Thought I was done with filthy manifolds - Other Brands Discussion - uk-mkivs
22 replies to this topic
#1 Evil
Evil
  • 1480 posts
  • Mid-Suffolk
  • Golf IV GTTDI 1.9 ASZ 130PS
Posted 21 May 2020 - 02:24 PM
after the arduous cleaning of the Golf and Passat inlets..
But no..
There's an issue with the Frontera so here we go again (for the flipping last time I hope!!)
Inlet elbow and EGR (already off), swirl flaps (WTF!) and inlet..
Cleaning spray arrives tomorrow so tomorrow it'll get put back together.
Next year I'm buying something lower maintenance (and better performance /comfort).. 8d224f6a4b7b4575ef667ba7cbf9f3e0.jpg31636278fe55751de5bc68c5e961dc72.jpg
Sent from my LYA-L09 using Tapatalk
Edited by Evil, 21 May 2020 - 02:25 PM.
#2 northpole
northpole
  • 9767 posts
  • Suffolk
Posted 21 May 2020 - 03:00 PM
Y20DT engine huh? yes that is a bugger to clean.. you should've gone for seafoam just be glad you got the older version at least you can block the egr without having to buy an egr cheater to fool the ECU... also you can easily remap it to go from 99 to 139 bhp...
#3 Evil
Evil
  • 1480 posts
  • Mid-Suffolk
Posted 21 May 2020 - 03:32 PM
Y22DTH..
EGR was brand new maybe 6 months ago.
Not sure about the remap option, was chatting to a bloke up Norwich way and he was uncertain..
I think it's about 120bhp in the frontera (but 140-ish in the Omega, dunno where they get ~20 brake from but it'd be groovy to have)
She's not long had 5 new tyres fitted otherwise she'd likely have scrapped it..
#4 northpole
northpole
  • 9767 posts
  • Suffolk
Posted 21 May 2020 - 04:15 PM
Y22dth? They manage 160 in the vectra's same bloody engine but edc15 ecu meaning you can mpps it... get teapot of vectra-c.com to remote map it for you... will need mpps v18 though... think that is the cheapest way to get a proper remap for your engine...
And yes they are dirty engines both y20dth and y22dth suffer from it... and you'll need an egr cheater if you want to get rid of the egr valve...
#5 Evil
Evil
  • 1480 posts
  • Mid-Suffolk
Posted 21 May 2020 - 04:27 PM
It was teapot I was emailing. He can't do it.
It's got the psg16 ecu.
Current top option is a Steinbaur tuning box that'd perk it up to Omega power.
But we need to make sure its issues are fixed by cleaning first.
Vectra C is the Y22DTR.. the B had the DTH (not a clue of any difference, they both make the same stock power so I'd guess it's minimal)
#6 northpole
northpole
  • 9767 posts
  • Suffolk
Posted 21 May 2020 - 06:44 PM
Yeah no vectra c is DTH mate my engine is the smaller y20dth... DTR is the older version found in the vectra B... has the small vacuum operated EGR as opposed to that big old electric egr cylinder thing we got on the engine... ps don't forget to clean the VNT mate as you got the variable turbo...
#7 Evil
Evil
  • 1480 posts
  • Mid-Suffolk
Posted 21 May 2020 - 07:06 PM
The B has the DTH..
I ain't cleaning a turbo. Still not done the one in the golf, they confuse the living crap out of me.
#8 northpole
northpole
  • 9767 posts
  • Suffolk
Posted 21 May 2020 - 08:22 PM
Latest version of that engine is dth not DTR... 2.2 16v dti diesel engine right? DTH... as I said my vectra C has a 2.0 16v dti diesel engine code = y20dth... differences between yours and mine are.. bottom block and you got a variable turbo... and your diesel pump is setup for that but basically we got the same engine... I'm even sure you got the f23 gearbox also with the same ratios
#9 Evil
Evil
  • 1480 posts
  • Mid-Suffolk
Posted 11 June 2020 - 01:24 PM
Ba$tard fuel pump won't prime..
Aside from a priming pump we've tried all other methods found across the net.
Might order a priming pump but I think kirsty's just sticking it up for sale for £500 spares or repair.
#10 northpole
northpole
  • 9767 posts
  • Suffolk
Posted 11 June 2020 - 01:55 PM
tow start it... it'll push the air out, if it doesn't start that way than there is something else wrong... anyway once it runs she/you can ask more for it...
  • Evil likes this
#11 adam-
adam-
    VR6 GT35 4mo
  • PipPipPipPipPipPip
  • 10711 posts
  • Glasgow
Posted 11 June 2020 - 02:06 PM
Feed it ether for 5 minutes.  Little squirts at a time.
  • Evil likes this
#12 Evil
Evil
  • 1480 posts
  • Mid-Suffolk
Posted 11 June 2020 - 03:08 PM
I'll see if she fancies having a bash at that in the next few days (we're almost at the 'cgaf I'll just scrap it' stage)
Could probably get some from somewhere.. never done that on a derv before.. only ever on 80's/90's petrol cars.
  • northpole likes this
#13 adam-
adam-
    VR6 GT35 4mo
  • 10711 posts
  • Glasgow
Posted 11 June 2020 - 03:15 PM
Deodorant works in a squeeze.
#14 northpole
northpole
  • 9767 posts
  • Suffolk
Posted 11 June 2020 - 03:52 PM
So does WD40 lol but I wouldn't use either... a tow start will actually help remove the air... just get the car up to 30 mph put it in 3rd gear, and slowly let the clutch come up... 9 out of 10 times it immediately fires up as soon as the clutch is fully engaged.... the reason to do it slowly is because you are being towed... and as soon as it runs, take it out of gear signal the tower stop on the side and drive back... park it and turn it off... than on again should start immediately
  • Evil likes this
#15 Evil
Evil
  • 1480 posts
  • Mid-Suffolk
Posted 19 June 2020 - 12:18 AM
Kirsty bought a priming bulb thingummy.
It didn't fit so I had to fiddle about and make it (got there just in time, Kirsty was about to phone the scrappy)..
Primed, bulb went firm, cranked it over - nothing.
Slackened fuel rail to 1 & 2, re-primed, fuel came out, tightened them back up, cranked it, tried to start, sounded horrific, Kirsty thought we'd killed the fuel pump.
Slackened 3 & 4, re-primed, got fuel, re-tightened, cranked it and it fired up, sounded good, took it for a little spin (after removing the primer bulb). Runs lovely..
She's going to use it for work for a week and see how it goes..
If it's good, and she's confident in its reliability, we'll be pushing to get the golf gone. Otherwise, the frontera will go.
Either way we lose a chunk of £'age and someone gets a good deal.
Edited by Evil, 19 June 2020 - 12:20 AM.
#16 northpole
northpole
  • 9767 posts
  • Suffolk
Posted 19 June 2020 - 05:31 AM
Glad it's sorted, you didn't try the tow-start at all than?
#17 Evil
Evil
  • 1480 posts
  • Mid-Suffolk
Posted 19 June 2020 - 05:37 AM
We didn't.. Kirsty was worried it'd harm the fuel pump (and probably didn't want the responsibly of towing or being towed) so wanted to exhaust other options first.
#18 northpole
northpole
  • 9767 posts
  • Suffolk
Posted 19 June 2020 - 05:51 AM
I get that but it wouldn't have killed the pump... but hey you got it sorted... next time you replace the fuel filter remember to clamp the fuel lines right after the filter housing both of them that way the fuel stays put.
Still not liking the fact the golf is constantly in danger of being sold but hey you got enough project cars to sort out.
#19 Evil
Evil
  • 1480 posts
  • Mid-Suffolk
Posted 19 June 2020 - 06:04 AM
The golf is a lot of fun and I'll be sad to see it go.. we've put over 30k miles on it, think that's the most I've done in a car in 36 years of driving.
Plus, in spite of finally getting back to full ncb, my insurance premium has exceeded £300 (£280 last year) in spite of being in a lower band postcode. I'm outraged (not really but I am a little peeved).
Think she'll get a garage to do the fuel filter, the bolts are solid and she thinks they're going to snap - plus they get any hassle getting it started again
#20 Evil
Evil
  • 1480 posts
  • Mid-Suffolk
Posted 20 June 2020 - 09:50 AM
Looks like the frontera is going..
Suppose I need to get my head around the heated seat and W8 light wiring in the golf.
And get the windscreen replaced .
Fit another door module.
Replace both coolant sensors.
Balls
#21 northpole
northpole
  • 9767 posts
  • Suffolk
Posted 20 June 2020 - 10:39 AM
Good news but it also means you got lots to do on the golf.... cars it never stops...
#22 Evil
Evil
  • 1480 posts
  • Mid-Suffolk
Posted 20 June 2020 - 02:38 PM
Bloody well will (stop).. I'm getting a bit past all the spannering shenanigans.
Until we get the front garden concreted and then all bets are off
#23 northpole
northpole
  • 9767 posts
  • Suffolk
Posted 20 June 2020 - 03:50 PM
Lol... you mean you are going to postpone the jobs... doesn't stop them from needing to be done though
  • Evil likes this
