Air Con not working, VCDS fault code and measuring block data - VAG Diagnostic Software Discussion - uk-mkivs
3 replies to this topic
#1 TdiBlacky
TdiBlacky
  • 404 posts
Posted 23 July 2020 - 02:06 PM
The A/c isn't working on my Golf, 2.0L BKD engine if that helps with info.
There's 1 fault code in the a/c hvap module which comes straight back when I attempt to clear it:
00229 - Refrigerant Pressure
          002 - Lower Limit Exceeded
I have screen shots of the measuring blocks if needed too.
The "Compressor Shut-Off code" in the measuring block is "3.0". Where do I find the fault / reason that this no. 3.0 translates to?
Is the above fault code simply saying that the A/c can't switch on because the gas pressure is too low and it's possible it just needs a leak test + refill / top up? Or is it more complicated than this?
Cheers in advance :)
#2 adam-
adam-
    VR6 GT35 4mo
  • PipPipPipPipPipPip
  • 10640 posts
  • Glasgow
Posted 23 July 2020 - 04:08 PM
Refrigerant pressure: 0.00 bar.  It's empty.  Find the leak, refill.
#3 Imagewerx
Imagewerx
  • Moderators
  • 50049 posts
Posted 23 July 2020 - 07:12 PM
Always ask techical questions in the relevant techical section.they're VERY easy to find.
#4 TdiBlacky
TdiBlacky
  • 404 posts
Posted 01 August 2020 - 12:25 PM
I got it leak tested and refilled, no leaks were found, ice cold again now :)
