[Other] Removal of boot lid trim on a 2004 Polo - FAQ Forum - uk-mkivs
Other
Best Answer gerrywac , 07 September 2016 - 05:17 PM
The top section of trim (round the glass) is just snap fit and prised off gently using a wedge tool
The lower section below the window is the same except there are two fastening screws, one each at the bottom of the moulded finger recesses
The lock, mechanism  and handle assembly is fastened to the body with 4 x T30 screws
Diagram and Notes from VW Elsawin workshop manual below
1 -  Handle support
q Remove:
q remove the door lining →General body repairs, interior; Rep. gr.70.
q Remove the command rod -6-.
q Remove the safety clamp and remove the cylinder housing from the handle support.
q Remove the internal multi-toothed screw and remove the handle support.
2 -  Safety clamp
3 -  Handle
4 -  Internal multi-toothed screw
q T 30
q 4 parts
q Torque: 8 Nm
q During installation, fasten central screws first.
5 -  Cylinder housing
q remove:
q Remove the rear door lining →General body repairs, interior; Rep. gr.70
q Disengage the operating rod -6- from operating lever -9-.
q Disengage the safety clamp -2- and remove the housing.
q Install:
q Position the cylinder housing on the handle support.
q Press the safety clamp -2- and secure the housing.
q Engage command rod in the operating lever.
q Install the rear lid lining.
6 -  Command rod
7 -  Latch
q Remove:
q Disconnect luggage compartment lighting switch -F5- harness.
q Disengage the command rod -2-, remove the screws -8- and remove the rear lid lock.
q Install - only with the rotating lock engaged
8 -  Bolt
q Torque: 23 Nm
q Use a Multi-teeth socket mate (enc.1/2") -VW 007CV-
9 -  Activation lever
Go to the full post
2 replies to this topic
#1 gazzer22
gazzer22
  • 2 posts
  • Gloucester
  • Other Models
Posted 07 September 2016 - 01:00 PM
Hi Guys, Please could you tell me how to remove the hatchback / boot lid inner trim and also how to remove the outside boot handle on a 2004 Polo 1.2e,
Many Thanks
Gary
#2 gerrywac
gerrywac
    Hang on like this MKIV thing
  • 4509 posts
  • West Yorks
  • Golf Match 1.9 TDI 105PS
Posted 07 September 2016 - 05:17 PM   Best Answer
[attachment=22050:N55-0274 04 Polo Hatch Lock.png]
1 -  Handle support
q Remove:
2 -  Safety clamp
3 -  Handle
q T 30
q 4 parts
q Torque: 8 Nm
q remove:
q Install:
6 -  Command rod
7 -  Latch
q Remove:
8 -  Bolt
q Torque: 23 Nm
  • gazzer22 likes this
#3 gazzer22
gazzer22
  • 2 posts
  • Gloucester
  • Other Models
Posted 08 September 2016 - 12:37 PM
Thank You very much for your help and perfect instructions and diagram, This will solve the problem perfectly, Cheers Gary
Also tagged with one or more of these keywords: Other
