Help car wont start ☹️ - TDI & Diesel Forum - uk-mkivs
Other
4 replies to this topic
#1 Pizza_time
Pizza_time
  • 21 posts
  • Manchester
  • Bora Highline TDI 1.9 AJM 115PS
Posted 26 December 2016 - 10:21 PM
Ok so im a bit depeserate now guys and need help with my Audi A3 2.0 tdi yes i know not mk4 but hoping someone can maybe point me in the right direction.
Problem is its not starting and just cranking over ive checked with vcds and no errors showing everything seems fine.
However there no noise of the fuel pump priming when igniton is on i know theres a secondery fuel pump at the front of the car but nothing
Ive checked with vcds and both work fine as in activated them via vcds but with the key in they dont work
Car details
A3 2.0 tdi 2010
Cbab engine
Sent from my iPad using Tapatalk
#2 TomasLT
TomasLT
    Hang on like this MKIV thing
  • 4645 posts
  • northern europe
Posted 27 December 2016 - 09:13 AM
Just guessing. There should be a relay for the pump. Try checking that.
#3 Pizza_time
Pizza_time
  • 21 posts
  • Manchester
Posted 27 December 2016 - 10:50 AM
That's what u thought at first but the relay works fine when I test it via vcds
#4 TomasLT
TomasLT
  • 4645 posts
  • northern europe
Posted 27 December 2016 - 03:01 PM
Just guessing again. Ignition is a remote to relay. Vcds test bypasses it. So I would look at ignition, maybe there's bad connection, broken wire, still may be bad relay. Multimeter and stabbing things.
#5 Pizza_time
Pizza_time
  • 21 posts
  • Manchester
Posted 27 December 2016 - 06:58 PM
So I tried again today with my multi metre prodding the lot and all seems fine just don't fire up
So I tested the fuel pump relays again via vcds all seem to work fine so I need to figure out where the power for the relays are coming from
Also tagged with one or more of these keywords: Other
