Vac pipes V6 4motion - FAQ Forum - uk-mkivs
4 replies to this topic
#1 xbl
xbl
  • 3 posts
  • Chester
  • Bora V6 4motion 2.8 24v 204PS
Posted 14 July 2020 - 05:56 PM
Hi guys, looking for a little help with the vacuum system, I could either do with a vac diagram for my Bora 4motion or some info on where the open end of the tee goes in the following picture....
TIA
Sent from my VOG-L09 using Tapatalk
#2 DerPanzerWagen
DerPanzerWagen
  • 326 posts
  • Wales
Posted 14 July 2020 - 11:53 PM
There should be another tee further along that line: check behind cyl. 2. A braided pipe thing connects the pair of them, looks like it's missing. On mine the pipe frayed due to heat and it left a nice trail of oil down the back of the block. Costs approx. £30 from VW but you get the black pipe too.
...If there's no other tee along the pipe, then I'm thinking of something else.
  • xbl likes this
#3 Neutron
Neutron
  • 883 posts
  • West Sussex
Posted 15 July 2020 - 09:14 AM
That'll be your vac leak then :) The hose on mine goes from there to the underside of the crank case breather pipe near the elbow that connects to the intake pipe. I'm guessing that's the clear reinforced PCV hose in your pic
  • xbl likes this
#4 Neutron
Neutron
  • 883 posts
  • West Sussex
Posted 15 July 2020 - 09:36 AM
search part number 022103474B (or maybe 022103474G for a revised version?) you'll see there's a PCV pressure control valve in that breather pipe that is actuated by that missing vacuum line
  • xbl likes this
#5 xbl
xbl
  • 3 posts
  • Chester
Posted 15 July 2020 - 09:39 PM
Thanks for that! I guess I can just blank it off then as there's a catch can on the end of the clear hose now.
