[Other] My Friends Audi A4 B6 TDI 1.9 PD130 Fault Codes Help - Audio, Electrics and Lighting - uk-mkivs
Other
5 replies to this topic
#1 joe bora tdi
joe bora tdi
  • 58 posts
  • sheffield
  • Bora SE TDI 1.9 ASZ 130PS
Posted 24 July 2020 - 10:35 PM
Hi
Did a read of my friends fault code and this is what it came back with can anyone help me figure our what they all are please.
Many Thanks
Joe
VCDS-Lite Version: Release 1.2
Thursday, 23 July 2020, 22:57:41:5433
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01: Engine Labels: 038-906-019-AVF.LBL
Controller: 038 906 019 FP
Component: 1,9l R4 EDC 0000SG 1538
Coding: 00002
Shop #: WSC 63351
VCID: 6AA754920567
WAUZZZ8E12A274867 AUZ6Z0B0032898
1 Fault Found:
17994 - Engine Mount Solenoid Valves (N144/N145): Short to Plus
P1586 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
VCID: E5BDA7AE6C79
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Controller: 8E0 820 043
Component: A4 Klimaautomat 1012
Coding: 00000
Shop #: WSC 63351
VCID: DECF8842492F
3 Faults Found:
00716 - Air recirculation Flap Positioning Motor (V113)
41-10 - Blocked or No Voltage - Intermittent
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
30-10 - Open or Short to Plus - Intermittent
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Controller: 8E0 907 279 C
Component: int. Lastmodul RDW 0203
Coding: 00001
Shop #: WSC 63351
VCID: 32178CF2ED37
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Controller: 8E0 959 655
Component: Airbag 8.4E 3001
Coding: 0010602
Shop #: WSC 63351
VCID: F49BCAEAD7A3
Address 16: Steering wheel Labels: 8E0-953-549.LBL
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00002
Shop #: WSC 63351
VCID: 361FB0E2015F
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Controller: 8E0 920 950 F
Component: KOMBI+WEGFAHRS. RB4 D26
Coding: 00400
Shop #: WSC 11111
VCID: 2C2B928ACF13
3 Faults Found:
01331 - Door Control Module; Driver Side (J386)
49-10 - No Communications - Intermittent
01332 - Door Control Module; Passenger Side (J387)
49-00 - No Communications
01304 - Radio
Address 45: Inter. Monitor Labels: 8E0-951-177.LBL
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
VCID: EBA9D1968A9D
Address 46: Central Conv. Labels: 8E0-959-433-MIN.LBL
Controller: 8E0 959 433 AJ
Component: Komfortgerát T9F 0619
Coding: 07115
Shop #: WSC 63351
VCID: 79857BDE70C1
11 Faults Found:
01134 - Alarm Horn (H12)
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01384 - Alarm triggered by Glass Breakage Sensor
35-00 - -
01561 - Left Rear Door
61-10 - Won't De-Safe - Intermittent
01562 - Right Rear Door
59-10 - Can't Unlock - Intermittent
End -------------------------------------------------------------------------------------------------
#2 joe bora tdi
joe bora tdi
  • 58 posts
  • sheffield
Posted 24 July 2020 - 10:36 PM
Hi
The year is 2002  :Y:
Many Thanks
Joe
#3 adam-
adam-
    VR6 GT35 4mo
  • PipPipPipPipPipPip
  • 10758 posts
  • Glasgow
Posted 25 July 2020 - 10:42 AM
 Engine mounts are vac controlled and the soleniod has grounded out.  It's intermittent, so consider replacing.
The flap is jammed or the gears are rounded.
Same as above. Check flap if it's stuck.
AC pressure is too low.
Drivers door lock is dead.
Passenger door lock is dead.
01304 - Radio
Likely sporadic fault or is aftermarket.
Drivers door module is dead or has been unplugged.
Passenger door module is dead or has been unplugged.
#4 adam-
adam-
    VR6 GT35 4mo
  • 10758 posts
  • Glasgow
Alarm horn likely battery flat.
A few break ins.
Rear door module dead.
Tbh, these are all codes over the years I'd have said, rather than all of a sudden, what specific problems do you have?  Clear them and see what returns.
#5 joe bora tdi
joe bora tdi
  • 58 posts
  • sheffield
Posted 25 July 2020 - 08:14 PM
Hi
yes were looking into getting things fixed but want to know what we will need overall to clear the codes properly.
Cheers Joe
#6 adam-
adam-
    VR6 GT35 4mo
  • 10758 posts
  • Glasgow
Posted 26 July 2020 - 12:25 PM
Clear all the codes and start fresh.  Those door modules could have been replaced a long time ago...
Also tagged with one or more of these keywords: Other
