been changed in gearbox
#4 Booster
Booster
    Diesel Geek
  • 4089 posts
  • Berkshire
Posted 25 May 2016 - 11:32 AM
Was a recalibration of the box done after the oil change? If it hasn't I'd get one done as a starter for ten. It can be done with vcds
Build Thread
#5 vwtdi130
vwtdi130
  • 327 posts
Posted 25 May 2016 - 12:22 PM
ok ill ask when its in tomorrow morning thanks for your help
#6 vwtdi130
vwtdi130
  • 327 posts
Posted 27 May 2016 - 10:22 AM
Thanks they recalibrated the gearbox and so far so good
