Golf MK4 cruise control - Welcome to uk-mkivs - uk-mkivs
1 reply to this topic
#1 adam66
adam66
  • 1 posts
  • Luton
Posted 29 May 2020 - 08:04 AM
OK. So I have a 1999 Golf mk4 1.8t GTI with an AGU engine and I would like to install cruise control.
Only problem is, I have a cable driven throttle body, so it`s not possible.
As some of the later models are "fly by wire", some of the 1.8t`s did come with factory fitted cruise control, so my question is this.
I realise that if I want to fit cruise control, I would need to swap out the throttle body and ecu, but does it HAVE to be from a factory fitted AGU engine or can it be from any other relevant mk4 GTI.?
Many thanks.
#2 northpole
northpole
  • 9448 posts
  • Suffolk
Posted 29 May 2020 - 09:24 AM
this is an introduction section, but you haven't introduced yourself at all.  .
@moderator could you move this to the appropriate section?
