[Mk4 Golf] Oil smells like exhaust - Engine, Tuning and Performance - uk-mkivs
Mk4 Golf
3 replies to this topic
#1 ttg4l
ttg4l
  • 857 posts
  • Golf IV 1.6 16v BCB 105PS
Posted 05 August 2020 - 11:17 AM
Dropped my oil yesterday and it smelt quite exhausty, it did so last time as well but the last change was after 10k miles so I just assumed it was because the oil change was a bit late. This time round it was after 4k miles.
Is it likely to just be because of blow by? Or something more sinister? It's a bit of an exhaust/petrol smell. Oil level doesn't increase between changes. Oil otherwise looked okay, no milky-ness and it didn't look thinner than it should.
The car is on 164k miles.
TIA.
#2 northpole
northpole
  • 9829 posts
  • Suffolk
Posted 05 August 2020 - 02:01 PM
in combo with the engine pinking i think there is more stuff wrong... I would have a compression test done..
#3 ttg4l
ttg4l
  • 857 posts
Posted 05 August 2020 - 05:00 PM
I'd already ruled out compression since the car burns minimal oil between changes (never needs topping up), doesn't emit any blue smoke, has no misfiring, and starts good hot/cold, but I'll get a compression test done anyway.
I was thinking it could be a bad oil separator which could be letting the crankcase vent straight into the sump.
Or maybe a bad injector, which I was thinking could also cause some pinking.
#4 northpole
northpole
  • 9829 posts
  • Suffolk
Posted 06 August 2020 - 09:25 AM
yes all possible...  but with the egr being one of the problems on your engine it might be that.
