Water pump change - D.I.Y Guides and How to Instructions - uk-mkivs
Water pump change
Mk4 Golf
1 reply to this topic
#1 Atrix
Atrix
  • 15 posts
  • Suffolk
Posted 09 August 2020 - 08:29 AM
Does anyone have a good guide for a water pump change with tools required for a 2000 Golf 1.8t? Haven’t found anything good from browsing google, and want to make sure I have everything before starting.
#2 adam-
adam-
    VR6 GT35 4mo
  • PipPipPipPipPipPip
  • 10757 posts
  • Glasgow
Posted 09 August 2020 - 06:41 PM
It's just a timing belt change.  16, 18, 13, 10, 6mm Allen, 15mm spanner.
Remove aux belt using the 15mm spanner.
Remove bottom 4 bolts on the crankshaft pulley.  They're Allen heads.  DO NOT ROUND.
Remove aux pulley.
Move coolant ball, power steering bottle and make space.
Support engine.
Remove two 18mm bolts.
Remove three 16mm bolts on mount.
Remove mount.
Remove covers.
Remove belt.  Put at TDC using stock timing marks.
Remove three 10mm bolts holding WP bolt.
Replace pump.
Replace belt.
Redo.
