[Mk4 Golf] Replacing immo 3 with used immo 3 cluster. - Audio, Electrics and Lighting - uk-mkivs
Mk4 Golf
2 replies to this topic
#1 Rob136
Rob136
  • 1377 posts
  • Golf IV TDI 1.9 ATD 100PS
Posted 28 May 2020 - 08:26 PM
Hi, the Speedo has packed up on my vr6 so the Speedo needle is stuck at differant speeds (even when switched off). I've got the part no and the skc code and the original cluster is a Bosch unit.
I've found plenty of second hand ones on eBay and most seem to be VDO. This is good as it means I can easily add miles to empty however I'm not sure where I stand with copying the current Bosch settings onto the VDO. Also I presume a second hand unit won't have the skc. If I install it can I retrieve the skc from the new cluster if it is not yet coded to the car?
#2 mur3633
mur3633
  • 163 posts
  • Podgorica, Montenegro
  • Golf IV GTTDI 1.9 AJM 115PS
Posted 28 May 2020 - 09:11 PM
You'll need Vag Commander.
#3 adam-
adam-
    VR6 GT35 4mo
  • PipPipPipPipPipPip
  • 10584 posts
  • Glasgow
Posted 29 May 2020 - 06:14 AM
Can read the Bosch SKC with KCommander, then read the new cluster SKC with EEPROM Programmer and can use DashDump to join or you'd be faster using VCDS to adapt properly.
