Need help with spacers - Wheels and Tyres - uk-mkivs
7 replies to this topic
#1 michaelwillis06
michaelwillis06
  • 6 posts
Posted 13 November 2019 - 05:28 PM
Need to know which spacers to run for my wheels to stop hitting the coilovers car is lowered about 40mil wheels are 18x8.75j et33 with a 225/40 tyre.
Sent from my SM-G960F using Tapatalk
#2 ttg4l
ttg4l
  • 699 posts
  • Golf IV 1.6 16v BCB 105PS
Posted 13 November 2019 - 06:03 PM
15mm should do it, as a semi-logical guess.
Here's my thinking:
Anniversary wheels are 18x7.5j with a 38 offset, so they're 0.75 inches narrower (0.75 inches = 19mm)
Your offset is 5mm lower than the anniversary wheels, so they sit 5mm further out, so subtract that from the extra width and you've got approximately 14mm extra width (19mm-5mm).
Add in the 15mm spacer and you should be plenty clear of the coilovers. 10mm would probably even do it, but I'd say 15mm to be safe.
What part of the wheel is hitting? And how badly is it hitting?
Probably best to find someone with a similar set up to confirm for sure, but imo 15mm should do it.
#3 michaelwillis06
michaelwillis06
  • 6 posts
Posted 13 November 2019 - 06:12 PM
Was thinking 15mm myself but didn't want to much poke...its the top of the alloy that is touching quite badly without even turning the wheel.
#4 adam-
adam-
    VR6 GT35 4mo
  • PipPipPipPipPipPip
  • 10584 posts
  • Glasgow
Posted 13 November 2019 - 06:36 PM
Touching what?  The wheel does not move if you turn the wheel, the only thing it can touch is the arch.
#5 michaelwillis06
michaelwillis06
  • 6 posts
Posted 13 November 2019 - 06:38 PM
When you put the wheel on the hub the alloy hits the coilover.
#6 DPM
DPM
  • 5759 posts
  • Newcastle Upon Tyne
  • MKI Models
Posted 14 November 2019 - 01:43 PM
8mm or 10mm H&R hubcentric would be our recommendation but you'd then be best to at least match at the rear for visual look as well.
Damian @ DPM Performance
DPM PERFORMANCE
The premier online suspension and handling specialists!
0191 2816844
#7 michaelwillis06
michaelwillis06
  • 6 posts
Posted 14 November 2019 - 01:44 PM
Yes was going to get all 4 anyway just didn't want to get the wrong ones
#8 DPM
DPM
  • 5759 posts
  • MKI Models
Posted 15 November 2019 - 12:03 PM
Drop us a PM if we can be any help with info or prices.
DPM PERFORMANCE
0191 2816844
