After finally getting my Mk4 to a point where I'm happy with it as a reliable (?
The car is a 1983 1.3 Driver edition. My uncle adapted some Mk3 Recaros to fit and it was fitted with a towbar at some point but apart from that it seems to be completely stock. The plan for this is to do a full restoration - bare metal, nut and bolt rebuild. I'll hopefully be swapping in an ABF 2.0 16V and most likely running it on ITBs. Currently I'm thinking the shell will be painted in RAL5009 which is similar to VW Monaco Blue, and will run small chrome bumpers, riding on 3 piece 15" wheels. This could all change as I work on it though!
It has a few patches that need attention...
..but is overall a very solid shell. Nevertheless, it'll be getting a thorough restoration. First job is stripping it down - started off with the interior. Mad quick release seat belt function, no need to undo any bolts, just pull!
Windows out so the headliner can be removed...
And interior stripped.
Next job is to disconnect the engine loom and pull the fuse box with the rest of the dash/interior loom, then it's time to pull the engine!
I've already started collecting bits, early front grill, chrome grill trim and badge, chrome waist and sill trims, and early chrome front bumper (managed to get a genuine one!).
-Jake
