Glendil’s 1.8t & GTTDI - Page 2 - Members Rides - uk-mkivs
396 replies to this topic
#31 Glendil
Glendil
  • 1609 posts
  • Croydon
  • Golf IV GTTDI 1.9 ASZ 130PS
Posted 12 December 2017 - 06:14 PM
So been spending the day working out why the car kept cutting out with the help of @adam- suggesting a leak i striped it all down to find
This was the pipe that come from the crankcase to throttle housing so now I have all running issues sorted after Christmas I’ll install my catch can and delete the sai n117 n249 and n80 then get my ecu sent over to Adam exciting times
Bolf gttdi asz 130/200 ish MK4 Golf 1.8t aum running after hard graph
http://GLENDILS 1.8T...DI BUILD THREAD
Genuine ross tech hex+can code mk4 clocks and keys mte lit needles and other adaptions read faults and send in email PM me
#32 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 14 December 2017 - 04:17 PM
So after driving around with thinking my problem was solved car was running nice went out the next morning for it to start doing the same thing but this time no codes until later on this after noon the same code 17705 pressure drop from dump valve so I just started ripping it all out
N117 n249 cut out
Sai is also ripped out all unbolted from the bottom I will also be deleting the evap but just unsure how that completely comes out
Tomorrow morning I’ll drain the coolant out get the combi valve out then I’ll be about there ready to send my ecu of to Adam to map out codes
#33 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 18 December 2017 - 02:44 PM
Sai n117 n249 n80 all out resistor in place till January just to get it running and make sure Iv solved the running issues seems ok so far time will tell like last time it’s going to work with my mate tomorrow have the rear bushes done and throttle realigned and a good old valet curtsey of Vw after Christmas I’ll be installing my catch can and tidying up the engine bay and start cleaning the engine as it’s a state from the split crankcase pipe
#34 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 23 December 2017 - 06:32 PM
So the rear vrs bushes are in and my power flex rear wishbone bushes are in car feels much better will get some pics up in the new year I’ll also be finishing off the delete and catch can install considering ripping out the aircon to is this easy also will it effect the climatronic
#35 TomasLT
TomasLT
    Hang on like this MKIV thing
  • 4645 posts
  • northern europe
Posted 24 December 2017 - 07:08 AM
Why
#36 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 24 December 2017 - 10:20 AM
For starters it’s never hot enough here and second of all I don’t even use it I’d rather the windows down n music up
#37 TomasLT
TomasLT
  • 4645 posts
  • northern europe
Posted 24 December 2017 - 04:55 PM
I use it in the winter too. It adds that fresh air feeling.
#38 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 24 December 2017 - 04:58 PM
I don’t lol I have windows down music on doing my youth boom boom music
  • Spud84 likes this
#39 TomasLT
TomasLT
  • 4645 posts
  • northern europe
Posted 24 December 2017 - 05:47 PM
https://m.youtube.co...h?v=rmkXmE9XGec
#40 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 24 December 2017 - 05:51 PM
Lmao me with hair
#41 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 13 January 2018 - 04:14 PM
So seems my cutting out problem is resolved it was a dead maf sensor also had it tracked today after my new bushes 2 weeks ago and also fitted my new tip I picked up for £60
#42 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 13 January 2018 - 04:15 PM
Will get some bay pics in daylight tomorrow
#43 equalizer
equalizer
  • 54 posts
  • london
  • Golf IV Match 1.4 16v AXP 75PS
Posted 13 January 2018 - 07:21 PM
eeeeeagles lol
#44 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 13 January 2018 - 07:31 PM
eeeeeagles lol
Yes bro soooo happy lol
#45 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 16 January 2018 - 03:03 PM
Ok so tip is on maf has been changed trying to sort this code 17705 and the car cutting out well it run fine for a couple hours then the next day it started to cut out again so I put the old maf back as was no point paying for something I didn’t need done some extensive research as I was 99% there was not a vac leak as I’d changed everything then I read somewhere clean the throttle body so I set about this task today well this is what it looked like
Cleaned it all up realigned it all be gold runs like a dream so far no cutting out and code has not come back fingers crossed
#46 NooNoo
NooNoo
    NooNoo
  • 9367 posts
  • Leicester
Posted 16 January 2018 - 04:19 PM
That's BAD!!!
:o
#47 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 16 January 2018 - 04:22 PM
Ur telling me lol it took me about Half hour to clean it was so built up on the throttle body side I could not move the flap at first till I cleaned it some
#48 NooNoo
NooNoo
    NooNoo
  • 9367 posts
  • Leicester
Posted 16 January 2018 - 04:35 PM
Idle is difficult enough without all that c**p!!!
No wonder it was unhappy  :Y:
Edit: It wasn't a "go to" solution because it's unheard of to cause a stall... fingers crossed
I clean mine about every 5 years lol.
#49 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 16 January 2018 - 04:49 PM
I have read a few times after more searching this was happening all because of dirty throttle body if u google the fault code 17705 u will be amazed it tells you to check dv
#50 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 29 January 2018 - 05:20 PM
So the 1.8t has been running like a dream after my clean of the throttle body role on payday want to get a new filter and a front mount and send my ecu off so I can remove all my taped up resistors only had yellow tape lol
#51 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 06 February 2018 - 05:06 PM
So brought myself and the tdi a little present any guesses
Also the 18t has been at the valet place in Vw Wimbledon they have completely striped the car down and started cleaning it should be with me by Friday looking forward to a good old drive the weekend
#52 TomasLT
TomasLT
  • 4645 posts
  • northern europe
Posted 06 February 2018 - 09:20 PM
A window? Wtf 🤷‍♂️
#53 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 06 February 2018 - 11:20 PM
Yes tinted window for a mere £50 😁
#54 brianpologti
brianpologti
  • 586 posts
Posted 07 February 2018 - 02:52 PM
If it's for the silver one are you going to do the bit in the middle of both doors ?
#55 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 07 February 2018 - 02:54 PM
The silver is already blacked out but the fronts were poor so I picked this up to replace the front then I started looking at how to do the rear so put the rears in the tdi and been quoted £40 to have the boot window done
Edited by Glendil, 07 February 2018 - 02:57 PM.
#56 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 07 February 2018 - 02:56 PM
#57 brianpologti
brianpologti
  • 586 posts
Posted 07 February 2018 - 03:06 PM
I mean like this
http://s115.photobuc...G_5728.jpg.html
With vinyl ?
#58 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 07 February 2018 - 03:08 PM
I mean like this
With vinyl ?
Nothing is showing up buddy
#59 brianpologti
brianpologti
  • 586 posts
Posted 07 February 2018 - 03:16 PM
This one
https://uk-mkivs.net/...-advice-please/
But I think without black roof , just the bit in the middle of the two doors
#60 Glendil
Glendil
  • 1609 posts
  • Croydon
Posted 07 February 2018 - 03:19 PM
I think I see what u mean mine are just std
