Hazard Switch LED Indicator DIY/Modification - D.I.Y Guides and How to Instructions - uk-mkivs
86 replies to this topic
#1 NooNoo
NooNoo
    NooNoo
  • 9360 posts
  • Leicester
Posted 03 March 2018 - 05:10 PM
150mR now the confirmed value for 4 LEDs.
33mR maybe marginal for 2 LEDs but worked for me on 2 units. Might need 40mR.
Fast Flash Current Threshold 'Reprogramming'
This DIY/modification allows the use of 2 or 4 LED indicators WITHOUT the need for additional load resistors.
Fast flash failed lamp detection will still work on the 2 LED option if the normal lamps fail.
On the 4 LED option it may still detect side repeater failure.
LED Lamps Required (or similar)
581 Front Amber LED 120deg (offset)
http://www.ebay.co.u...872.m2749.l2649
382 Rear Amber LED 180deg (no offset)
http://www.ebay.co.u...fsAAOSwJq1ZaC78
Resistors Required
33mR (0.033) 3W wirewound resistor - for 2 LED solution (just rear lamps changed for LEDs).
https://www.ebay.co....8098&rmvSB=true
or
150mR (0.150) 3W wirewound resistor - for 4 LED solution (front and rear lamps changed to LEDs).
Best option...
https://uk.rs-online...istors/4851385/
eBay x 10!
https://www.ebay.co....8UAAOxy~ilSQBdT
Note:
Once you have changed the shunt resistor DO NOT run normal lamps!
The 2 LED modification will tolerate all 4 being normal lamps but the hazard will warm up (hazards on).
The 4 LED modifcation will tolerate 2 of the lamps being replaced with normal ones but the hazard will warm up (hazards on).
The 4 LED modification will NOT tolerate all 4 lamps being normal ones the hazard will get very hot (hazards on).
In BOTH cases I recommend running the correct number of LEDs, 2 or 4!
If you sell your vehicle do not leave this modified hazard switch in place.
There is a risk of 3 watts of power being dissipated in the hazard switch which really is
not advisable (4 LED 150mR solution).
Suggestion
Buy another hazard switch to modify. Then if you ever switch back to normal lamps you can refit your original switch.
Fast Flash Current Thresholds
Fast flash factory current threshold: 2.72 amps
Fast flash 2 LED mod current threshold: 1.485 amps.
Fast flash 4 LED mode current threshold: 0.49 amps.
Information
Two types of hazard switches encountered, both genuine.
Type 1 - fited to my 1998 era car, difficult to disassemble and solder. Nicer 'tick'.
Type 2 - bought off eBay to experiment with, easy to disassemble, easy to solder. Not so nice 'tick'.
Type 1 & Type 2 Side by Side
Type 2 on the left, my original type 1 on the right.
Cold Plastics.
Cold plastic disassembly = broken parts car parts.
Use a hairdryer or leave the hazard somewhere nice and toasty
prior to disassembly.
Type 1 Disassembly
First remove the front of the switch. Use a screwdriver to spring the
two side clips. The circled resistor is the new part that allows 4 LEDs
to be used.
Then lever the rear edge of the black housing up. There is a slot to assist with this.
Do the top and bottom while trying to pull on the grey part. The inner part of the
switch will then slide out of the outer housing.
Exploded view.
Once the grey part has been removed the side springs my slip out.
These simply fit into a slot and need to be refitted later.
Identifying The Shunt Resistor
Spot the 18mR (0.018 ohm) shunt!
Highlighted is the 18mR open air shunt resistor.
I didn't manage to disassemble this type any further. So we are looking
to remove the shunt by heating the joints highlighted. Access is tricky.
Two people actually make it easier, one heating the joint with another
using fine pliers to pull on the shunt leg. Do not just YANK on it, a
substantial amount of heat and dexterity is required.
Removed 18mR Shunt
A clamp to hold the switch is essential IMHO.
Shunt resistor off to the left. You don't need to save this really. Up
to you! Do not try to solder suck the plated through holes, you won't
succeed, the copper lands are too large. What we are going to do is
pre-shape the replacement shunt resistor and solder "top side" only.
Soldering - Difficult Type 1
Here you can see the finished result. The resistor body has to be on this
side as there is no space on the other side.
First, solder the distant "flexible" leg to the far point on the PCB.
Second, solder the resistor body leg to the closest point on the PCB.
Ensure the resistor body and wire do not touch the surrounding plastic.
This resistor will dissipate a small amount of power so keep this neat
and tidy with air space around it.
Close up of the soldering. You can see slight melting of the black relay plastic as access
is not easy. I use SMT flux and an RF iron at work, so kit is important.
Here you can see the other side. The resistor in the plastic tube is for
the red LED that illuminates with the hazards on. This prevents access
on this side.
Another image showing the 150mR wirewound shunt resistor fitted.
If someone manages to strip this type 1 switch further then please comment.
I could not detach the rear assembly which prevents the cream plastic assembly
being removed. Access to the PCB would make this easy.
Re-Assembly Of Type 1
Is pretty straightforward. Before fitting the grey part and PCB back into the outer housing
ensure you have fitted the side spring clips into the side slots. The grey part holds these in place.
Finally refit the front of the hazard with a little force.
Testing
This 4 LED solution was tested initially with 2 LEDs (rear) and 2 normal lamps at the front.
The 150mR shunt resistor got warm as expected (1W dissipation, hazards on). Changing to LEDs on the
front yielded an almost cold resistor. Perfect.
The LED performance is much better than the normal lamps.
Closest one is LED, lamp on far side.
I recommend running/testing the modified switch loose and plugged into the loom.
Run the hazards for at least 2 minutes and ensure the switch does not get hot.
Type 2 Disassembly
Remove the front of the switch, consider the location of the 4 tabs shown.
Ensure the switch is nice and warm so that the plastic is flexible.
I didn't use any tools just gentle persuasion.
Defeat the rear clips as described for type 1.
The grey part will separate from the front part/PCB.
Rear part, watch out for springs.
Remove the side spring clips.
Remove the remaining PCB from the outer housing using the clips
shown.
PCB comes out to the the front.
aHmLwHQ.jpg]
Look for this slightly different shunt resistor on the top side of the
PCB.
Shunt Resistor Removal
The above pads are for the 18mR shunt. Heat each one in turn and
use fine pliers to extract the shunt. Clear the holes afterwards with a
solder sucker.
18mR shunt removed.
Shunt Resistor Replacement
Shape the new shunt resistor and solder into place.
This is much easier than type 1 as you have much better access.
33mR 3W shunt resistor is shown fitted in above images.
Re-Assembly Of Type 2.
Once again is pretty straightforward. Reverse all the stages above. Pay attention to spring positions
(and the switch rod) when refitting the grey back connection part.
______________________________________________________________________________
All done.
The usual disclaimers apply. I am not responsible for any accidents, injuries or fires that may occur due
to this modification.
Please read the NOTE: section above.
I advise the use of the correct number of LED lamps at ALL times.
Enjoy the normal flash speeds fellas!
:Y:
See my build thread for the calculations of the shunt resistors and power considerations.
https://uk-mkivs.net/...tch-mod/page-17
  • Imagewerx and gambitplmg like this
#2 patchrico
patchrico
    No more Mods....Yeah right !
  • 1440 posts
  • Essex
Posted 03 March 2018 - 10:47 PM
Now that's what I call a guide  :)  :Y:
Shall look forward to doing this !
Build Thread / Anthracite / R Line front & modded R32 rear bumpers / Oettinger side skirts / shaved rear door handles with power open / half cup front handles / custom trimmed leather seats / black & grey alcantara interior / custom binnacle / carbon centre console & dash end caps / Carbon Kevlar Cluster case & colour mfa / Audi RS4 steering wheel with engine start button / SFS Supersize TIP / Bosch 440cc Injectors / 3" Downpipe / 3" Alloy MAF housing / SS Custom Airbox / Pro Alloy FMIC / 034 Motorsport Inlet Manifold and fuel rail / Ported Exhaust Manifold / Moroso Catch Can / Silver Project Top Mounts / Vibratechnics engine mounts / Poly bushed suspension / Front & Rear Brace / Bilstein PSS9s / BBS CH custom finish / BBS IMPUL / AP Racing 6 pot calipers / Tarox rears / VR6 clutch G60 SMF / TT cast wishbones & Hubs / R32 steering rack / H&R front Nuespeed rear ARBs / R32 power fold mirrors mod / OEM Xenon Joey mod / BBT K300 turbo 303BHP 324Ft.lbs
#3 Wazzzer
Wazzzer
    Hang on like this MKIV thing
  • 2718 posts
  • Isle of Wight
Posted 03 March 2018 - 10:53 PM
I wonder if you can get the resistor down Maplins
Sent from my SM-G935F using Tapatalk
  • patchrico likes this
#4 NooNoo
NooNoo
    NooNoo
  • 9360 posts
  • Leicester
Posted 03 March 2018 - 11:41 PM
100mR £3.50 delivered for 5.
RS. Just get an account, easy.
Incorrect part - removed.
Free delivery, next day.
#5 NooNoo
NooNoo
    NooNoo
  • 9360 posts
  • Leicester
Posted 03 March 2018 - 11:48 PM
This mod is a bit tricky on type 1, you have been warned 🙂
#6 Wazzzer
Wazzzer
  • 2718 posts
  • Isle of Wight
Posted 04 March 2018 - 09:56 AM
A good excuse to get the second type
#7 NooNoo
NooNoo
    NooNoo
  • 9360 posts
  • Leicester
Posted 04 March 2018 - 10:53 AM
33mR, length 13mm should be OK, a little tight.
https://www.ebay.co....1EAAOSw8lpZJIto
This part looks fine, but I can't give guarantees of course.
:Y:
#8 NooNoo
NooNoo
    NooNoo
  • 9360 posts
  • Leicester
Posted 04 March 2018 - 11:03 AM
I have updated the 'how to' with links to parts on RS and eBay.
Remember this mod is tricky access wise.
I will re-iterate, use the right resistor for your application.
2 LED indicators = 30mR to 40mR 3W.
4 LED indicators = 150mR 3W.
0 LED indicators = normal unmodified switch!
Test and monitor the switch prior to rebuilding your dashboard as recommended.
:Y:
#9 NooNoo
NooNoo
    NooNoo
  • 9360 posts
  • Leicester
Posted 04 March 2018 - 11:05 AM
I have wondered if the eBay switch that was supplied for me to experiment on was genuine.
It's covered in VAG part numbers so I'm guessing it is!
:Y:
#10 patchrico
patchrico
  • 1440 posts
  • Essex
Posted 04 March 2018 - 11:31 AM
All good to go ... have both types of hazard switches to play around with and resistors on order  :)
  • NooNoo likes this
#11 Wazzzer
Wazzzer
  • 2718 posts
  • Isle of Wight
Posted 04 March 2018 - 11:41 AM
Where did you order them from Pat?
#12 NooNoo
NooNoo
    NooNoo
  • 9360 posts
  • Leicester
Posted 04 March 2018 - 11:42 AM
It's a much better solution than load resistors dangling everywhere. Also your car will be electrically more efficient, marginally!
:Y:
#13 NooNoo
NooNoo
    NooNoo
  • 9360 posts
  • Leicester
Posted 04 March 2018 - 11:48 AM
By the way. My other half didn't like the indicator 'tick' sound on the genuine eBay type 1!
So my original one with the open relay design is back in  :Y:
#14 patchrico
patchrico
  • 1440 posts
  • Essex
Posted 04 March 2018 - 12:45 PM
Hazard switches x2 from ebay based on NooNoo's type 1 & 2 pics (will have both types so will mod both) and the resistors from NooNoo's links (100mR from RS and 33mR ebay)  :Y:
  • NooNoo likes this
#15 Wazzzer
Wazzzer
  • 2718 posts
  • Isle of Wight
Posted 04 March 2018 - 05:40 PM
Ebay resistors ordered, will report back when I've completed it :Y:
  • NooNoo likes this
#16 NooNoo
NooNoo
    NooNoo
  • 9360 posts
  • Leicester
Posted 05 March 2018 - 08:28 AM
Other half just called on way to work, says left indicator fast flashing. Must have not fitted a lamp properly. If the design was wrong both would fast flash... Watch this space 🙂
#17 NooNoo
NooNoo
    NooNoo
  • 9360 posts
  • Leicester
Posted 05 March 2018 - 09:45 AM
OK, we maybe marginal on the 4 LED shunt value. Sorry guys. Both sides were working fine on Saturday.
All lamps are working according to Amanda just the offside fast flashes. Weird as all lamps are the same.
So I can only think the value is marginal. I'll keep you posted.
I may have rushed into publishing this how to... we maybe looking at 120mR or 150mR.
Update to come when I get time.
:Y:
#18 Wazzzer
Wazzzer
  • 2718 posts
  • Isle of Wight
Posted 05 March 2018 - 12:16 PM
I'll expect to be reimbursed for the cost of my resistors then
  • NooNoo likes this
#19 NooNoo
NooNoo
    NooNoo
  • 9360 posts
  • Leicester
Posted 05 March 2018 - 04:21 PM
Yeah sorry! Will buy you a beer if we ever meet  :D
#20 NooNoo
NooNoo
    NooNoo
  • 9360 posts
  • Leicester
Posted 05 March 2018 - 04:50 PM
I have some 150mR shunts on order. Will take a quick look tonight but it will be a few days before a I can test this.
Something I didn't consider is the duty cycling being 50/50 despite there being a capacitor in the circuit to maintain the voltage across the shunt...
I was also trying to preserve side repeater failure detection.
Sailed too close to the wind it seems!
:whistle:
Ok quick investigation. All good with the engine off. With the increased system voltage (14V) when running it's pushed the offside into fast flash. 150mR should arrive tomorrow.
#21 Wazzzer
Wazzzer
  • 2718 posts
  • Isle of Wight
Posted 05 March 2018 - 08:52 PM
I understand absolutely nothing about electronics unfortunately so I'll leave it to you to do your thing and experiment
#22 NooNoo
NooNoo
    NooNoo
  • 9360 posts
  • Leicester
Posted 07 March 2018 - 04:16 PM
Modified my eBay type 2 switch with 150mR. Testing tonight :)
#23 Wazzzer
Wazzzer
  • 2718 posts
  • Isle of Wight
Posted 07 March 2018 - 08:41 PM
:whistle: :Y:
#24 patchrico
patchrico
  • 1440 posts
  • Essex
Posted 07 March 2018 - 08:54 PM
:whistle:  :Y:  ;)
#25 NooNoo
NooNoo
    NooNoo
  • 9360 posts
  • Leicester
Posted 07 March 2018 - 09:31 PM
Didn't manage to test tonight, left work late and CBA 😁
#26 brianpologti
brianpologti
  • 586 posts
Posted 08 March 2018 - 05:45 PM
Lucky I was slow didn't solder mine in haha , guess the resistors will go into my box of random golf stuff , lol
  • NooNoo likes this
#27 NooNoo
NooNoo
    NooNoo
  • 9360 posts
  • Leicester
Posted 08 March 2018 - 06:09 PM
Tested and perfect.
@patchrico will post you a 150mR FOC.
@Wazzzer will post you a 150mR FOC.
@brianpologti will post you a 150mR FOC.
Please PM addresses if you want...
Will revise How To soon!
#28 NooNoo
NooNoo
    NooNoo
  • 9360 posts
  • Leicester
Posted 08 March 2018 - 06:12 PM
Sorry to anyone else who was quick to buy.
I will probably revise the 2 LED solution also, maybe to 40mR (but I think 33mR will be OK).
#29 patchrico
patchrico
  • 1440 posts
  • Essex
Posted 08 March 2018 - 07:21 PM
Tested and perfect.
Man.....you don't have to do that. I'm happy that I've got your guide to work to.
Just post up a link to the ones you used   :Y:
#30 Wazzzer
Wazzzer
  • 2718 posts
  • Isle of Wight
Posted 08 March 2018 - 07:24 PM
@NooNoo same, don't fret about it mate
  • NooNoo likes this
