MonK-E's Drag car Project - Page 32 - Members Rides - uk-mkivs
949 replies to this topic
#931 MonK-E
MonK-E
    Si
  • 2898 posts
  • East Sussex
  • Mk4 Models
Posted 14 March 2021 - 06:39 PM
Spent the majority of the day planning and thinking.
We have moved the engine forward and up a bit to improve drive shaft geometry and ease of access to the whole drive train. This means don't need to cut the tunnel.
It will also enable us to run tyres up to around 30x10" not that we will go that big but it will give options if needed. Initially we will probably run 28x9"
I've placed an old toyota hylux wheel just to get an idea on rough dimensions.
  • Imagewerx, northpole, Adam_Jonezy and 1 other like this
#932 MonK-E
MonK-E
    Si
  • 2898 posts
  • East Sussex
  • Mk4 Models
Posted 22 March 2021 - 07:59 AM
I had a bit of a thought this weekend. As I have a lot of chassis work to do I might as well start from almost a clean sheet as it'll give me a chance to change a lot of the little bits I wasn't too keen on.
So I pulled the doors off and got to it
Pretty much everything has come out
The majority needed to come out anyway. I will be welding a new dash bar to the cage that the top frame rails for the engine bay will tie into.
With all the junk removed it will give me a chance to shed some of the mk4's lardy body weight. I'm planning on removing all of the inner skin of the back end. I might even go as far as removing the A and B pillar structure then tying them too the cage with dimple die plates. With removing all the unnecessary weight I hope to get the whole car down to around 1000kg with me in the car
  • Adam_Jonezy likes this
#933 Glendil
Glendil
  • 1640 posts
  • Croydon
  • Golf IV GTTDI 1.9 ASZ 130PS
Posted 22 March 2021 - 06:46 PM
Damn that be awesome
Bolf gttdi asz 130/200 ish MK4 Golf 1.8t aum running after hard graph
http://GLENDILS 1.8T...DI BUILD THREAD
Genuine ross tech hex+can code mk4 clocks and keys mte lit needles and other adaptions read faults and send in email PM me
#934 MonK-E
MonK-E
    Si
  • 2898 posts
  • East Sussex
  • Mk4 Models
Posted 03 April 2021 - 05:45 PM
Last weekend I cut the fire wall out and replaced it with somthing a bit lighter and cleaner looking
Then during the week this tuned up
Which means shits getting real with this build.
This is the build spec for a full tubular chassis drag car.
After reading through it couple of times I decided there's only 1 way to do this properly.
So I started cutting away
After a fair bit I managed to separate half the floor from the body.
I also cut the cage off the floor pan. It's a bit of a shame but the only way it's going to be useful now is any short sections of tube I need will be cut out of it.
The rest of the tube chassis and funny car hoop will be new and a mix of cds and cromoly.
Here's how she's looking now. Next up will be chopping the rear floor out, then all the second inner skin.
  • Adam_Jonezy and rainbird like this
#935 Glendil
Glendil
  • 1640 posts
  • Croydon
Posted 03 April 2021 - 05:46 PM
Madnes looking good thou
  • MonK-E likes this
#936 MonK-E
MonK-E
    Si
  • 2898 posts
  • East Sussex
  • Mk4 Models
Posted 03 April 2021 - 05:53 PM
Cheers buddy
Yeah it is getting a little bit out of hand now, even by my standards. I never thought I'd ever build a tube chassis race car
#937 northpole
northpole
    I live here
  • PipPipPipPipPipPip
  • 10318 posts
  • Suffolk
Posted 04 April 2021 - 07:06 AM
I knew you'd get carried away and go full tubular chassis and why not? I mean you got all the tools and access to the materials to do it plus the space to do so.
Just make sure you do it to the standards as nothing would be more annoying than not doing it right and not getting a pass on it once you've build it.
It also gives you a chance to mess with the cars geometry as you can even widen the shell to make it look like that is how it was made in the factory... just don't give up halfway!
  • MonK-E likes this
#938 MonK-E
MonK-E
    Si
  • 2898 posts
  • East Sussex
  • Mk4 Models
Posted 04 April 2021 - 05:10 PM
Yeah it'll definitely be done to spec, hence the sfi 25.4 book.
Got a bit more out today
Now started stripping the inner skin out for a bit of extra weight reduction
Still got a fair way to go but Hopefully some rollcage tube will turn up on Tuesday.
#939 LR5V
LR5V
  • 924 posts
  • Golf V GTI 2.0 200PS DSG
Posted 04 April 2021 - 05:27 PM
If only VWDRC had a Flintstone class - add wheels - and you'd be done!
Excellent work mate.
  • MonK-E likes this
#940 northpole
northpole
    I live here
  • 10318 posts
  • Suffolk
Posted 05 April 2021 - 01:21 PM
it was 4wd you are going for right? might aswell fit the engine in the back you've gone far enough ;)
#941 MonK-E
MonK-E
    Si
  • 2898 posts
  • East Sussex
  • Mk4 Models
Posted 05 April 2021 - 07:54 PM
It would be fairly easy to do that from this stage. But I have other ideas.
I want to build a pro fwd car like in the US. No one seems to make them over this side of the pond, we'll at least not to the same standard. As far as I can tell no one has done it with a mk4 from what I can find. I've been watching a lot of PFI speed which is mainly Honda based but still such a awesome inspiration.
I'm hoping to end up with somthing along the lines of this
  • northpole, rainbird, Glendil and 1 other like this
#942 northpole
northpole
    I live here
  • 10318 posts
  • Suffolk
Posted 05 April 2021 - 08:06 PM
That'll be a serious different setup to most and I haven't even seen them in Europe or Germany
  • MonK-E likes this
#943 marshole82
marshole82
  • 339 posts
Posted 05 April 2021 - 08:31 PM
YES!!!!
I know this is a car forum, filled with manly talk and grease but I feel that this pic deserves some kind of heart emoji...
Ok. 3 kinds.
Sent from my CPH2067 using Tapatalk
  • MonK-E likes this
#944 Burgy
Burgy
  • 178 posts
  • Surrey
  • Golf V GT FSI 2.0 150PS
Posted 06 April 2021 - 10:45 AM
it'll be great when the put the engine in, though probably should have done it back in the workshop!  :D  :lol-lol:
  • MonK-E likes this
#945 MonK-E
MonK-E
    Si
  • 2898 posts
  • East Sussex
  • Mk4 Models
Posted 13 April 2021 - 06:44 PM
The weekend just gone I cut the door pillar out then had to add a fair few braces as the body got a little wobbly
Then started fabricating a chassis jig out of scrap laying about the yard.
The next day I finished it off and levelled it out
After reading through the spec a few times I started with the initial measurements and began laying out the main chassis legs
I've got the day off work tomorrow so I'll hopefully get the majority of the floor layed out and tacked together.
I can't do any of the bends at the moment, due to needing a new electric pump for the tube bender. Fingers crossed that'll turn up by the end of next week. If not I'll be stuck for a bit and probably end up chopping more out of what's left of the body
#946 Glendil
Glendil
  • 1640 posts
  • Croydon
Posted 13 April 2021 - 10:48 PM
Beast mode is on
  • MonK-E likes this
#947 MonK-E
MonK-E
    Si
  • 2898 posts
  • East Sussex
  • Mk4 Models
Posted 14 April 2021 - 02:55 PM
That's the main floor layed out and tacked up. Now waiting on the pump for the tube bender to turn up so I can get on with the main hoop
#948 Adam_Jonezy
Adam_Jonezy
    "I'm not modding this one"
  • 1726 posts
  • Preston, Lancs
  • Golf IV V5 2.3 20v 170PS
Posted 14 April 2021 - 03:11 PM
Your work is amazing mate. This is going to be bloody insane  :wub:
  • MonK-E likes this
#949 MonK-E
MonK-E
    Si
  • 2898 posts
  • East Sussex
  • Mk4 Models
Posted 14 April 2021 - 03:23 PM
Thanks buddy, fingers crossed I'll be able to make it one of the fastest 1.8t's in the country
#950 Gsxkev
Gsxkev
  • 13 posts
  • South Coast
Posted 22 April 2021 - 07:33 PM
Holy moly :blink:  this has got really nuts now!!! :Y: looking forward to this build.
