Beginning:
Current mod/work done list:
Suspension and Braking
Front Suspension:
Coilovers - BC Racing BR type (BC Racing)
Shock covers (Generic unbranded)
New shocks clamp bolts (OEM VW)
New top mounts and bearings (Febi-Bilstein)
Refurbished TT wishbones - cast (OEM Audi)
New wishbone bushes (front and rear)(Lemförder)
New ball joints (MOOG)
Refurbished TT knuckles (OEM Audi)
New wheel bearings (FAG)
New ABS sensors (OEM VW)
Refurbished subframe with bracing welded in (OEM VW)
New aluminium subframe bushes (Custom)
New subframe bolts (OEM VW)
Refurbished TT steering rack - 2.5 turn (OEM Audi)
New steering rack bush (Powerflex)
New TT anti roll bar (OEM Audi)
New anti roll bar bushes (Febi-Bilstein)
New anti roll bar drop links (Febi-Bilstein)
New drop link bolts (OEM VW)
New wheel bolts - tuner key (Unbranded)
New tyres (Michelin CrossClimate+)
New 15mm spacers (Demon Tweeks)
Front Brakes:
New discs - 312mm (Brembo)
New pads (Brembo)
Rebuilt calipers (Pistons, seals, bleed nipples, slide pins, slide pins bushes)(OEM VW)
New carrier mounting bolts (OEM VW)
Refurbished splash shields (OEM Audi)
New braided lines (HEL)
Rear Suspension:
New shocks (BC Racing)
New springs and adjusters (BC Racing)
New spring top rubbers (Topran)
New rear beam bushes - Fabia VRS (Febi-Bilstein)
New rear beam bolts (OEM VW)
New 20mm spacers (Demon Tweeks)
Rear Brakes:
Used rear discs - 256mm vented (Pagid)
Used rear pads (Pagid)
Refurbished calipers and carriers (OEM VW)
New caliper bolts (Generic)
Engine and Transmission
Engine:
Mods:
GTB1756VK turbo with billet compressor wheel and cast manifold (Garrett)
Braided turbo oil feed and silicone return (XMan)
Custom map to ~180BHP (200+ with GTB turbo) (Custom)
Catch can (Mishimoto)
EGR delete (with all new hardware)(Darkside Developments)
N249 and N18 delete and modified N75 bracket (-)
Aluminium intercooler pipework kit (Darkside Developments)
Aluminium S3 intercooler (OEM Audi)
Refurbished inlet manifold (new gasket)(OEM VW)
Turbo back full stainless exhaust system, resonated (new gaskets, Mikalor clamps, and copper nuts)(Milltek)
Custom GTB downpipe (modified Milltek)
Replacements:
Replacement engine on 89k w/turbo (OEM VW)
New timing belt (Gates Powergrip)
New water pump (Febi)
New hydraulic damper (-)
New idler pulley (-)
New heavy duty camshaft (Lear Industries)
New camshaft oil seal (Topran)
New hydraulic lifters (INA)
New camshaft bearings (Kolbenschmidt)
New rocker bolts (OEM VW)
New camshaft carrier bolts (OEM VW)
New rocker cover gasket (Elring)
New sump (Unbranded)
New sump plug - magnetic (Unbranded)
New fuel lines - filter to engine (Unbranded)
Used fuel pump (VDO)
New fuel temperature sensor (OEM VW)
New coolant temperature sensor (OEM VW)
New thermostat (OEM VW)
New front exhaust mount (Unbranded)
New central exhaust mount (Unbranded)
Refurbished central exhaust brace (OEM VW)
New coolant reservoir (Topran)
New dog bone mount (Meyle)
New engine and gearbox mounts (Febi)
Transmission:
Short shifter (Unbranded)
Solid brass end link bushes (Custom made)
Refurbished drive shafts (OEM VW)
New outer CVs (J&R)
Interior
ColorMFA (self-installed)(Autopilot, colormfa.ru)
Custom clocks with custom needles (Self built)
Recaro Trendline bucket seats (with folding added to passenger side)(Recaro)
Seat frames for Recaros (Custom made from OEM brackets)
RCN210 Bluetooth head unit (OEM VW)
Vent mounted digital boost gauge (Ardiuno, self built)
Bora lay-flat vents (OEM VW)
Carbon skinned dash end panels (Custom)
Mk7 GTI gear knob (OEM VW)
Carpet floor mats (OEM VW)
Two mini fire extinguishers (UKFiremaster)
Black headliner and associated hardware (OEM VW/Seat)
Black sunglasses holder (Unbranded)
Inverted climate control display (Custom)
Netoptic trim sandblasted and coated in clear lacquer (OEM VW, custom)
Anniversary pedal covers (OEM VW)
Leather door cards (OEM VW)
Door bin (OEM Skoda)
Exterior
FULL early Votex kit - front valance, early skirts, rear valance, and early hatch spoiler (Votex)
Oz Superleggera wheels 17x7J ET48 (Oz Racing)
Ispiri WRC1 wheels 18"x7.5J ET42 (Ispiri)
Mk5 handle cutout welded into Mk4 boot lid (OEM VW)
Mk6 boot lid handle/badge (OEM VW)
US GTI tails (OEM VW)
Celis “angel eye” headlights (with Philips Racing Vision high beams and Morimoto XB35 Xenon low beams)(Hella)
Bumper vents (FK)
Smoked indicators (Hella)
Mk7 LED rear plate lights (OEM VW)
Pressed steel registration plates (Pressed_Number_Plates)
New style shark fin aerial (Unbranded)
Tow loop cover (OEM VW)
Sharptone horns (Hella)
Software etc.
Needle staging (sweep on startup)
Lit needles
Cruise lamp mod
Windows up/down from fob
Beep on lock
Auto lock doors over 10mph, auto unlock when keys removed
Bora (1C0) CCM for boot pop
Plenty of bits still to be fitted – Brembo 4 pots and LCR 323mm discs, etc.
Jake
Edited by JakeMcC, 07 June 2020 - 11:32 PM.
