Rear fog light was white bulb - Audio, Electrics and Lighting - uk-mkivs
7 replies to this topic
#1 lawred2
lawred2
  • 11 posts
  • ireland
  • Golf V S 1.4 75PS
Posted 20 September 2017 - 07:59 PM
Switched on the rear fog light this evening and noticed that the bulb was bright white. Is this right? Thought a rear fog lamp was supposed to be red?
#2 Gti Fly
Gti Fly
    I live here
  • PipPipPipPipPipPip
  • 10574 posts
  • Golf IV R32 3.2 240PS
Posted 20 September 2017 - 09:02 PM
The cluster is red, so it lights up red. Bulb should be clear , or you could use a red one, but there's no need as the lens is red !
If anything lights up bright white then it's wrong
#3 lawred2
lawred2
  • 11 posts
  • ireland
  • Golf V S 1.4 75PS
Posted 21 September 2017 - 08:14 AM
lol well there is something clearly wrong then because this is a bright white light
#4 Burgy
Burgy
  • 166 posts
  • Surrey
  • Golf V GT FSI 2.0 150PS
Posted 21 September 2017 - 09:02 AM
Fog light is red & on the right hand side (for a RHD car) with the white reversing light on the left.
#5 Gti Fly
Gti Fly
    I live here
  • 10574 posts
Posted 21 September 2017 - 09:14 AM
On mk4 there are 2 reverse lights (one each side ) and only one rear fog light.
You can modify the loom to have 2 fog lights (one each side ), but that's a different story.
Why is your fog white ? Do you have aftermarket tail light clusters ?
#6 02-MkIV-ASZ
02-MkIV-ASZ
  • 21 posts
  • Golf IV GTTDI 1.9 ASZ 130PS
Posted 21 October 2020 - 09:04 PM
Hello.
Thought I was going mad. I always knew there were two reversing lights (which is handy when reversing when it's dark), but I always thought there were two fog lights on the mk4. I had a dodgy tail light on the driver's side (bulb connector) and when I went to check the other lights I discovered there seems only to be one fog lamp (also driver's side).  Bizarrely, I have a fog light bulb (25W?) in the 'fog light holder' on the passenger side, but it's not connected.  The car's owners' manual says only one rear fog light and the wiring diagram (and text) in the Haynes manual seems to confirm this.
I can see why VW would use the same bulb module for both sides (simple) and switch the symmetry of the bulbs and relevant wiring, but why include the bulb?
What's the recommended way to wire up the second one, it is legal and what are the pros and cons?  Anyone done this?
As an aside, I can see why not to do this as rear dazzle of fog lights can mask brake lights and with two fog lamps it can effectively mask the brake lights (or indicators) on both sides, which isn't the case for singles. In old days it was common for fog lights to be totally removed from the main light clusters to avoid this, but manufacturers seem to tend towards single clusters now..
#7 Gti Fly
Gti Fly
    I live here
  • 10574 posts
Posted 21 October 2020 - 09:42 PM
Just leave the fog a single bulb.
As you already said. It avoids ppl not seeing the brake lights come on suddenly .
#8 02-MkIV-ASZ
02-MkIV-ASZ
  • 21 posts
Posted 23 October 2020 - 01:30 PM
At least I have a spare bulb!
