MonK-E's Compound Turbo project (its alive......) - Page 27 - Members Rides - uk-mkivs
808 replies to this topic
#781 northpole
northpole
  • 9287 posts
  • Suffolk
Posted 21 May 2020 - 06:43 AM
You 'll fly through that just like when you did the 2.0 slow
  • MonK-E likes this
#782 MonK-E
MonK-E
    Si
  • 2823 posts
  • East Sussex
  • Mk4 Models
Posted 21 May 2020 - 07:11 AM
I hope so, it's a touch more involved this time round but nothing too complicated.
I still need to find out if the speed sensor on the gearbox sends a 5V signal even though its fed 12v. If the signal is 12v it's going to cause issues with the ECU and I may not be able to have boost by gear and speed activated launch control. Something I can look into later theres plenty of other wiring to figure out before then :)
  • northpole likes this
#783 adam-
adam-
    VR6 GT35 4mo
  • PipPipPipPipPipPip
  • 10445 posts
  • Glasgow
Posted 21 May 2020 - 07:29 AM
OEM is 12v. There's no 5v ref on these.
#784 adam-
adam-
    VR6 GT35 4mo
  • 10445 posts
  • Glasgow
*Could build an op-amp easy enough to convert from 12 - 5...
#785 MonK-E
MonK-E
    Si
  • 2823 posts
  • East Sussex
  • Mk4 Models
Posted 21 May 2020 - 07:43 AM
Ahh that's a shame. I read somewhere that some VSS (Toyota, Nissan or somthing) are 12v but output a 5v siganl to the ecu. I was hoping that the sensor would be similar.
I've no idea how to make a op-amp. But I'll have a look about and see if I can find out what's involved.
I have a feeling this isn't going to be straight forward to be able to get the ECU to see vehicle speed and keep the clocks working as normal lol
#786 adam-
adam-
    VR6 GT35 4mo
  • 10445 posts
  • Glasgow
Posted 21 May 2020 - 08:06 AM
Are you keeping ABS?  ECU, ABS and cluster are all tied via CAN.  You can change the cluster to see speed via ABS instead of speed sensor, so that's an option if you're keeping stock cluster and ABS.   I can't imagine you're keeping ABS though.
What ECU are you using and what kind of signal does it need?
#787 MonK-E
MonK-E
    Si
  • 2823 posts
  • East Sussex
  • Mk4 Models
Posted 21 May 2020 - 08:24 AM
Haha yeah I'm trying to keep ABS. I still want to keep it just about road worthy so I can do some testing without needing to go to the track or dyno.
The ECU I have is Motorsport electronics ME442.
I think I can use either a digital or analog 5v signal
https://motorsport-e...ine-management/
#788 adam-
adam-
    VR6 GT35 4mo
  • 10445 posts
  • Glasgow
Posted 21 May 2020 - 08:40 AM
Not sure how it'll react without an ECU because I've never tried it, but worth a stab.  Can record the cluster to use ABS for speed signal and look to fit the box with a dedicated sensor or build a circuit to convert existing to 5v.
If you need a hand, holla!
  • MonK-E likes this
#789 MonK-E
MonK-E
    Si
  • 2823 posts
  • East Sussex
  • Mk4 Models
Posted 21 May 2020 - 09:12 AM
I just had a thought. As RPM is done through CAN on later clocks and the ME442 now supports that I can ask the guys at motorsport electronics to add ABS speed to the CAN list and use that. Which means I shouldn't have to touch the VSS.
It's all a way off yet I still have to finish the exhaust, the rest of the winning and get it running before I really need to thing about launch control and boost by gear.
If motorsport electronics can't help I'll definitely give you a shout buddy :D :Y:
#790 MonK-E
MonK-E
    Si
  • 2823 posts
  • East Sussex
  • Mk4 Models
Posted 22 May 2020 - 08:03 PM
I've now tacked the exhaust system together other than 2 joints.
So tomorrow will be a day of cleaning it up and welding it all out
  • northpole and Glendil like this
#791 MonK-E
MonK-E
    Si
  • 2823 posts
  • East Sussex
  • Mk4 Models
Posted 23 May 2020 - 10:56 PM
Finished up the exhaust today :D
I also welded in some rear exhaust mounts. I'm going to have to do somthing with the handbrake cables. Apparently you can't use cable ties to hold it out the way. As they are only allowed for wires and hoses. Even though they are called cable ties.. lol
#792 Glendil
Glendil
  • 1597 posts
  • Croydon
  • Golf IV GTTDI 1.9 ASZ 130PS
Posted 23 May 2020 - 11:29 PM
Looks bloody mint I brought something for my boot build today
Bolf gttdi asz 130/200 ish MK4 Golf 1.8t aum running after hard graph
http://GLENDILS 1.8T...DI BUILD THREAD
Genuine ross tech hex+can code mk4 clocks and keys mte lit needles and other adaptions read faults and send in email PM me
#793 northpole
northpole
  • 9287 posts
  • Suffolk
Posted 24 May 2020 - 12:21 PM
I'm inclined to buy some exhaust pipes and drive down to you and put myself at work while you watch me building a nice oversized decat dual rearbox delete system for the vectra.... but i won't as i can't be arsed lol  nice work mate ;)
  • MonK-E likes this
#794 MonK-E
MonK-E
    Si
  • 2823 posts
  • East Sussex
  • Mk4 Models
Posted 24 May 2020 - 07:22 PM
Northpole you're more than welcome to pop over. Not sure about the Vauxhall bit though hehe :D
Today was a bit all over the place doing a few bits here and there.
I'll start off with the best bit.
I finished off putting the front end back on and enlarged the hole on the bonnet so I could fit the air filter
After that I sorted the (imo lol unnecessary) heat shield and handbrake cable hangers. I'll talk from experience here, when I had my old 300bhp black 5door golf (some might remember) that had a side exit. I rested the handbrake cable on the top of it with a small amount of heat wrap. I drove it daily and took it to brands hatch a few times on track days. Never once did it melt the cable. But hey enough whinging. Here's how it looks now
With that out of the way I went back to the engine bay and started looking how and where I'm going to mount the 4 port mac valve.
I decided to make a simple little bracket and hang it off the slam panel.
Unfortunately I ran out of the teflon tubing so I couldn't finish the last line to the top port on the wastegate today.
I'm now making a nice little list of all the little bits I need to grab and do before the first fire up. The main thing really is all the wiring. I've been putting it off for a bit now so tomorrow I want to make a start on it.
On a side note anyone remember where I put the o2 sensor..
I can't find it anywhere lol, I'll just have to buy another one and if it finally turns up at least I'll have a spare :D
#795 adam-
adam-
    VR6 GT35 4mo
  • 10445 posts
  • Glasgow
Posted 25 May 2020 - 07:31 AM
YAS
  • MonK-E likes this
#796 northpole
northpole
  • 9287 posts
  • Suffolk
Posted 25 May 2020 - 09:55 AM
Don't be a brand-ist! a car is a car mate, granted some are way better than others and yes i do prefer VW over a whole load of other brands (although the new skoda's octavia VRS estate is making me want one but it has to be the latest model) and everytime i see a lowered mk4 that kinda looks like it's been cared for makes me look a lot longer than i should...  But if i ever go mk4 again it'll have to be an r32... and that won't happen.
#797 MonK-E
MonK-E
    Si
  • 2823 posts
  • East Sussex
  • Mk4 Models
Posted 25 May 2020 - 06:41 PM
Hahaha it was only in jest. I still have a unfinished mk1 Ford focus turbo project sitting in the yard lol
Well today I mostly spent wiring in the sensors. All of them are wired and just need to connect them to the ECU now. Although it's a bit annoying that all of them other than the EGT sensor are 3 wire sensors so itll take a bit of time sorting it all out.
I'm thinking I might re wire the ignition so auxiliarys are on a flip switch and start is on a button. Although it's not really necessary.
I've also added a couple of extra heat shields to protect some of the nearby sensors.
I really wish bank holidays lasted a couple days. It would of been nice to get the wiring in the scuttle panel done. Still a couple of weekends and I think itll be ready for test starting
#798 northpole
northpole
  • 9287 posts
  • Suffolk
Posted 25 May 2020 - 07:16 PM
It's getting so close....
  • MonK-E likes this
#799 MonK-E
MonK-E
    Si
  • 2823 posts
  • East Sussex
  • Mk4 Models
Posted 27 May 2020 - 06:48 PM
Little mid week update.
I've finished off the wiring in the scuttle panel, which just leaves the lambda sensor left to sort out. Oh and theres the window washer wiring and pipes. I'm not sure what I'm going to do there yet because if I want it to be road legal itll still need one.
But I've run out of room in the engine bay so I'm going to have to think it over a bit.
Next up is inside wiring. Theres so much I can strip out here but where to start, I need to get my head round it before chopping through lots of wires really
#800 MonK-E
MonK-E
    Si
  • 2823 posts
  • East Sussex
  • Mk4 Models
Posted 31 May 2020 - 01:04 PM
No update yesterday as I was working through a few issues that I'll get into in a bit. The wait is worth it though.
I wired in the fuel pumps
Then made a quick little relay/fuse board. It still need finishing off as I need to add the charge cooler pump relay and wire all that in.
Then I decided I'll try and fire her up. So I topped all the fluids up, put a couple of cans of Tesco 99 in and calibrated some sensors.
Flicked the key and primed the oil system. Reconnected the injectors and coils. Flicked the key again..... nothing. Just turning over.
After a bit of a closer look I found the tps wiring was wrong.
Generally if you have 3 wires. Red, black and white. You would guess that red would be 5v. Black ground and white signal.
Well clearly not in this case. Red was 5v but black turns out to be signal and white was ground.
Bloody Chinese connector. Still it didn't take much to re pin it properly.
That didn't solve the no spark issue though.
Back to looking through the wiring, I found I put the EGT sensor +into the wrong pin.
After I sorted that suddenly I got spark but no fuel.
So back to wiring diagrams. It looks like after removing the stock fuel pump and other bits, the fuel pump relay which also supplies power to the injectors is no longer working.
Simple fix though ;)
Back to trying to start it. Still no love. And back to no spark.
After tearing what's left of my hair out it turns out that by moving the wiring when sorting the EGT sensor out, it nudged a loose earth. So I cleaned it up and tightened it up.
And then......
https://youtu.be/qG9xHlAchww
  • patchrico and northpole like this
#801 northpole
northpole
  • 9287 posts
  • Suffolk
Posted 31 May 2020 - 02:31 PM
It sounds mental already! Love it... good to see you found the little mistakes and sorted it out in the end.
Ps I bet you you only pulled out the grey hairs
  • MonK-E likes this
#802 MonK-E
MonK-E
    Si
  • 2823 posts
  • East Sussex
  • Mk4 Models
Posted 31 May 2020 - 04:00 PM
It should sound better once I've sorted out the richness and added a touch of 2 step later on :D
Theres a bit more of a underlying issue with the richness though. The lambda is reading massively lean which is most likely a exhaust leak somewhere before the sensor even though I can't hear it anywhere.
Any colour hair is good hair. Unfortunately I have very little of either after the last 24 hours
#803 northpole
northpole
  • 9287 posts
  • Suffolk
Posted 31 May 2020 - 04:13 PM
Lol I can believe that you were thinking wtf? Than slowly retracing most of the cables... yeah I know the feeling... and the reason why I said grey hairs lol been there myself.. and the first start is so important people have no idea...
  • MonK-E likes this
#804 MonK-E
MonK-E
    Si
  • 2823 posts
  • East Sussex
  • Mk4 Models
Posted 31 May 2020 - 05:11 PM
What made it worse is that i doubt my work/wiring so much and the main part of the loom that I modified is running along the chassis rail, hidden by all that turbo junk and a 6speed gearbox tight next to it.
My heart sank when I was considering taking the engine back out..
I think I would of jumped off the workshop roof if I had pulled it all out only to find the main culprit was a dodgy earth in the scuttle panel.
#805 northpole
northpole
  • 9287 posts
  • Suffolk
Posted 31 May 2020 - 07:20 PM
Been there... anyway.. I'm so pleased you got it running ! Hope you get time to do the last bits and bobs so you can go for a test run soon.
  • MonK-E likes this
#806 LR5V
LR5V
  • 897 posts
Posted 31 May 2020 - 09:33 PM
Nice one Si
Windscreen washer - how about a bag kit like the one in this link:
https://www.amazon.c...sc=1&th=1&psc=1
Small capacity, so compact and can be easily be mounted within the cabin
  • MonK-E likes this
#807 MonK-E
MonK-E
    Si
  • 2823 posts
  • East Sussex
  • Mk4 Models
Posted 01 June 2020 - 05:17 AM
Thanks LR5V, after doing a bit of looking about and thinking.
I went for this
https://www.ebay.co....tm/383536518250
I should be able to place it in the boot next to the fuel tank some where. Then use the rear washer hose in the loom to connect to the front washer hose in the scuttle panel.
It also looks like the pump wires run all the way to the rear wiper motor. So I should be able to pick them up just before the go into the boot lid :)
#808 Bhavick
Bhavick
  • 129 posts
  • Golf IV TDI 1.9 ATD 100PS
Posted 01 June 2020 - 01:04 PM
This thing looks mental, i hope your gonna upload lots of videos of it once you get it all up and running properly.
  • MonK-E likes this
#809 MonK-E
MonK-E
    Si
  • 2823 posts
  • East Sussex
  • Mk4 Models
Posted 01 June 2020 - 01:47 PM
There will be alot more. I'll be racing this car with the VWDRC. Which means lots of burnouts, 2 step launches and what not.
This project is really only just beginning. Not only that if the engine stays together theres plans for more upgrades ;)
